Pocket GPS World :: View topic - Txt format DB for Alpine Satnav help please
Antitheft2
PostPosted: Tue Aug 25, 2009 1:57 pm    Post subject: Txt format DB for Alpine Satnav help please Reply with quote
Have been hunting for an answer to this for days now and wondering if anyone can help.
I have an Alpine PMD-B200P Satnav unit (hand held unit that docks with the stereo in my car to give in car satnav too).
I love this unit, but the default camera poi is pretty useless and I'm hoping to use the PGPSW database instead.
I've tried the one from your main "competitor" which works perfectly but only lists fixed cameras and doesn't give warnings of possible mobile positions.
Importing the database on the Alpine unit is really straight forward and is done via a specifically formatted text file. I'm hoping that one of the standard text files available through PGPSW is compatible. But as I'm sure you'll understand I don't want to pay my £20 just to find out that none of them are.
So, if possible I'm hoping someone confirm that one of the txt file format databases on PGPSW matches the below format because if they do, then they'll work with the Alpine unit and I'll happily spend my money to get it.
Code:
X, Y, TYPE, SPEED, DIRTYPE, DIRECTION
-1.9092200,52.5159400,1,30,0,0
-0.2354400,51.3451900,1,30,0,0
0.1680300,51.0614700,1,40,0,0
If anyone can help I'd be extremely grateful and will be paying for the full DB straight away.
Thanks in advance.
PostPosted: Tue Aug 25, 2009 2:40 pm    Post subject: Reply with quote
I haven't seen one that looks exactly the same as that, usually there is either a single file with all the cameras in, in something like this format
Code:
;Longitude,Latitude,Name
-2.17787,50.68305,"GATSO:1@40"
-2.09933,50.70723,"GATSO:2@30"
-2.08935,53.5027,"GATSO:3@20"
or they are split out into several files, one for each speed and camera type, like this
Code:
-2.08935,53.50271,"GATSO:3@20"
-0.13769,51.32807,"GATSO:364@20"
-0.05071,51.453,"GATSO:562@20"
and:
Code:
-2.48385,52.69615,"GATSO:12@30"
-2.07761,53.5114,"GATSO:13@30"
The above is the "Garmin POI Loader" .csv version, but there are many other text-types that are similar but with slight differences to the layout. For example I've just noticed there is no "heading" info in that version. I'll just have a hunt for one of the ones that does....
I suppose what I'm trying to say is that *if* there isn't one ready-made to suit your needs, it shouldn't be too difficult to cut and paste one up from something else in Excel or similar to give you the correct columns, which you could then save out as text.
PostPosted: Tue Aug 25, 2009 2:44 pm    Post subject: Reply with quote
Ignore all the above waffle!
Here's the "iGo" format download:
Code:
X,Y,Type,Speed,DirType,Direction
-2.17787,50.68305,1,40,1,268
-2.09933,50.70723,1,30,1,37
-2.08935,53.5027,1,20,1,239
How does that look? Smile
Antitheft2
PostPosted: Tue Aug 25, 2009 2:53 pm    Post subject: Reply with quote
Code:
That looks pretty much spot on! Smile
I'd heard that the Alpine system was based on the Igo but hadn't been able to confirm it.
Massive thanks for that, am now off to purchase my membership and get my cameras up to date at last.
Thanks again Smile
Antitheft2
PostPosted: Tue Aug 25, 2009 3:30 pm    Post subject: Reply with quote
Membership bought and iGo DB downloaded.
Can confirm this worked first time with no modifications perfectly on the Alpine PMD-B200P have confirmed this by checking multiple locations on the maps where I know cameras are located or used and every single one now shows up correctly (even the mobile ones).
Huge thanks for your help. You may want to arrange for that unit to be listed as compatible with the iGo database, I can provide installation instructions if needed.
One happy customer Smile
PostPosted: Tue Aug 25, 2009 3:39 pm    Post subject: Reply with quote
Not something I can do personally, but I'm sure the admin will be interested to know!
Glad it all worked out fine! Smile
PostPosted: Thu Aug 27, 2009 4:57 pm    Post subject: Reply with quote
can you let me know if any of these are what you did: http://www.pocketgpsworld.com/uksafetycameras-igo-myguide-oncourse_navigator.php
thanks
Antitheft2
PostPosted: Thu Aug 27, 2009 5:27 pm    Post subject: Reply with quote
Forgive me for posting a link to something on one of your rival's sites but it's the easiest way to show the exact process as it's written for the Alpine device in question.
I simply deleted the original files and copied the files from the iGO download I bought from you over to the location mentioned in this and reset the device and it worked perfectly.
CLICK HERE
Please remove the link once you've viewed it if you aren't happy for it to be there, I'm simply posting it for pure convenience to save writing it all out.
Cheers Smile
PostPosted: Thu Aug 27, 2009 6:36 pm    Post subject: Reply with quote
tried that link earlier (you sent it via support ticket) but still can't view it...
PaulB2005
PostPosted: Thu Aug 27, 2009 6:38 pm    Post subject: Reply with quote
Can't seem to access http://www.scdb.info either.... Suggests website is down...
Antitheft2
PostPosted: Thu Aug 27, 2009 6:40 pm    Post subject: Reply with quote
Heh, at least I know the support ticket got through ;) the site was working fine when I posted it, looks like that site is having "issues" at the moment.
Go to their main site (if you can get it to open, seems intermittent at best today). Click on Alpine on the left and then choose "Blackbird 2", the link to the installation instructions is at the bottom.
AliOnHols
PostPosted: Thu Aug 27, 2009 6:44 pm    Post subject: Reply with quote
I can confirm that the link as provided by Antitheft2 worked when it was originally posted.
Garmin Nuvi 2599
SatMap Active 10 & 20.
Antitheft2
PostPosted: Thu Aug 27, 2009 6:47 pm    Post subject: Reply with quote
Heh, at least I know I'm not going insane. Thanks for that Smile
PostPosted: Thu Aug 27, 2009 8:29 pm    Post subject: Reply with quote
2 of us have replied to the ticket today... did you receive either?!
Antitheft2
PostPosted: Thu Aug 27, 2009 8:32 pm    Post subject: Reply with quote
I've had no email notifications at all other than the forum topic replies because I subscribed to the thread.
24.041 (01 Apr 26)
