| Author |
g0tch Regular Visitor
Joined: May 15, 2008 Posts: 115 Location: North Somerset
Posted: Sat Dec 05, 2009 12:13 pm Post subject: There is not enough free space |
Yesterday I tried to download the latest map I was offered and it came up with the error:
"There is not enough free space on your device to add the item. You need to remove: 4.3Mb."
I did try to search the forum for the above – honest – but not been able to find any posts on it.
Can anyone tell me what I need to delete to be able to complete the download? I have of coarse have a backup via explorer.
Many thanks, _________________ Tibor
Garmin Drivesmart 61 |
| Back to top |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Sat Dec 05, 2009 12:26 pm Post subject: |
When you searched, did you select the "Search for all terms" option?
Have a look at this response from mikealder to a similar question. _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
| Back to top |
Posted: Sat Dec 05, 2009 1:18 pm Post subject: |
| JockTamsonsBairn wrote: | When you searched, did you select the "Search for all terms" option?
Have a look at this response from mikealder to a similar question. |
Many thanks for your response. I must admit I didn’t select "Search for all terms" option.
Looked at the tread you referred to but it seem to my 70 yr old head that it deals with memory card that I don’t have. May be to get my head around it I need some exact answer.
Thanks, _________________ Tibor
| Back to top |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Sat Dec 05, 2009 2:23 pm Post subject: |
Hi g0tch
I began to get short of room on my 720 and overcame the problem by buying a 4Gb memory card. It only cost a few quid from Amazon and it solved the problem immediately both for now and for the immediate future.
After inserting the card and running ‘Home’ it will ask you to select your navigation device, either Internal Memory or Memory Card. Chose Memory Card and then ‘Update My Go’. It should then go just fine with plenty of room on the Memory Card.
PS. I’m older than you. _________________ Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G |
| Back to top |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Sat Dec 05, 2009 2:31 pm Post subject: |
You would probably find it more helpful to get a memory card for your GO730T - as you see, below, I have. They are very cheap at the moment - I have just bought a Kingston 4Gb SDHC card for less than £6.
There are explicit instructions here for installing the card.
Oh! Trevor's beat me to it. AND btw I'm much older than you  _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
| Back to top |
Posted: Sat Dec 05, 2009 3:52 pm Post subject: |
Many thanks to all. Looks like I will be getting a 4Gb memory card then. Any suggestion as to where to find the fastest supplier? _________________ Tibor
| Back to top |
Posted: Sat Dec 05, 2009 4:56 pm Post subject: |
| g0tch wrote: | | Many thanks to all. Looks like I will be getting a 4Gb memory card then. Any suggestion as to where to find the fastest supplier? |
There are lots of places - just search for a 4Gb SDHC card or see HERE - I'm afraid it is a little more expensive that what I paid for it about two weeks ago - it was on special offer with an item of photography that I bought, but it is still relatively inexpensive.
I expect others will offer other places.
Graham _________________ Gee-Pee
| Back to top |
Posted: Sat Dec 05, 2009 5:04 pm Post subject: |
Funny you should point me to that site. Been there earlier and ordered one.
Many thanks for all replies
Regards, _________________ Tibor
| Back to top |
pottsy Regular Visitor
Joined: Jul 27, 2004 Posts: 86 Location: Midlands, UK
Posted: Sun Dec 06, 2009 4:01 pm Post subject: |
In fact the problem is that the Tomtom server does not recognise that the device is a UK device, so it generates a map for download that includes lots of unnecessary localisation files.
The solution is to:
Back up (obv). I took a separate backup (folder copy) of the 3 folders LoquendoTTS, voices and zip.
Format the internal memory.
Use home to install the map. Then close home and remove all the localised files from the map. They are obvious - all the same bar the endings (IT, ES and so on). Leave the GBR ones on though!
Restore the 3 folders.
Then use home to install the OS and anything else missing.
Worked for me on a 2GB 750 Live. |
| Back to top |
Posted: Sat Dec 12, 2009 9:00 pm Post subject: |
Thanks for all the replies. Today my 4Gb card arrived. Put in the device, started TT, selected the card and I had the same error. Might be a dodgy download, I thought. Deleted the last download then spent 4hrs to download it again, at the end of which I had the same error again. Below is all I see when I opened “show error”
ERROR: There is not enough free space on your device to add the item. You need to remove: 4.3 Mb
Stack:
0. chrome://tthome/content/ui/bindings/commit.js:82
error(textOrException);
1. chrome://tthome/content/ui/bindings/ttwizard.xml:1058
this._commitFailed(i, commitPage);
2. chrome://tthome/content/logic/util.js:79
return func.apply(obj, arguments);
3. chrome://tthome/content/logic/model/ttNavItem.js:924
errorCallback(errorStrOut.value);
4. chrome://tthome/content/ui/subtask/installSelectSome/installSelectSome.js:740
errorCallback);
5. chrome://tthome/content/logic/util.js:79
6. function _startCommitFunction chrome://tthome/content/ui/bindings/ttwizard.xml:1054
7. chrome://tthome/content/ui/bindings/ttwizard.xml:1042
8. chrome://tthome/content/logic/util.js:79
9. chrome://tthome/content/ui/subtask/installSelectSome/installSelectSome.js:683
"downloadedItems", [item.name], 1));
10. chrome://tthome/content/logic/util.js:79
11. chrome://tthome/content/logic/model/ttNavItem.js:706
aSuccessCallback(result);
Time: Sat, 12 Dec 2009 16:56:10 GMT _________________ Tibor
| Back to top |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Sat Dec 12, 2009 10:09 pm Post subject: |
You may want to try a map install without using Home. A method to do so can be found here _________________ David |
| Back to top |
Posted: Sat Dec 12, 2009 10:32 pm Post subject: |
| dhn wrote: | | You may want to try a map install without using Home. A method to do so can be found here |
Many thanks, will try that monday. A busy day tomorrow.  _________________ Tibor
| Back to top |
| Back to top |
