| Author |
beeney Occasional Visitor
Posted: Tue Aug 18, 2009 4:02 pm Post subject: speed camera icons and voice camera alerts |
| hi could u tell me if these will work on a navman icn 520 pls |
| Back to top |
GerryC Pocket GPS Moderator
Posted: Tue Aug 18, 2009 4:12 pm Post subject: |
Hi beeney, welcome to the forum.
By all means give it a go. On the previous page, it's noted that the 24x24 icons work on a Navman device - don't know if it would work on yours though.
You may also want to check out the Navman forum where I've just seen info regarding using wav files (see the Navman download instructions). _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
| Back to top |
Posted: Tue Aug 18, 2009 5:20 pm Post subject: |
| Don't forget that Navman use 8 Bit colour depth so loading the alternate sets which are 24 Bit might not work unless you alter this prior to installing - Mike |
| Back to top |
Darren Frequent Visitor
Posted: Sun Dec 13, 2009 8:33 pm Post subject: Re: icons |
| browny99 wrote: | | hi guys, Newbie here!!! i think i have read all this forum on changing the icons, but i cant seem to find a page that tells me a step by step guide to install them on my new go 750. |
The installation is the same for all TomTom's but it does require you use our speed camera database.
| Quote: | | maybe im asking to much since i used to own a snooper syrius, which is the best for speed cameras |
<cough> I'll beg to differ there, OUR database is superior to Snooper's. They may have a decent device but our data is better.
| Quote: | | So i need help on how to put yr icons on my 750, also want to check out the sound but, we can do that another dayall help appreciated, thanx. |
As per the icons, our real voice alerts are also available but again will require that you use our speedcam database service. _________________ Darren Griffin |
| Back to top |
Posted: Sun Dec 13, 2009 9:20 pm Post subject: |
| Keep your eyes peeled for the mobile speed camera locations then as the TomTom offering is fairly pathetic in this area, the database from this site will notify you of locations known to be frequented by the mobile cameras. I consider a warning of such a location far better even if there is nothing there at the time you pass - with the TT you are lucky to see anything at all to do with mobile locations - drive carefully for the next three months is my advice - Mike |
| Back to top |
Posted: Sun Dec 13, 2009 9:40 pm Post subject: Re: icons |
| browny99 wrote: | | so i cant install the icons alone, unless i pay for the database? |
You can install the icons we offer but they are designed for our database and as TomTom don't permit the icons for their database to be changed, installing the ones we supply would be pointless. _________________ Darren Griffin |
| Back to top |
Posted: Mon Dec 14, 2009 6:31 pm Post subject: |
Your TomTom will have been supplied with Navcore 9 software installed but it won't alter the speed camera warnings.
If you change to the offering from this site you can use the spoken voice alerts so approaching a camera the device will say something like "Warning Gatso ahead, speed limit 30 miles per hour" so it tells you the type of camera and the rated speed prior to you getting a pre set distance from the camera - Some of the voice warnings even have siren sounds followed by the spoken alert - Mike |
| Back to top |
Barncluith Regular Visitor
Joined: Jun 17, 2005 Posts: 67 Location: Hamilton, UK
Posted: Fri Jan 08, 2010 7:46 pm Post subject: |
The 44x an 48x don't work on the Garmin Nuvi 205W  |
| Back to top |
Posted: Fri Jan 08, 2010 7:59 pm Post subject: |
| There is a table of applicability near the top of the extra icon downloads page which explains which models support the use of these icon, AFAIK Garmin don't support any of the larger format icons on any device - Mike |
| Back to top |
transplant Lifetime Member
Posted: Sun May 09, 2010 8:14 am Post subject: Garmin nuvi 255WT |
Hi guys,
Just uploaded the 24x24 speed rated icons to the Garmin nuvi 255WT - works perfectly so you can update your database on this one. (Currently running software version 6.40 and audio version 2.30 with map CN Europe NT 2010.30)
Cheers (Great website by the way!) |
| Back to top |
TheQuest Regular Visitor
Joined: Aug 15, 2010 Posts: 81 Location: Kent. UK by the sea
Posted: Sat Aug 21, 2010 1:49 am Post subject: Where do I put........... |
Hi all
Could someone please help me with where to put GerryC's Safety Camera Icons on my Garmin nuvi 1490T please?
I have downloaded the Speed Camera Database and Voice files [mp3 to wav] and loaded to a SD Card with POI Loader, drive tested and it worked it's magic.
Now I would like to install GerryC's Safety Camera Icons, but do not know where they go, because it says to put them in the map folded which I have no idea where it is on my device.
Thank in advance for any replies.
Take Care
TheQuest  _________________ When Nothing is Certain, Anything is Possible. |
| Back to top |
Posted: Sat Aug 21, 2010 10:29 am Post subject: |
With the Garmins you have to replace the icons from the speed camera download before uploading them to the unit with POILoader. You don't move or copy anything to the unit yourself.
Just unzip the speed camera download and then copy the new icons over the original ones. Then upload with POILoader. |
| Back to top |
Posted: Sat Aug 21, 2010 9:26 pm Post subject: |
Hi PaulB2005
Thank you very much for you reply.
Will do as you explained now, and give the 1490T a simulated test run.
With many regards
Take Care
TheQuest
PS: Just to update PaulB2005, that it worked as said, many thanks once again.  _________________ When Nothing is Certain, Anything is Possible. |
| Back to top |
maa1506 Occasional Visitor
Posted: Sun Jul 29, 2012 7:30 am Post subject: Primo? |
| Is there a custom camera icon for Igo Primo at all please and where does it need to be installed? |
| Back to top |
M8TJT The Other Tired Old Man
Posted: Sun Jul 29, 2012 9:49 am Post subject: |
| It ain't that easy. The camera icons are in the data.zip/gfx folder and are in the file speedwarn.bmp. They are in a special iGO .bmp format for which you need an iGO decompressor. The icons are not single icons, but are in a strip of all warnings and the speedwarn.spr file tells iGO how to process these icons. Alternative speedwarn icons can be obtained from several places on the web if you google for them. Good luck! |
| Back to top |
| Back to top |
