| Author |
lbendlin Pocket GPS Staff
Posted: Sun Mar 25, 2007 3:20 pm Post subject: Globalsat DG-100 USB Datalogger review |
The GlobalSat DG-100 USB data logger is a strange bird. Looking rather square-ish it will certainly not win any prices for good looks, although the overall design is not too shabby either.
So, let's look for something else that differentiates this device from the other data loggers on the market.
Read the review here:
http://www.pocketgpsworld.com/globalsat-DG-100-gps-review.php _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
| Back to top |
Mehanik Occasional Visitor
Joined: Jun 09, 2004 Posts: 26 Location: Moscow, Russia
Posted: Mon Mar 26, 2007 4:27 pm Post subject: |
Hi lbendlin.
Why you say about CP230x driver, but later use COM5 with common Prolific CP210x USB-to-Serial converter??? _________________ Mikhail E. Veselov
http://www.globalsat.su
GlobalSat Russia |
| Back to top |
uffe73 Frequent Visitor
Posted: Tue Mar 27, 2007 7:32 am Post subject: Re: Globalsat DG-100 USB Datalogger review |
| lbendlin wrote: | One thing I did not understand is how tracks are separated. One theory is that if the logger loses and regains a fix then a new track is started. I don't think I like that approach - I would want to be able to start a new track by power cycling the device (like it is done on the Wintec WBT-100). But for now you can end up with multiple tracks per journey, and true to Murphy only one track at a time can be exported to Google Earth.
I completely agree that the file handling in the DG-100 is a bit strange. But your "Murphy conclusion" is not correct. You can actually merge any number of tracks into one output file. However this might require quite some clicking in the track list to select the correct ones. The PC application should include the ability to filter based on time, not only speed. Hopefully future versions of the PC application will include this. |
| Back to top |
Posted: Wed Mar 28, 2007 3:14 am Post subject: |
| Mehanik wrote: | Hi lbendlin.
Why you say about CP230x driver, but later use COM5 with common Prolific CP210x USB-to-Serial converter??? |
Read it again - I use "COM5 with a Prolific converter". It does _not_ state Prolific 210x converter. Just Prolific. The device manager doesn't show the 230x in this view. _________________ Lutz
| Back to top |
Posted: Wed Mar 28, 2007 2:41 pm Post subject: 2 lbendlin |
Sorry for inattention...  _________________ Mikhail E. Veselov
GlobalSat Russia |
| Back to top |
eugn Occasional Visitor
Posted: Sat Apr 07, 2007 3:33 pm Post subject: |
| could you possible post the kml-files, so that i can download them to see how accurate they are, since i had some problems with the sensitivtiy with a different divice i bought as datalogger |
| Back to top |
Posted: Tue Apr 10, 2007 3:35 am Post subject: |
sorry, not possible. However, I would say the receiver is somewhere in the middle SiRF III range. I did see a few spikes, but nothing systemic. The position itself was accurate enough (have a look at the DOP values) _________________ Lutz
| Back to top |
fosheezy05 Occasional Visitor
Posted: Sat Jun 23, 2007 10:17 pm Post subject: |
| I just bought a DG-100 last week from Semsons, and I did not have any problems with logging and mode switching. I was able to continue logging between all three modes during a trip from Los Angeles to San Diego. |
| Back to top |
flatsheep Occasional Visitor
Posted: Mon Jul 09, 2007 10:10 pm Post subject: .NET API to access the DG-100 data logger |
I have created an API using .NET for the DG-100 data logger. It allows you to create an application and access the data on the device.
I've made some executive decisions on parts of the way the data is handled (addressing some of your issues in this thread). I don't differentiate between the different headers the device returns. I just return a long list of all the points in the device in chronilogical order. Your software can use logic to seperate the different tracks, etc.
You can monitor and download the API at http://dg100gpslogger.spaces.live.com/
Hopefully people will start to develop more applications using this software.
Regards
Flatsheep |
| Back to top |
kiwibird2 Occasional Visitor
Posted: Tue May 04, 2010 2:26 am Post subject: updates on this device |
are there any updates on this device since 2007.
From the review it seems some buggy locations recorded,
changing the settings a/b/c wouldnt work till power cycle done.
unit cant be permanently wired as it wont work when being charged,
What other devices come recommend?
I am after two kinds of gps.
One with logging and no gsm sim card. (hard wired in car)
and one with gsm sim card (hard wired in car) |
| Back to top |
Posted: Thu May 06, 2010 2:16 am Post subject: |
Did you check out the Columbus V900? _________________ Lutz
| Back to top |
Posted: Thu May 06, 2010 2:43 am Post subject: more info |
thanks for the reply.
the Columbus V900 is not available in australia.
Any other recommend device, also for a gps that has a sim card.
Does anyone know what sort of data usage gps trackers will use if in data mode (not sms mode)
From what I can see the current consumption is much higher in this mode.
It may be cheaper to run, depending on your sim provider. |
| Back to top |
Darren Frequent Visitor
Posted: Thu May 06, 2010 7:53 am Post subject: Re: more info |
| kiwibird2 wrote: | thanks for the reply.
the Columbus V900 is not available in australia. |
It wasn't available here in the UK either but it was sufficiently good that many of us bought from the US. And it is a superb datalogger, possibly the best of its kind. _________________ Darren Griffin |
| Back to top |
| Back to top |
