| Author |
Redsfotografie Occasional Visitor
Posted: Sat Apr 17, 2010 11:17 pm Post subject: IGO 8 how to show speedlimit always? |
Hi all,
I'm looking for an option to show the speed limit on the display at all times like when your speeding but I want the sign to be there all the time!
Skins do not work I tried the plus and ultra version but it chrashes on it
Please help me! |
| Back to top |
acres10 Occasional Visitor
Posted: Mon Apr 26, 2010 9:16 pm Post subject: speed limit |
hi
i have speed limit always on , i assumed you tried settings/map visual/more and check the box show speed limit?
works great keeps you from getting points on your driving licence
| Back to top |
mxmaciek Lifetime Member
Joined: Jun 20, 2007 Posts: 117 Location: UK, Nottingham
Posted: Mon May 10, 2010 9:26 pm Post subject: |
another way to keep it alive without the skin:
edit the BOTH (on the storage card\igo8\ AND my device\program files\igo8\ floes sys.txt, by adding:
[config]
overspeedrewarnbelow = 1
That should trigger the warning always on. |
| Back to top |
mojo-chan Occasional Visitor
Posted: Sat Jun 09, 2012 10:56 am Post subject: |
Sorry for the thread necro but I have the same problem and the instructions do not work.
It looks like there needs to be a mod to the skin. I tried editing the skin but was unable to make the speed limit display visible all the time. It sounds like the latest version of the Ultra skin or the "iGo Plus" skin can do it, but I can't find them for download anywhere now.
Can anyone help with this? |
| Back to top |
Posted: Sat Jun 09, 2012 11:02 am Post subject: |
| use Google, search for kikker 3.2 skin... |
| Back to top |
M8TJT The Other Tired Old Man
Posted: Sat Jun 09, 2012 1:51 pm Post subject: |
| mojo-chan wrote: | | It looks like there needs to be a mod to the skin. I tried editing the skin but was unable to make the speed limit display visible all the time. | Several skins do what you want. Which one are you using at the moment? DiMka skins do what you want try here |
| Back to top |
Posted: Sat Jun 09, 2012 10:55 pm Post subject: |
| M8TJT wrote: | | mojo-chan wrote: | | It looks like there needs to be a mod to the skin. I tried editing the skin but was unable to make the speed limit display visible all the time. | Several skins do what you want. Which one are you using at the moment? DiMka skins do what you want try here |
I am using the stock skin. Really I just want to add the speed limit display to that. Amigo does it but I prefer iGo 8.
I'll take a look at the skin you mentioned. It looks quite different to the stock one. Perhaps it will give me a hint so I can get the display to be on permanently in the default skin. |
| Back to top |
Posted: Sat Jun 09, 2012 11:21 pm Post subject: |
I'll have a look at the stock skin later to see what I can find.
Edit;
Right. I've had a look and can't see why it doesn't show all the time. Can you tell me what exactly happens and the circumstances under which it does it. Does it just show when you are near/over the current speed limit. If so, I think that I have a fix. |
| Back to top |
Posted: Sun Jun 10, 2012 2:51 pm Post subject: |
| Kikker is just clone of Ultra skin which is compatible with 8.3.x |
| Back to top |
Posted: Sun Jun 10, 2012 3:26 pm Post subject: |
M8TJT: It shows only when exceeding the speed limit. I guess you have found the visiblemodel field that seems to suggest it only shows when you are near the speed limit, but I tried changing it to various things and none of the made it display permanently.
My guess is that there is a script somewhere that controls its visibility, overriding that setting.
mxmaciek: Thanks, I will try it. It looks like the speed limit display is a major modification so porting it back to the default skin won't be easy. |
| Back to top |
Posted: Sun Jun 10, 2012 8:36 pm Post subject: |
Just to be specific.
On same roads there is NO SPEED assigned, and you'll never see it.
I have no idea how it looks on native skin, as I always used Ultra or kikker, but on some roads, even with kikker - I have options:
overspeed warning -advanced - urban areas 110%, rural 110%, sound warning - disabled, visual warning - when speeding.
After that, on most of the roads, when I'm approaching the speed limit, iGo displays blue circle with max allowed speed value inside. While I'm above 110% - the circle changes colour to red.
But - there are some roads, on which there is no warning or mistake value. I think that it depends on map. I do not remember exactly, but some time around one year ago I saw on M1 between J25 and 26 allowed speed value of 112 mph.
First, it is obvious mistake of calculation (70 mph = 112kph), second, the error gone with the map update.
Concluding, you should NOT expect info on ALL of the roads, but you SHOULD be prepared for possible mistakes
About the kikker: be careful, as the skin is designed for some screen resolutions, while on others it will not work. To have it working in "HD" (not just scaled up) 800x480 HTC HD2, I had to manually modify the sys.txt, after what some elements (like automatic weather changer for backgrounds in different seasons and day-night 6 steps sequence via themechanger) stopped working correctly.
But still - I think that this is simplest and very nice skin. |
| Back to top |
Posted: Sun Jun 10, 2012 9:56 pm Post subject: |
| mojo-chan wrote: | | I guess you have found the visiblemodel field that seems to suggest it only shows when you are near the speed limit, but I tried changing it to various things and none of the made it display permanently. | Yes, that's the one, in navigatemapxxxx.ui (where xxxx is your resolution). I assume that you are changing it in the correct resolution for your device? (Sorry if I insult your skills). I'll have a play tomorrow, but I'm certain that if you get rid of the visiblemode statement it 'should' work. Just as an experiment, put the ! (NOT) operator in front of the variable i.e. visiblemode=!nearspeedlimit (or whatever, I can't remember the exact system variable name). This should make it appear when below the speed limit but go away above it. At least that will prove that it's the visiblemode statement that's affecting it (or not).
You seem to have inadvertently set me a challenge. Watch this space ;=) |
| Back to top |
Posted: Sun Jun 10, 2012 10:12 pm Post subject: |
| M8TJT wrote: | | mojo-chan wrote: | | I guess you have found the visiblemodel field that seems to suggest it only shows when you are near the speed limit, but I tried changing it to various things and none of the made it display permanently. | Yes, that's the one, in navigatemapxxxx.ui (where xxxx is your resolution). I assume that you are changing it in the correct resolution for your device? (Sorry if I insult your skills). I'll have a play tomorrow, but I'm certain that if you get rid of the visiblemode statement it 'should' work. Just as an experiment, put the ! (NOT) operator in front of the variable i.e. visiblemode=!nearspeedlimit (or whatever, I can't remember the exact system variable name). This should make it appear when below the speed limit but go away above it. At least that will prove that it's the visiblemode statement that's affecting it (or not).
Yes, I got the right resolution :-)
If I put the ! in or just remove the whole visiblemode bit I get a parse error when starting iGo.
It doesn't seem to matter what I set it to, the visiblemode bit here does not actually appear to control its visibility directly.
mxmaciek: My maps have the correct speed limits on the roads I am using to test. I know because the warning pops up if I exceed the speed limit by 1MPH. The reason your speed display is wrong is because you are using European maps. A friend of mine noticed that if you let the GPS lock on before opening iGo it seems to fix this issue some times. |
| Back to top |
Posted: Mon Jun 11, 2012 12:23 am Post subject: |
My data.zip has bits about USA in it. It is not the laver that is 'visiblemoded' but the icon and text. So my mod above is th the speedlimit text
If I change
visiblemodel="navigation.near_speed_limit"
to
visiblemodel="!navigation.near_speed_limit"
the speed limit text is present all the time that I am below the speed limit (In sim mode) so it 'should' work the same on the speed limit layer. Are you putting the ! inside the "". If you don't, it produces the parse error on mine |
| Back to top |
Posted: Mon Jun 11, 2012 6:28 pm Post subject: |
Cracked it :-)
The parse error was due to the ZIP file. For some reason if I extract everything and make a new ZIP file it never works, so I am just updating that one file in a copy of the existing data.zip. If I do it with 7zip I get the parse error. If I do it with Directory Opus it works, but only the first time and every time after I have to start from the original data.zip again.
Anyway, to display the speed limit all the time set visiblemodel to:
| Code: |
"navigation.near_speed_limit|!navigation.near_speed_limit"
Other values might work, like "1" or something, I have not tried. |
| Back to top |
| Back to top |
