Pocket GPS World :: View topic - A solution for TTS pronunciation for Go models (Loquendo)
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 15, 16, 17  Next
MARViN2003
PostPosted: Thu Jun 10, 2010 7:12 pm    Post subject: Reply with quote
Well it's the [^0-9]? that is being replaced by the character and being read out.
I made rules for the specific number of digits, so I have 4 digit rules and 3 digit rules, anything else is just handled as it originally was.
Code:
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])([1-9])([1-9])([1-9])" = "\1 \s \2 \3_ \4_ \5_ \6_"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])0([1-9])([1-9])" = "\1 \s \2 \3_ oh \4_ \5_"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])([1-9])0([1-9])" = "\1 \s \2 \3_ \4_ oh \5_"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])([1-9])([1-9])0" = "\1 \s \2 \3_ \4_ \5_ oh"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])0([1-9])0" = "\1 \s \2 \3_ oh \4_ oh"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])([1-9])00" = "\1 \s \2 \3_ \4_ double oh"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])00([1-9])" = "\1 \s \2 \3_ double oh \4_"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])000" = "\1 \s \2 \3_ thousand"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])([1-9])([1-9])" = "\1 \s \2 \3_ \4_ \5_"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])0([1-9])= "\1 \s \2 \3_ oh \4_"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])([1-9])0" = "\1 \s \2 \3_ \4_ oh"
"(^|[ \t]+)(M|A|B)[ \-]*([1-9])00" = "\1 \s \2 \3_ hundred"
I'll update the zip file
http://www.darklight.info/downloads/Loq7fix.zip
notones
PostPosted: Fri Jun 11, 2010 4:14 pm    Post subject: Reply with quote
Hi thanks for all your work on this, had a few probs geting it working due to 2 sets of files 1 set on SD and 1 on internal, - removed SD files and it works great now.
MARViN2003
PostPosted: Fri Jun 11, 2010 10:34 pm    Post subject: Reply with quote
As there are no 4 digit Motorway numbers, the for digit rules don't need the M in there...
Code:
"(^|[ \t]+)(A|B)[ \-]*([1-9])([1-9])([1-9])([1-9])" = "\1 \s \2 \3_ \4_ \5_ \6_"
"(^|[ \t]+)(A|B)[ \-]*([1-9])0([1-9])([1-9])" = "\1 \s \2 \3_ oh \4_ \5_"
"(^|[ \t]+)(A|B)[ \-]*([1-9])([1-9])0([1-9])" = "\1 \s \2 \3_ \4_ oh \5_"
"(^|[ \t]+)(A|B)[ \-]*([1-9])([1-9])([1-9])0" = "\1 \s \2 \3_ \4_ \5_ oh"
"(^|[ \t]+)(A|B)[ \-]*([1-9])0([1-9])0" = "\1 \s \2 \3_ oh \4_ oh"
"(^|[ \t]+)(A|B)[ \-]*([1-9])([1-9])00" = "\1 \s \2 \3_ \4_ double oh"
"(^|[ \t]+)(A|B)[ \-]*([1-9])00([1-9])" = "\1 \s \2 \3_ double oh \4_"
"(^|[ \t]+)(A|B)[ \-]*([1-9])000" = "\1 \s \2 \3_ thousand"
MARViN2003
PostPosted: Wed Jun 16, 2010 11:38 am    Post subject: Reply with quote
I've been testing this with a few longish journeys, and haven't had any 'comma' or 'semi-colon' problems.
Has anyone else been testing my rules? I'd be interested in any feedback...
SpikeyMikey
PostPosted: Wed Jun 16, 2010 3:03 pm    Post subject: Reply with quote
Hi, thanks for everybodys hard work on this.
I've downloaded the latest zip files and still get commas and dots being read out, have I missed something?
Mike
MARViN2003
PostPosted: Thu Jun 17, 2010 9:31 am    Post subject: Reply with quote
Hmm,
I wonder if it's because I am on Navcore 9?
I don't get commas or dots read out...
Do you have your tomtom set to read out incoming text messages?
Maybe it's something with it loading up the SMS lex files...
theripper
PostPosted: Thu Jun 17, 2010 5:44 pm    Post subject: Reply with quote
MARViN2003 wrote:
Hmm,
I think there is a voice setting to read out names and numbers, perhaps you have yours set differently!
MARViN2003
PostPosted: Thu Jun 17, 2010 10:21 pm    Post subject: Reply with quote
I have mine set to read road names and numbers, but not foreign road names. I aslo have the read signpost option ticked.
notones
PostPosted: Fri Jun 18, 2010 9:04 pm    Post subject: Reply with quote
Hi i get commas and dots, using latest app from tt update v8.351
Western_and_central_Europe_2GB v845.2645 again from tt update
- have tried turning all options on/off and still get comma and dot.
i can make a route on google maps if that will help?
MARViN2003 wrote:
Hmm,
notones
PostPosted: Fri Jun 18, 2010 10:12 pm    Post subject: Dot and comma routes Reply with quote
Dot Route! [B3197 onto A379] or any road onto A379
http://maps.google.com/?ie=UTF8&t=h&hl=en&saddr=50.28766,-3.81401&daddr=50.30549,-3.83639&f=q&om=1
Comma Route! [A3022 onto A380] or any road onto A380
http://maps.google.com/?ie=UTF8&t=h&hl=en&saddr=50.48798,-3.57046&daddr=50.48543,-3.57205&f=q&om=1
Hope this helps
SpikeyMikey
PostPosted: Sat Jun 19, 2010 9:11 am    Post subject: Reply with quote
Hi Marvin2003, sorry for delayed reply I wanted to see if there was a pattern to the comma / dot problem, it seems that it's OK for two digit roads eg A41, but they appear after three or four digit roads eg A416 & A4009.
Hope that helps
Mike
MARViN2003
PostPosted: Mon Jun 21, 2010 11:47 am    Post subject: Reply with quote
I've tried both those routes and don't get any comma or dots Sad
I'll grab my tomotm later and list all the settings I have...
SpikeyMikey
PostPosted: Mon Jun 21, 2010 12:46 pm    Post subject: Reply with quote
Thanks.
I now realise that I should have said that it appears to only be a problem if the road number is followed by a name.
Sorry if I've put you to needless trouble.
Mike
notones
PostPosted: Mon Jun 21, 2010 4:59 pm    Post subject: Reply with quote
Hi Spikey, were both using same map, but slightly diff versions of app, neither of us on v9 as marvin , i get dots and comma's on both numbers with or without names, but not all. even some 3 and 4 digit roads are fine, there doesnt seem to be any set pattern, also sometimes just going over a roundabout on the same road will at some roundabouts give dot and others give commas, im getting used to it as its still far better than the defaults.
SpikeyMikey wrote:
Thanks.
MARViN2003
PostPosted: Sun Jun 27, 2010 3:30 pm    Post subject: Reply with quote
Hi all,
Unfortunateley, I've fried the mini usb socket on my go 520, so I can't access the files anymore (does anyone know a way to copy the files from internal disk to the sd card from the tomtom os? - brfore the charge goes completely...)
I've ordered a recon 930 from tomtom, so I'll continue my experimenting when I get that.
Page 6 of 17
24.041 (01 Apr 26)
