| Author |
Darren Frequent Visitor
Posted: Wed Jun 23, 2010 8:34 am Post subject: CamerAlert v1.1 now available |
We have updated our iPhone Speed Camera app, CamerAlert, to provide compatibility for devices running iOS4.
The CamerAlert 1.1 release has been tested with the latest iOS4 iPhone software but does not implement multitasking yet. We thought it more important to get an update out that permitted the app to function fully under iOS4 as a priority and will now work to enable full multitasking support as our next priority.
There are a number of major features added in this update including camera management, and a Heads Up Display (HUD. There are also a number of bug fixes.
This release introduces new functionality for the management of camera reports. It is no longer required to have an active data connection to report cameras, reports are collected and will be sent next time you have an internet connection. This means that CamerAlert will now work 100% without wireless data. Of course if you do not have a data connection you will not be able to display maps.
There is also now a new HUD style display where all the data is mirrored allowing you to lay the iPhone flat on the dash and see a projection on the windscreen.
Also added is a slightly more prominent reminder that a new database is available, displayed in the list mode.
Finally, numerous bug fixes to improve the stability and performance of the application have been included. _________________ Darren Griffin |
| Back to top |
mtb_monster Occasional Visitor
Posted: Wed Jun 23, 2010 11:41 pm Post subject: CamerAlert app for Apple iPhone |
| Update went smoothly. Looking forward to multi tasking and what this may offer. Will check out the HUD tomorrow. |
| Back to top |
HL7222 Occasional Visitor
Posted: Thu Jun 24, 2010 11:39 am Post subject: |
Not working at all on my 3G model with IOS4.
Fails to get any GPS fix at all
Have tried rebooting phone, no change
Help please! |
| Back to top |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15506 Location: Bradford, West Yorkshire
Posted: Thu Jun 24, 2010 1:17 pm Post subject: |
| HL7222 wrote: | Hi
Help please! |
do you have location services turned on? have you allowed access for the app to use 'my location'?
check in settings / general / location services
also, are you driving at the time you load the app? if you are driving fast it will struggle to get a gps fix on the 3G.
also, if you close cameralert and load up 'maps' does that work ok?
MaFt |
| Back to top |
Posted: Thu Jun 24, 2010 1:32 pm Post subject: |
| MaFt, I cant even install the new version as it just sits there saying waiting and has been like this for about an hour - Mike |
| Back to top |
Posted: Thu Jun 24, 2010 2:58 pm Post subject: |
| MaFt wrote: |
MaFt |
I have location services on. Have turned off and back on, also.
When I start Cameralert I get a zoomed out map of UK centred on Manchester (at a guess).
If I press locate button, after 5 or 10 secs it finds me. I can then pinch zoom in, and slowly it will draw the maps near where I am.
However at no point will the camera icon go from red to blue.
(I am trying all of this sitting in the garden btw)
If I drive off the pin point stays put... If I then click the locate me icon again it will shift,,, and again redraw the map VERY slowly
| Back to top |
Posted: Thu Jun 24, 2010 3:00 pm Post subject: |
| Should have said Maps does much the same EXCEPT the blue pinpoint will refresh from time to time as I move about... |
| Back to top |
Posted: Thu Jun 24, 2010 4:42 pm Post subject: |
no issue here - just deleted from phone and re-downloaded again from appstore. all installed without issue...
is your t'interwebnet connection playing up?
MaFt |
| Back to top |
Posted: Thu Jun 24, 2010 4:44 pm Post subject: |
i would suggest you have an issue with the gps on your phone then. in maps when the pin moves does it have a pale blue circle around it? if so then it means it has poor gps reception and is likely to be using dell phone mast triangulation (i.e. not accurate and will jump from point to point rather than moving smoothly).
MaFt |
| Back to top |
Posted: Thu Jun 24, 2010 4:49 pm Post subject: |
In Maps
It starts with a circle round it of maybe 50 mile radius, which then shrinks down to say 5 miles then finally after maybe 10secs goes altogether.
In Cameralert I seem to get a blue pinpoint after 10secs or so too... however the map doesnt shift off being centered on Manchester (I am near Heathrow) and it never zooms in.
It seems that the pin point then just 'sits' in the same spot.... I am off out in the car again in a moment. I think I might delete the app and redownload from the Appstore and see if things change. |
| Back to top |
Posted: Thu Jun 24, 2010 5:03 pm Post subject: |
the app will NOT work in 'couch-test' mode.. it is designed for on the move. i.e. your actual location won't update until you are out in the car moving. also, if you want it to auto-zoom you need to turn this on in the settings.
MaFt |
| Back to top |
Posted: Thu Jun 24, 2010 8:39 pm Post subject: |
It doesnt work in car mode either.
However with the help of the GPS Status App on this unit, and on my wifes identical phone (I bought them together) I have discovered that the gps setup in my phone is dead.
Holding both phones in the palm of my hand hers comes up bad fix, then poor fix then good fix within 5 or 6 seconds of starting the App whilst mine never gets past bad fix.
So...... I knew I wanted an Iphone 4, now I have a solid reason!! |
| Back to top |
Posted: Thu Jun 24, 2010 9:58 pm Post subject: |
| HL7222 wrote: | | However with the help of the GPS Status App on this unit |
which one? this one?
MaFt |
| Back to top |
Posted: Fri Jun 25, 2010 8:47 am Post subject: |
Thats the one.... very useful.
If I were to get hold of a Tomtom car kit (with a built in GPS chipset) would that then make the app on my gps defunct Iphone work???
Thinking of getting one to use with the Iphone 4 anyway - but cant face the waiting around outside an O2 shop to upgrade just yet. |
| Back to top |
Posted: Fri Jun 25, 2010 8:48 am Post subject: |
And for anyone upgrading to iPhone4, please remember that CamerAlert is locked to a single iPhone.
In order to transfer a sub to a new iPhone you must follow the guide here. _________________ Darren Griffin |
| Back to top |
| Back to top |
