| Author |
matthewj Frequent Visitor
Posted: Tue Jul 06, 2010 2:45 pm Post subject: Using a memory card |
I looked in the FAQ, but it isn't there. Given the map size issue, and the fact that my subscription is up soon, I figure I should install an SD card in my 740 and get the whole of Europe downloaded to it.
Could someone tell me what I should do to make it work as easily as possible? Do I just buy any 4Gb micro-SD card, stick it in the slot, copy the files from one to the other, and then select the big map? Or is there something more to it?
Thanks in advance, Matthew |
| Back to top |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Tue Jul 06, 2010 3:36 pm Post subject: |
For a 740, it should be just case of putting in a micro SD card.
Home should now ask where you want to install the map to - internal memory or card. |
| Back to top |
Guivre46 Frequent Visitor
Joined: Apr 14, 2010 Posts: 1262 Location: West London
Posted: Tue Jul 06, 2010 5:35 pm Post subject: |
In the "W&CE v850 map released' thread, there is a report that TTCS say there is an issue with loading the whole map on an sd card which they are working to resolve. _________________ Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom |
| Back to top |
MARViN2003 Regular Visitor
Joined: Nov 27, 2005 Posts: 132 Location: Stroud, Gloucestershire
Posted: Tue Jul 06, 2010 7:15 pm Post subject: |
I have a GO 930. I moved the US maps onto an SD card and then Home let me install all of W&CE to the internal memory  |
| Back to top |
Posted: Thu Jul 08, 2010 10:48 am Post subject: |
| I have here a Duracell "microSDHC" 4GB card in its packaging. On it, it has a warning, that "microSDHC" is not "microSD". Did I buy the wrong thing? Will this work, or should I send it back? |
| Back to top |
Posted: Thu Jul 08, 2010 11:40 am Post subject: |
| Google and Wikipedia tell me that MicroSD goes up to 2GB, and MicroSDHC goes from 4Gb, so it must be okay. |
| Back to top |
compost Occasional Visitor
Posted: Thu Jul 08, 2010 11:58 am Post subject: |
| I am using a 4GB SD (Class 6 SDHC) card in my Go 720 and that works without any problem whatsoever. |
| Back to top |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2146 Location: Surrounded by A1, M1 & M25
Posted: Thu Jul 08, 2010 11:59 am Post subject: |
I use 8GB MicroSDHC in my 940 and also one via an adaptor in my 530. _________________ Drivelux |
| Back to top |
Posted: Thu Jul 08, 2010 12:02 pm Post subject: |
| Thanks both - I can continue with confidence. |
| Back to top |
Posted: Thu Jul 08, 2010 4:06 pm Post subject: |
One more question then, following on from discovering that to install the bigger map I have to put it in an SD card reader: Am I going to be able to update as usual on the TT740 device, or should I pull the SD card each time? What is the normal mode of operation when you have "two installs"?
Thanks! |
| Back to top |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Fri Jul 09, 2010 9:52 am Post subject: |
When you connect device to PC, home asks you which device you want to connect, SD or internal memory. I think this behaves properly for everything EXCEPT map updates. (I don't really use Home for anything else.) When it comes to maps, even though you have chosen the SD, it still updates the internal memory, or at least, when I updated this week, it told me it was going to update internal memory, and I aborted the install! _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
| Back to top |
Posted: Fri Jul 09, 2010 11:21 am Post subject: |
Maoshare updates are only downloaded for the active map on the unit. I wonder if Map updates are similar.
I use operate my go to switch maps (I have W&CE and US 8.50s on there) and then update my go. I get the Mapshares only for the active map.
So, try try a map update, with the sd card in the slot of your tomtom and with that map active. |
| Back to top |
crowman Occasional Visitor
Posted: Tue Jul 13, 2010 6:15 am Post subject: |
| MARViN2003 wrote: | I have a GO 930. I moved the US maps onto an SD card and then Home let me install all of W&CE to the internal memory  |
My 930 is also in the same situation. 68Mb on the internal memory and a 8Gb SD card with pretty much nothing on it.
Did you just move the NorthAmerica folder straight to the SD card, or is there a correct way to do this in TTHome? |
| Back to top |
trooper Occasional Visitor
Posted: Tue Jul 13, 2010 7:59 am Post subject: |
| crowman wrote: | | MARViN2003 wrote: | I have a GO 930. I moved the US maps onto an SD card and then Home let me install all of W&CE to the internal memory  |
Best not to use Home to move the map. Just use windows explorer. I did the same as MARViN2993 and moved the USA map to my 4GB SD card, then installed W&CE.
I almost have enough Internal memory to put it back (USA map). Anyone know what Folders and Files you can safely delete with out loosing any functionality?
This is a 930. |
| Back to top |
| Back to top |
