Pocket GPS World :: View topic - Another Go 100x "can it do this yet" thread...
HenryMitchell
PostPosted: Wed Feb 16, 2011 12:40 am    Post subject: Another Go 100x "can it do this yet" thread... Reply with quote
I ordered a GO 1005 before launch to replace my GO 950 but then cancelled it when I realised that it might not be a good idea quite yet, but it's starting to look attractive again now the 3P POI issue is (nearly?) resolved.
However I would also require the following functions:
1. Compatibility with my my TT Bluetooth remote.
2. Mapshare.
3. TT Camera database updates (I like a belt n braces approach).
4. Genuinely latest maps (not just the latest one that works on GO 100x)
Can anyone shed any light on where the units currently stand on these?
Device: GO 600, Live connected via iPhone 5.
App: 13.030.1412491.111 (0) (2042, 31/10/2013)
OS: 1392579
Map: Europe v920.5244 (11/2013)
PostPosted: Wed Feb 16, 2011 12:44 am    Post subject: Reply with quote
1. Don't know
2. No Mapshare "yet"
3. No TT camera downloads "yet"
4. Latest (v865) maps work on the Go1000, but I don't think you'll get them via the LMG in the UK "yet"
HenryMitchell
PostPosted: Wed Feb 16, 2011 12:46 am    Post subject: Reply with quote
Looks like I'm waiting a bit longer then...?
OS: 1392579
xtraseller
PostPosted: Wed Feb 16, 2011 7:45 pm    Post subject: Reply with quote
Speed Cameras do (read have just) updated on the TT 1000 - the are lots of additional spots, improved icons, etc. - to be honest, they work great now compared to just a few days ago (in terms of coverage and visual icon). Very impressed
LMG - I claimed mine and it updated fine, although I understand from on here that TT are no longer offering it - a new map update is due any day now, which they say will include te TT 1000 units
TomTom Go Live 6100, 600
Garmin DriveLux 50, D-Smart 70, NuviCam, 3598, 2699, 2798
Mio Navman 695
Nexus 6p, Apple iPhone 6sPlus and Microsoft Lumia 950xl running TomTom, Garmin, CoPilot, Navigon, Sygic, Here Drive, Google, Waze, MS Maps
technik
PostPosted: Wed Feb 16, 2011 11:07 pm    Post subject: Re: Another Go 100x "can it do this yet" thread... Reply with quote
Why change from a 950?
Is it mainly because the route calculations are slow?
I can still get a new 950 for £160, but thought the 1000 will have a better future?
Does the 950 fit onto a GO 1000 mount with same electrical connections?
GO 620, Tomtom Android EU,
Garmin 2548LMT-D; 2599LMT-D
PostPosted: Wed Feb 16, 2011 11:12 pm    Post subject: Re: Another Go 100x "can it do this yet" thread... Reply with quote
No it doesn't the 1000 uses a totally new mount that is held together with magnets, works well in practice but can look rather unsightly due to the cable entry position compared to an x40/ x50 mount - Mike
technik
PostPosted: Wed Feb 16, 2011 11:23 pm    Post subject: Reply with quote
Hi mike, I think it was you that showed how to make a GO 1000 bracket using an Iphone ball instead of buying the full Brodit version.
What is the part number for the ball part?
PostPosted: Wed Feb 16, 2011 11:30 pm    Post subject: Reply with quote
You can even use an old Go x20 ball!
technik
PostPosted: Wed Feb 16, 2011 11:35 pm    Post subject: Reply with quote
Thanks.
So my 930 Brodit ball will do the job...Great. Laughing
PostPosted: Wed Feb 16, 2011 11:41 pm    Post subject: Reply with quote
533091 is the part number for the Brodit ball that works with most TomTom mounts once you take them to bits.
AFAIK I have only sent the following out to one forum member in the form of a PM, but cannot remember who! Here are a set of instructions that you might find "handy"
All thats needed is a Brodit Pro-Clip to suit your car and the Brodit "Ball" intended for use with the iPhone car kit, a torx size 5 screwdriver and a small Philips screw driver.
Start by removing the two size 5 Torx screws from the back cover of the Go-1000 mounting shoe:
With both screws removed which can be fiddly as they get held in place due to the magnets but they do come out. Using nothing more than your thumb nails part the two sections of the mount:
With the front cover removed you can also remove the large magnet, this is handy to stop those little screws from rolling around on the table and getting lost!
The rear section of the mount shoe is next to remove, using the small Philips head screwdriver simply release the four screws that hold it in place:
Push the black "collar" back towards the windscreen sucker to reveal access to the translucent ball cover:
Pull the translucent ball cover off the windscreen mount:
Finally pull the black collar off the ball, note this can be a little stiff but will come off with gentle force:
Now you start the process of rebuilding your mount on to the Brodit Ball:
First slide the black collar over the "ball":
Next is the translucent ball cover which is pushed in to place, look at the next photograph before pushing this part in to place:
Take care to make sure the keyway is in the correct position, looking at the picture you can see the small notch in the translucent ball cover at the six o' clock position, if you don't get this notch and key-way correct the mount will be floppy when built up:
Re-fit the rear portion of the mount shoe using the four Philips head screws, these need to be tight:
Fit the main magnet into the front cover before snapping the front portion of the mounting shoe back in position, once secure re-fit the two size 5 Torx screws in the rear of the holder:
Fit the Pro-Clip/ Brodit 1K mount in to your car, and fit the power cable supplied with the device to the mount, note in my installation the power cable is routed out of sight through the airvent which makes for a very neat installation devoid of cables all over the inside of the car:
Finally pop the unit on the mount and away you go:
Mike
xtraseller
PostPosted: Thu Feb 17, 2011 12:04 am    Post subject: Reply with quote
And a Go 1000 for about £190 from Expansys.com us bound to be £30 well spent???
Mio Navman 695
technik
PostPosted: Thu Feb 17, 2011 12:41 am    Post subject: Reply with quote
Mine is already in the post from Amazon.
I presume you work for Expansys?
xtraseller
PostPosted: Thu Feb 17, 2011 9:28 pm    Post subject: Reply with quote
No I don't work for expansys or any other sat nav / electronics company, I was just trying to help. Should have known better, I suppose
Mio Navman 695
zip401
PostPosted: Mon Feb 21, 2011 2:32 am    Post subject: Reply with quote
Thankyou Mike. A great descriptive post, very helpful.
Currently have a Brodit mount in that position for my phone. That can move to the middle. Will defo get the mounting ball for the 1000 and fit it.
No more suction cups - yippee!
And only looks like a phone mount, so no more smashed windows looking for satnavs after suction rings left on windows - double yippee!
lyskamm
PostPosted: Mon Feb 21, 2011 10:29 am    Post subject: Reply with quote
I wouldn't be so sure about this one... Laughing
24.041 (01 Apr 26)
