Pocket GPS World :: View topic - 720 T battery life
720 T battery life
TD
PostPosted: Fri Mar 04, 2011 9:35 am    Post subject: 720 T battery life Reply with quote
I have searched for answers but have not found anything.
My 720 has up to recently had a reasonable battery life,45min to 1 hr,Its now down to 1-2 min.I have heard that recent updates via tt home can cause this problem? If so how can I correct this. I would like to be sure that it IS a battery fault before I send it away for battery replacement
Thank you TD Smile
Daggers
PostPosted: Fri Mar 04, 2011 9:44 am    Post subject: Reply with quote
My 520 is the same, and has been for some while. I don't know the cause, but there's a simple solution - always drive with it plugged in. It doesn't worry me at all!
Garmin DriveSmart 50 LMT-D
stuart
PostPosted: Fri Mar 04, 2011 10:37 am    Post subject: 520T Battery Reply with quote
After many months, I decided to replace the battery on mine..... £13.01 on Amazon from MDS Battery Ltd, which included the Torx screwdrivers and opening tool. Took 24 hours to arrive 'Post Free' and 20 minutes to replace....An absolute bargin.. CoPilot
Thumbs Up
TD
PostPosted: Fri Mar 04, 2011 5:13 pm    Post subject: Reply with quote
Thanks for the replies, but regarding doing the battery replacement myself,after reading how delicate the connecting strip is & the difficulty removing the old battery I think I will have it done for £25 IF it needs replacing & the fault is not down to a recent download
TD Wink
PaulB2005
PostPosted: Fri Mar 04, 2011 6:24 pm    Post subject: Reply with quote
I can't see how a recent download would result in the battery life being dramatically reduced like that. More likely that the battery in your older model is now knackered and not holding it's charge.
PostPosted: Fri Mar 04, 2011 6:34 pm    Post subject: Reply with quote
Seconded, this is symptomatic of a battery at end of life, nothing to do with software and never heard of HOME causing any such issue. It's at the root of many issues but battery life ain't one of them Very Happy
Get the battery replaced if you're not comfortable doing it yourself and it'll be right as rain.
Thermoman
PostPosted: Tue Mar 08, 2011 10:24 am    Post subject: Reply with quote
I have a TT720 & a TT730, replaced batteries in both as they where not holding their charge.
720 is fine, will hold its charge for several weeks but the 730 still only lasted about 30 mins.
Thought it may be a duff battery so bought another but still the same problem.
I found that pressing the hard reset button on the 730 after use solved the problem, just switching off puts the unit to sleep but for some reason on the 730 when it sleeps it still draws a high current.
Barry
PostPosted: Tue Mar 08, 2011 10:53 am    Post subject: Reply with quote
Try using the "clear route" option rather than pressing the reset button and see if that makes things better - Mike
Thermoman
PostPosted: Thu Mar 10, 2011 7:42 pm    Post subject: Reply with quote
Nope, tried that, the only way I can extend the battery life is to press the reset button.
Also shifted the prog (new download) & maps to the SD card but that made no difference.
Barry
Trevor1234
PostPosted: Thu Mar 10, 2011 9:41 pm    Post subject: Reply with quote
Hi Folks
I have had my 720 since Feb 2008 and the battery is still ok. However, it is used on a regular basis and the day must come when it gives up the ghost. I always drive with it plugged into the car but one does occasionally still sit at home having a fiddle and to do so a battery is still required.
Some time ago someone (I think it was Mike) gave a demo using screen shots of a battery replacement taking place. I meant to bookmark that topic but I if I did so I can no longer find it. If any of you have the web page can you let me have the details please?
Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G
dhn
PostPosted: Thu Mar 10, 2011 10:02 pm    Post subject: Reply with quote
Not Mike's tutorial (I'm sure he'll post it here) but here's one in this link:
http://www.tomtomforums.com/tomtom-tweak-discussion/14261-720-730-920-930-battery-replacement-tutorial.html
Trevor1234
PostPosted: Thu Mar 10, 2011 10:22 pm    Post subject: Reply with quote
Hi dhn
Thanks for the address I will save it for when its needed. It wasn’t the tutorial that I had seen in the past but it will do just fine
Thanks again.
Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G
PostPosted: Thu Mar 10, 2011 10:23 pm    Post subject: Reply with quote
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=444186#444186 Wink
TT Via 135 App 12.075: Europe Map v1165
Trevor1234
PostPosted: Fri Mar 11, 2011 3:48 pm    Post subject: Reply with quote
Hi Oldboy
Thanks. I hope that I never need to replace the battery but If the day does arrive I will be well prepared.
Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G
MrT
PostPosted: Sat Mar 12, 2011 10:51 am    Post subject: Reply with quote
Is it just me or are half the pictures missing from Mike's tutorial?
Drivelux
24.041 (01 Apr 26)
