Pocket GPS World :: View topic - Unblocked Streets
Unblocked Streets
PostPosted: Fri Mar 18, 2011 9:39 am    Post subject: Reply with quote
cabmanuk wrote:
Both roads have changed, you can drive through both.Been changed for about a year.Google maps still showing old system
Had you imparted this little gem of local knowlwdge to us in your first post, this would have made this topic much shorter. Very Happy Possibly in just one reply post such as below, but probably more detailed frome someone more knowledgable than I Very Happy
I don't think you can unblock roads that are shown as one way in the map data. You should submit a change to the map provider, but don't expect it to be corrected anytime soon, unless they are already on to it Sad .
Oldboy
PostPosted: Fri Mar 18, 2011 11:46 am    Post subject: Reply with quote
Indeed you can, and they take immediate effect on your own map(s). Smile
TT Via 135 App 12.075: Europe Map v1165
PostPosted: Fri Mar 18, 2011 12:16 pm    Post subject: Reply with quote
Then I wonder why cabmanuk is having problems unblocking it? Confused
cabmanuk
PostPosted: Fri Mar 18, 2011 12:47 pm    Post subject: Reply with quote
I have changed all the one way little arrows still no joy,maybe its a fault on the TT1005 Confused Still no map share so it cannot be reported yet.Or maybe I have missed some will keep trying Very Happy
Oldboy
PostPosted: Fri Mar 18, 2011 7:31 pm    Post subject: Reply with quote
cabmanuk wrote:
I have changed all the one way little arrows still no joy, ...
Look a bit further Westward, the top of Friday St, and you'll see an EB arrow head there. Do that one as well. Wink
This is on the 865 map on my 910.
Guivre46
PostPosted: Fri Mar 18, 2011 8:39 pm    Post subject: Reply with quote
cabmanuk wrote:
I haven't got a 100x model, but didn't I read somewhere here that they do map corrections differently? Something about not changing the map on the device directly, but having to progress via TT servers? Is mapshare available for the 100x yet?
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
PostPosted: Fri Mar 18, 2011 9:01 pm    Post subject: Reply with quote
Nope... works exactly the same for corrections on your own device.
They are implemented immediately.
But the uploading and downloading (the "sharing" bit) doesn't work yet.
young-goat
PostPosted: Sat Mar 19, 2011 11:54 pm    Post subject: Reply with quote
I am also a London Taxi Driver , and I devised a workaround for the Cannon St. / Friday St. / Queen Victoria St layout
Because you can't change the way the map shows the previous road layout you have to trick it into giving you different routes
make EVERY part of Friday Street 2 way Including the triangular islands at the top and bottom
make EVERY part of Cannon St. above Friday St. 2 way
make the whole of Queen Victoria St. 2 way INCLUDING both sides that head to and from the Bank Junction
There are lots of short sections of Cannon St so there are a lot of changes to the traffic direction to be made.
You may have to change turn restrictions also
cabmanuk
PostPosted: Sun Mar 20, 2011 12:46 am    Post subject: Reply with quote
Thanks everyone for your help finally done it Very Happy
PaulB2005
PostPosted: Sun Mar 20, 2011 10:40 am    Post subject: Reply with quote
I hope those dont EVER get Shared.
Surely in this case it would just be easier to do what you know and ignore your tomtom? Now you risk lots of other errors now?
I have a junction near here that isn't displayed exactly correct but I know what I need to do from the instruction even though it's not displayed correctly.
cabmanuk
PostPosted: Sun Mar 20, 2011 1:00 pm    Post subject: Reply with quote
Sad Hello mate why would it cause more errors?
PaulB2005
PostPosted: Sun Mar 20, 2011 1:12 pm    Post subject: Reply with quote
Well, if I've understood it correctly you've effectively undone several one way roads in the area so if you approach from a different direction will it not now try to send you the wrong way down one way roads etc? Especially round the triangle junctions?
cabmanuk
PostPosted: Sun Mar 20, 2011 1:26 pm    Post subject: Reply with quote
As far as I know the roads that I have corrected should be ok Embarassed
I have only changed the directions on the roads and have not changed the triangle junctions.
young-goat
PostPosted: Sun Mar 20, 2011 2:15 pm    Post subject: Reply with quote
The point is, ALL these roads have been reverted to being TWO WAY
As to 'taking the route one knows to be right' One could do that easily but these changed routes have a far wider effect on route planning than you might realise.
(edited to insert omitted word and bad punctuation)
PaulB2005
PostPosted: Sun Mar 20, 2011 2:20 pm    Post subject: Reply with quote
Ah I see! I thought it was just one section of road that was mis represented leading to a round the houses route rather than a direct route.
Page 2 of 3
24.041 (01 Apr 26)
