| Author |
Andy_P Pocket GPS Moderator
Posted: Tue May 24, 2011 12:24 pm Post subject: v10.200 software and new features for the Go1000 at last! |
TomTom has just released v10.200 software for the GO 1000 / GO 1005 and some VIA models.
At last, the long promised ability to load POIs, voices, Warning sounds etc. has been implemented.
I've been lucky enough to have a sneak preview of this functionality, and it works well.
It's still a long slow process to load stuff, but even that may be improved soon.
| Quote: | (GO 1000 series, Via series)
* Allows you to use MyTomTom to install third party POI sets, community voices, warning sounds, start-up and shut-down images, car symbols and colour schemes.
* Improves map installation process |
This is what you should see in myTomTom now.
 _________________ "Settling in nicely" ;-) |
| Back to top |
cooldood Lifetime Member
Posted: Tue May 24, 2011 1:34 pm Post subject: |
| What format do the warning sounds have to be as it wont let me upload the .ogg sound files for the cams? |
| Back to top |
Posted: Tue May 24, 2011 3:10 pm Post subject: |
I'm using ogg files OK here.
There was some problem uploading them but I thought it had been sorted.
But you could try .wav?
I don't think mp3 are ever going to work. _________________ "Settling in nicely" ;-) |
| Back to top |
Posted: Tue May 24, 2011 3:49 pm Post subject: |
I just tried it again and uploaded another .ogg sound file successfully, but I'm on a slightly earlier software version.
One thing to mention is that the sounds are not being sorted alphabetically, so check to see if they HAVE uploaded but just got buried in the list. _________________ "Settling in nicely" ;-) |
| Back to top |
Posted: Tue May 24, 2011 4:31 pm Post subject: |
when i try to install them it tells me..... the poi set you are trying to use cannot be used with your device. check you have the correct file.
i will try converting them to wav format and try again |
| Back to top |
Posted: Tue May 24, 2011 4:45 pm Post subject: |
converted them to wav and get exactly the same response  |
| Back to top |
technik Lifetime Member
Joined: Mar 18, 2004 Posts: 789 Location: Midlands UK
Posted: Tue May 24, 2011 5:41 pm Post subject: |
It doesn't actually provide you with any new map colour schemes, or icons, voices etc like the old Home used to do. _________________ GO 620, Tomtom Android EU,
Garmin 2548LMT-D; 2599LMT-D |
| Back to top |
jmcmtank Lifetime Member
Posted: Tue May 24, 2011 9:33 pm Post subject: |
| Got my ogg camera warning sounds on OK, tested and they work fine......just a shame I loaded the wrong set initially, just as slow to delete files as load them! Oh yeah, now have a retro start up splash screen from a previous device. |
| Back to top |
Posted: Tue May 24, 2011 10:48 pm Post subject: |
| cooldood wrote: | when i try to install them it tells me..... the poi set you are trying to use cannot be used with your device. check you have the correct file.
Are you scrolling down the page to "Community warning sounds on device +Add Warning Sound"? |
| Back to top |
Posted: Tue May 24, 2011 11:42 pm Post subject: |
| jmcmtank wrote: | | cooldood wrote: | when i try to install them it tells me..... the poi set you are trying to use cannot be used with your device. check you have the correct file.
Yes I was. I shut the pc down to go out when I came back I tried again and the option was there. Installed then deleted so I could rename them, I can now assign them without going through every single one to find the correct one. _________________ Tomtom 1005 but wish I had kept my 550 live |
| Back to top |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Thu May 26, 2011 8:54 am Post subject: |
Got an email from TT this am pointing me to the updated info on this subject ...see here
Gives all the info on the updated 'Community content' function of MYTomTom  _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
| Back to top |
HummerUK Frequent Visitor
Joined: Apr 21, 2007 Posts: 332 Location: East Sussex
Posted: Thu May 26, 2011 5:59 pm Post subject: |
I see the PC software has also updated again to 3.0.2.344
HummerUK |
| Back to top |
Posted: Thu May 26, 2011 6:20 pm Post subject: |
| HummerUK wrote: | I see the PC software has also updated again to 3.0.2.344
HummerUK |
Yes, just updated mine.  _________________ Gee-Pee
| Back to top |
mjdj1689 Regular Visitor
Posted: Thu May 26, 2011 9:06 pm Post subject: |
| Not had a chance to look at this, so instead of a page where you can get the voices like on the old tomtom now you just add poi and it gives you a list of voices pois , is this correct ? |
| Back to top |
vickusin Occasional Visitor
Posted: Thu May 26, 2011 11:56 pm Post subject: |
Just had a go at uploading something into each category to see what would happen. I had a lot of personalised stuff in my old Go 950. I tried warning sounds, car symbols, map colour schemes, voices and a startup screen - they all seem to have gone in OK and are working.
It seems that TomTom are finally heading in the right direction with this. Still a few thigs that need adding, like Map Share and additional voices, but they're getting there. |
| Back to top |
| Back to top |
