| Author |
bloater Lifetime Member
Posted: Fri Jun 03, 2011 7:16 pm Post subject: Un-Navigable road |
Help,
How can I make a road be used for navigation??
My new 1005 exhibits the same issue with the maps as my 730 used to, it wont route down the road into my local estate in MK. Instead of a 100yard road it takes a 5 minute detour, getting to the opposite end of the road as well.
I tried on my 730 to correct it with map corrections, however all the junctions are correct with arrows where they should be. The road doesn't have anything on it to indicate its blocked, its driving me up the wall.
If anyone has a spare few minutes and feels like trying to find out why, its Nymans Gate in Westcroft, Milton Keynes. Route from Buckingham to MK4 4FE and then see which way it takes you into the estate, certainly not via Nymans Gate, the quickest way. This is even the same on the web planner, and has existed for a few years now. The road has been there the same length of time as Exbury Lane, don't understand.
Thanks for any light shedding moments you may have.
Gary |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Fri Jun 03, 2011 8:03 pm Post subject: |
That's quite a good one, isn't it!
For anyone else trying it, once you've tried the full route from Buckingham, you can adjust the start point closer and closer to the destination and keep re-calculating it.
If you start anywhere on Nyemans Gate itself, it takes the sensible route, but as soon as you move back out onto Snellshall street (from the North or South) then it takes the silly route.
Switching to shortest route makes no difference either.
So that implies there's something wrong in the join between the two roads, but I haven't spotted it yet! _________________ "Settling in nicely" ;-) |
| Back to top |
Posted: Fri Jun 03, 2011 8:38 pm Post subject: |
Thanks Andy, glad its not just me,
I have all manner of delivery drivers struggle, driving the sat nav way, but after delivery I tell them up there turn right, back on main roads, they laugh usually. Not sure if its just a TT thing, don't have anything else to try, but suffice to say, Google does the same thing.
Gary |
| Back to top |
Posted: Fri Jun 03, 2011 8:45 pm Post subject: |
I can report it to TomTom for you, but I'll wait a bit.... to see if anyone clever can work out WHY it's doing it first! _________________ "Settling in nicely" ;-) |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
Posted: Fri Jun 03, 2011 8:54 pm Post subject: |
The route fails in both directions. It looks as if the data associated with that junction is corrupt/incomplete. It could be either, or both, roads that are in error.
Unfortunately there is nothing in MapShare that allows it to be corrected 'on the fly'. _________________ Richard
TT Via 135 App 12.075: Europe Map v1165 |
| Back to top |
Posted: Fri Jun 03, 2011 9:05 pm Post subject: |
Thanks for looking chaps. Anything that could be done would be good, after all, why shouldn't it work
Whenever I set a route home from anywhere, I always knock 5 mins off of the arrival time, because I don't blindly follow the TT, but use my initiative and use the "un-navigable" road. Its fine, its tarmaced, with a speed limit, in fact the wife saw the google street view car drive down it when they were mapping the area a couple of years back.
Cheers.
Gary |
| Back to top |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Fri Jun 03, 2011 11:20 pm Post subject: |
I believe I know another very similar situation to this. Try Weston Lane B11 (52.45221, -1.85235) to Battery Lane B11 (52.45223, -1.86338). Is this the same? _________________ Garmin DriveSmart 50 LMT-D |
| Back to top |
technik Lifetime Member
Joined: Mar 18, 2004 Posts: 789 Location: Midlands UK
Posted: Fri Jun 03, 2011 11:55 pm Post subject: |
The same thing happens to the OP's route using Google Maps to plan the route. _________________ GO 620, Tomtom Android EU,
Garmin 2548LMT-D; 2599LMT-D |
| Back to top |
unseen Occasional Visitor
Posted: Sat Jun 04, 2011 12:52 am Post subject: |
Funny I was about to mention that Google does the same.. What I did notice though is if with the OP's original post on Google Maps and drag the route to one side of Nymans gate that it will plan a more direct route.
Could it be something as daft as a junction with incorrect routing? IE Thinking it's a one way route when it's quite obviously not, hence the wierd round the houses routing?
Same thing happens with the B11 address's, if you play with them in Google Maps you can get it to route nearly directly.
Google and TT use the same data so I guess it's a no brainer they'd both be wrong.. |
| Back to top |
Posted: Sat Jun 04, 2011 9:26 am Post subject: |
It's interesting that the walking directions in Google for both journeys take the correct route, and are much quicker than the convoluted driving route. (In the MK case, over the disputed road, not starting from Buckingham!) _________________ Garmin DriveSmart 50 LMT-D |
| Back to top |
Posted: Sat Jun 04, 2011 1:30 pm Post subject: |
| unseen wrote: |
Could it be something as daft as a junction with incorrect routing? IE Thinking it's a one way route when it's quite obviously not, hence the wierd round the houses routing? |
No... Mapshare shows all the turn directions as allowed and the road as open in both directions _________________ "Settling in nicely" ;-) |
| Back to top |
2216 Regular Visitor
Posted: Sat Jun 04, 2011 6:07 pm Post subject: |
| Using Mapsource with slightly old maps 2011.1 it routes from Buckingham centre to Nymans 10.4 miles and 13.03 mins. So Navtech maps seem to have got it right. |
| Back to top |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Sat Jun 04, 2011 6:20 pm Post subject: |
| Oldboy wrote: | | It could be either, or both, roads that are in error. |
It appears to be Nymans Gate that's in error. On Google Maps, if you drag the 'End' marker to a point within the first few yards of Nymans Gate, it takes the sensible route but, if you drag the marker further, the route changes at 51.999552, -0.799937. It seems to be close to where the road widens at a layby. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
| Back to top |
| Back to top |
