| Author |
peasemore Lifetime Member
Posted: Sat Jun 04, 2011 8:45 pm Post subject: 720T_ RDS TMC Accessory |
My TMC traffic accessory seems on the blink; it's the non USB type.
Has anyone ever opened up the capsule, as a last chance saloon attempt I was thinking of prising open to see if anything loose/repairable??
I'm fairly certain it's accessory not the TT itself, but of course unless I buy another, I can't be certain.
Been down for week now, but did suddenly pop back into life when travelling through North Oxfordshire recently; when I came out of my meeting, and switched the TT on, there was no Traffic again  _________________ Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve. |
| Back to top |
psyskiesman Lifetime Member
Joined: Jun 22, 2004 Posts: 322 Location: Swindon, Wiltshire
Posted: Sat Jun 04, 2011 8:53 pm Post subject: |
| I recall mine went faulty, occasionally springing back into life. The fault was a break in the wire, very close to the egg shaped thingy. I swapped it out for the usb type. |
| Back to top |
Posted: Sat Jun 04, 2011 9:12 pm Post subject: swapped for usb type |
| psyskiesman wrote: | | I recall mine went faulty, occasionally springing back into life. The fault was a break in the wire, very close to the egg shaped thingy. I swapped it out for the usb type. |
Is it single strand wire; if break discovered, wondered if I could
make good/ seal off.
How can you swap for USB type as 720t has round not USB socket  _________________ Gel
| Back to top |
DennisN Tired Old Man
Posted: Sat Jun 04, 2011 9:19 pm Post subject: |
The USB type is a block with USB input and output thingies. You plug your ciggy power cable into the block and the block thingy (using a short cable) into the base of the 720T instead of your ciggy cable. It doesn't go into the round hole. _________________ Dennis
Two of them are obesiting!! |
| Back to top |
Guivre46 Frequent Visitor
Joined: Apr 14, 2010 Posts: 1262 Location: West London
Posted: Sat Jun 04, 2011 11:36 pm Post subject: |
The usb connector needs v8.351 software.
I recall a post where someone said they opened the old egg-shaped one by squeezing it in a vice - it just 'popped open'. Though others here were urging a more cautious opening. _________________ Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom |
| Back to top |
molerat Lifetime Member
Joined: Jul 06, 2007 Posts: 204 Location: Very North of the Border
Posted: Sat Jun 04, 2011 11:55 pm Post subject: |
Check the centre pin of the jack plug is not missing, seen a few like that. _________________ Garmin Drive 51LMT-S EU
(TT One V3 512MB + RDS TMC UK&RoI v1005 now retired, dead due to withdrawal of manufacturer support) |
| Back to top |
Posted: Sun Jun 05, 2011 7:18 am Post subject: |
The two parts of the oval "egg" can be prized appart, I use a blunt kitchen knife, there are four wires connected to the PCB:
J4 RED
J5 GREEN
J6 ORANGE
J7 BLACK
- Mike |
| Back to top |
Posted: Sun Jun 05, 2011 7:29 am Post subject: USB |
| DennisN wrote: | | The USB type is a block with USB input and output thingies. You plug your ciggy power cable into the block and the block thingy (using a short cable) into the base of the 720T instead of your ciggy cable. It doesn't go into the round hole. |
Thanks DN ; there are a few more of those about on E Bay, and presumably provides power input too, as without power I just have a few minutes operating. _________________ Gel
| Back to top |
Posted: Sun Jun 05, 2011 8:05 am Post subject: |
| Your existing mini USB charger lead plugs in to the RDS-TMC receiver, there is a short lead from the RDS unit that plugs in to your TomTom, this short lead supplies the charging voltage for the nav unit and the digital data containing the RDS information - Mike |
| Back to top |
Posted: Sun Jun 05, 2011 8:06 am Post subject: |
| mikealder wrote: | | Your existing mini USB charger lead plugs in to the RDS-TMC receiver, there is a short lead from the RDS unit that plugs in to your TomTom, this short lead supplies the charging voltage for the nav unit and the digital data containing the RDS information - Mike |
| Back to top |
| Guivre46 wrote: | | The usb connector needs v8.351 software. |
I'm using v8.302 on mine (and I don't know how long I've had the USB device, might have been before 8.302?). _________________ Dennis
| Back to top |
Posted: Sun Jun 05, 2011 8:32 am Post subject: |
Thanks all; looking at image of an USB RDS TMC I didn't see a socket just a plug, ie 2 plugs and only 1 socket!
Now clarified.
| Back to top |
Posted: Sun Jun 05, 2011 9:06 am Post subject: |
| DennisN wrote: | | Guivre46 wrote: | | The usb connector needs v8.351 software. |
I'm using v8.302 on mine (and I don't know how long I've had the USB device, might have been before 8.302?). |
Still living and learning about TT.
Apparently the new rds-tmc that incorporates the antenna into the power lead is compatible with 8.351 though it is not listed - what's new!
SEE HERE _________________ Mike R [aka Wyvern46]
| Back to top |
Posted: Sun Jun 05, 2011 9:42 am Post subject: |
The newer RDS receiver thats integrated in to the charger lead was released circa April 2010, Navcore 8,351 predates the release of the RDS device by at least 12 months so compatibility can't have been provided.
The newer RDS receiver built in to the charger lead will work with some of the newer devices but NOT the x20/ x30 product range unless you really hack around some files to force it to work but not with a stock 8,351 - Mike |
| Back to top |
Posted: Sun Jun 05, 2011 10:49 am Post subject: |
It was This Post from cheapskater - but his link is now dead. _________________ Mike R [aka Wyvern46]
| Back to top |
| Back to top |
