| Author |
clay Occasional Visitor
Posted: Tue Nov 01, 2011 11:04 am Post subject: TomTom Go520 power socket issue. |
The connection socket at the base of my tomtom seems to be on its way out, when you connect via the car charger or pc base unit you have to mess about to get any power to the 520.
Is it worth trying to get this fixed or should I be looking for a new tomtom ? thanks. |
| Back to top |
Posted: Tue Nov 01, 2011 6:19 pm Post subject: |
| A DIY fix for the mini USB connector isn't really viable, not only is it surface mounted to the PCB there are a couple of larger bits of the connector that are soldered through the PCB, de-soldering these prooves very difficult even with professional de-soldering equipment - Mike |
| Back to top |
Posted: Tue Nov 01, 2011 11:53 pm Post subject: |
Thanks Mike...
So im going to be looking at buying a new tomtom then, thats not good news when all i read on here is how the newer tomtoms have less features. |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Wed Nov 02, 2011 1:42 am Post subject: |
Possible to find one on eBay with a broken screen? _________________ "Settling in nicely" ;-) |
| Back to top |
Anita Pocket GPS Moderator
Posted: Wed Nov 02, 2011 10:38 am Post subject: |
Would be worth giving SatNav Repairs a ring to see what they would charge. They get very good reviews from our members. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
| Back to top |
IanS100 Frequent Visitor
Posted: Wed Nov 02, 2011 1:32 pm Post subject: |
| clay wrote: | Thanks Mike...
Or if your're an iPhone aficionado you could take a look HERE & read the write up on the Bosch iPhone app by Tobas - it makes interesting reading particularly if you're looking at spending a sizeable wedge on a new TomTom |
| Back to top |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2146 Location: Surrounded by A1, M1 & M25
Posted: Wed Nov 02, 2011 4:04 pm Post subject: |
Depending on your skills there are some final things you could check out to be totally assured that your unit is dead.
Often where mini connectors are fitted directly to circuit boards the bending of the socket as it is used can break or loosen one of the solder joints of the connectors to the board. If you look at the soldered connections to the board through a jewellers loupe or similar you may see one of the soldered legs move as you insert the plug, this could possilby be re-soldered.
You could try and look at the mini socket under a strong lens and see if any of the external socket contacts are misplaced, dirty or stuck down such that they don't flex slightly to make contact. These could be cleaned with a fine brush (similar to a record player stylus cleaning brush if you remember those) and a little alcohol. If they are pushed out of true or stuck, they could freed gently with a very fine needle. _________________ Drivelux |
| Back to top |
Tobas Regular Visitor
Posted: Wed Nov 02, 2011 6:56 pm Post subject: |
| IanS100 wrote: | | clay wrote: | Thanks Mike...
There's plenty of other iphone and android satnav apps, the Bosch app just happened to be in the recent release list and is a good price for the launch period. I hope my write-up makes it clear why I'm personally avoiding tomtom, I had no problem with their software, just their customer service. I do like the Bosch app though  |
| Back to top |
Posted: Thu Nov 03, 2011 2:40 am Post subject: |
Thanks for all your replys above... no iphone here...
My 520 is still fully working with the latest maps its just the socket has had it, I have to hold the plug in to keep the unit powered...
I might just buy a refurbished Go 750 from tomtom seems the best unit about still. |
| Back to top |
Calomax Lifetime Member
Posted: Thu Nov 03, 2011 8:19 pm Post subject: |
[quote="Tobas"] | IanS100 wrote: | | clay wrote: |
There's plenty of other iphone and android satnav apps, the Bosch app just happened to be in the recent release list and is a good price for the launch period. I hope my write-up makes it clear why I'm personally avoiding tomtom, I had no problem with their software, just their customer service. I do like the Bosch app though  | Only problem, you have to have an awful iPhone (unless the latest one is a huge improvement) _________________ TT Go Essential |
| Back to top |
stuart Frequent Visitor
Joined: 20/04/2003 11:51:10 Posts: 405 Location: Dorset, England, Great Britain
Posted: Fri Nov 04, 2011 3:39 pm Post subject: TTG520T USB |
| clay wrote: | Thanks for all your replys above... no iphone here...
clay...I have the same problem with my 520T..If you find anyone to fix it please let me know.
Anita, got a reply within hours.....£29.99 + P&P...
Edit to update to Anitas repair link... |
| Back to top |
Posted: Fri Nov 04, 2011 6:39 pm Post subject: Re: TTG520T USB |
| stuart wrote: | | Anita, got a reply within hours.....£29.99 + P&P... |
Thanks for the info, Stuart. Not cheap, but I'd pay it to keep my 720 going rather than buy one of the newer (and, in my opinion, inferior) models! _________________ Anita
UK map 1130.12368
| Back to top |
Posted: Fri Nov 04, 2011 7:22 pm Post subject: Re: TTG520T USB |
| Anita wrote: | | Thanks for the info, Stuart. Not cheap, but I'd pay it to keep my 720 going rather than buy one of the newer (and, in my opinion, inferior) models! |
+1  _________________ TT Go Essential |
| Back to top |
| Back to top |
