| Author |
Posted: Fri Jun 24, 2011 8:15 pm Post subject: |
| cornz wrote: | | Awaiting results eagerly.. |
See previous post.
| cornz wrote: | | Does anyone know if it can record 0-60 times, 1/4 mile etc etc?? |
No, it doesn't do this - Mike |
| Back to top |
cornz Lifetime Member
Joined: 05/01/2003 10:51:57 Posts: 118 Location: United Kingdom
Posted: Fri Jun 24, 2011 8:26 pm Post subject: |
Many thanks...
Mines ordered.... |
| Back to top |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Sat Jun 25, 2011 1:45 pm Post subject: |
Wouldn't be very "eco" then, would it?  _________________ Gone fishing! |
| Back to top |
Posted: Sat Jun 25, 2011 6:09 pm Post subject: |
| Skippy wrote: | | cornz wrote: | | Does anyone know if it can record 0-60 times, 1/4 mile etc etc?? |
Wouldn't be very "eco" then, would it?  |
Neither is my car but thats hardly the point. I'd like to be able to measure these things directly... |
| Back to top |
angusc Occasional Visitor
Posted: Wed Jun 29, 2011 2:24 am Post subject: |
| If you have an Android Phone you can always download Torque from the Market which is a very swish interface for any Blue Tooth OBD interface. |
| Back to top |
MRCC Regular Visitor
Posted: Fri Jul 01, 2011 8:53 pm Post subject: |
Could be. You could try to get to 60 as slowly as possible  |
| Back to top |
Posted: Fri Jul 01, 2011 8:56 pm Post subject: |
| angusc wrote: | | If you have an Android Phone you can always download Torque from the Market which is a very swish interface for any Blue Tooth OBD interface. |
Thanks for this. Found one for my symbian phone but it doesnt communicate with the garmin eco-hd device sadly. But i will try torque on 'er indoor's phone..
PS. i love eco route. Adds a touch of "tech+" to the cabin. |
| Back to top |
Posted: Fri Jul 01, 2011 9:18 pm Post subject: |
The Garmin unit appears to use its own unique way of communicating with the PND's from the Garmin product range it won't work with software such as "Torque" for the Torque app you would need a more generic Bluetooth OBD-II reader.
I tend to use the OBD_Gauge software with my OBDKey Bluetooth unit if I want to access and datalog while on a run, its a shame the Garmin software doesn't record the data to the memory card, as I mentioned in the review it would great if it could log such data along with the GPS position, even at one Hertz it would be very handy for post run analysis when running on a race track - Mike |
| Back to top |
Posted: Fri Jul 01, 2011 9:28 pm Post subject: |
Yes, its a shame its a propriatory system.
Oh well...I can read and reset most DTC's so its no massive problem. |
| Back to top |
armoore Occasional Visitor
Posted: Sun Feb 26, 2012 12:16 pm Post subject: ecoRoute HD |
| I've been using mine on an Alfa Romeo GTV 2001 model and have found it to be very useful; it replicates the computer features now found on later cars and the fuel consumption works out to within 1 m.p.g. of what I get from calculating it from fuel used (full tank to full tank) and mileage done. The extra instruments facility in particular is noteworthy and not a distraction. Nearly all my cars and motorbikes have been fitted with oil temperature and pressure gauges, voltmeters and/or ammeters amongst others and especially on the air-cooled engines have had an added benefit (I fly a Bolkow Monsun and in aviation it is imperative to keep an eye on Ts and Ps). Ts and Ps used to be displayed on older cars but now we have to rely on "idiot lights" which really only show when damage has been done. All I had to do to fit the ecoRoute HD device was to very slightly modify (bend) the bracket holding the OBD II socket and use a right-angle adaptor. |
| Back to top |
Posted: Sun Feb 26, 2012 12:19 pm Post subject: |
| MRCC wrote: | | Skippy wrote: | | cornz wrote: | | Does anyone know if it can record 0-60 times, 1/4 mile etc etc?? |
I've tried this and I've found that accelerating "briskly" then easing off gives better economy than gradually gathering speed. |
| Back to top |
carl_w Lifetime Member
Posted: Mon Mar 12, 2012 11:31 pm Post subject: |
| mikealder wrote: |
You get the in call icon top right, the handsfree works fine - Mike | The scale on that central gauge is useless. You might just about get the coolant hot enough to move the pointer off the bottom stop. I guess the scale has been calibrated for Fahrenheit even though the units are set to Celsius. |
| Back to top |
Posted: Tue Mar 13, 2012 10:51 am Post subject: |
I found that too so re-allocated that dial to another function. As 200 is at the top and most cars would run at about 90 deg.C. or 195 deg.F. I would imagine it is for fahrenheit as you say. They've yet to catch up on the metric system in the USA!  |
| Back to top |
Posted: Sun Jul 08, 2012 10:08 am Post subject: Fuel economy. |
| On a recent trip of over 1 200 miles to the Black forest and the Vosges (and back) the ecoroute HD gave a reading of within 0.15 m.p.g. of the one I calculated using the car's odometer and measured fuel upload. I'd say that was pretty good. |
| Back to top |
Agius1410 Occasional Visitor
Posted: Tue Oct 16, 2012 1:23 pm Post subject: |
Does anyone know if you can use a generic OBD2 bluetooth device which you can pic up on ebay for £15?
Ta |
| Back to top |
| Back to top |
