lostgerry Occasional Visitor
Posted: Wed May 09, 2012 10:53 pm Post subject: 910 ebay maybe not a good buy ? |
Hi just purchased a 910 from Ebay nice chap
but every few mins the gps signal disapears for between 1 and 3 seconds ??? is this a known fault and something in the settings ? or have I bought a dodgy one ?
any help advice please
thank you |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
Posted: Thu May 10, 2012 7:06 am Post subject: |
It's not a known fault of the 910, and not something I've seen.
Does this happen when you are in clear view of the sky, and not moving?
If it happens when driving it might be a dodgy connection between the aerial module and the unit (someone may have put it back together incorrectly). _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Thu May 10, 2012 9:51 am Post subject: |
Blimey yes i think you are right when stationary sat on my window sill it stayed rock solid all the bars and I remember the guy said he had had it repaired and bought a new one while it was being fixed
so now is it going to cost me the price of the unit to get someone to take it apart and put it back right ? I dont think i could do this ? (I'm 66 and fingers like bananas )
any suggestions on where to send it too please ? |
Posted: Thu May 10, 2012 9:13 pm Post subject: |
You don't say where you are located. I have an old 910 that suffered a fall that damaged a pcb connector, so that the battery didn't charge.
The aerial module has a small connector and is held in place by 2 small screws. If these are missing, or not tightened, it is possible to get the symptoms you describe.
My 69-year-old, arthritic, fingers can get to the aerial in about 2 mins. It's not that difficult if you have a No.6 Torx bit.
I bought This Torx Set.
See This Post as a guide. You only need to get the cover off - no more. The Red Warning is for those who are going further. _________________ Richard
Posted: Thu May 10, 2012 11:23 pm Post subject: |
hello Richard thanks very much
I will go to maplins in the morning and buy a no 6 torrix screwdriver and have a go I live in Hillingdon Uxbridge I will let you know how I get on fingers crossed
regards Gerry |
Posted: Fri May 11, 2012 10:39 pm Post subject: |
Hi well did as you said but the screws were tight so I removed them and lifted that bit off then carefully replaced it put it all back together and I thought I had broken it as no signal at all then about 7 or 8 mins later the signal came back but its still doing it sadlly
any more ideas ? |
Posted: Sat May 12, 2012 5:57 am Post subject: |
The delay is typical of a 'cold start' for GPS reception.
If you PM me your address I can send you the aerial module from my broken 910, and you can give that a try. _________________ Richard
technik Lifetime Member
Joined: Mar 18, 2004 Posts: 789 Location: Midlands UK
Posted: Sat May 12, 2012 10:24 am Post subject: |
Have you done a hard reset of the 910?
That would usually fix most problems.
Paper clip in bottom pin hole. _________________ GO 620, Tomtom Android EU,
Garmin 2548LMT-D; 2599LMT-D |
Merlin2005 Occasional Visitor
Posted: Sat May 12, 2012 11:43 pm Post subject: |
@ Oldboy
I have a 910 here that my son knocked off a shelf while it was connected to the holder and he's snapped the charging connector off the board. The PCB appears to be OK but the connector has some broken pins, therefore I need a scrap board to desolder the charging connector, to replace it on my 910.
Woould you be prepared to part the board out and how much would you want for it?
Thanks |
Posted: Sun May 13, 2012 7:27 am Post subject: |
Merlin2005 wrote: | The PCB appears to be OK but the connector has some broken pins, ... | It's the Connector that is the problem on mine. I tried re-soldering, but even with the smallest soldering iron I have (and it's very small), I gave up.
But if you want to go ahead, and have a go, just PM me your address and I'll pop it in the Post to you.  _________________ Richard
AliOnHols Pocket GPS Verifier
Posted: Sun May 13, 2012 8:30 am Post subject: |
lostgerry wrote: | ............ I dont think i could do this ? (I'm 66 and fingers like bananas )
If you are still struggling, these people have had good reviews from members in the past. Based in N London with a workshop which is open to the public by appointment but most of their business is postal.
http://satnavrepairservice.com/faq.html _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Posted: Sun May 13, 2012 11:22 am Post subject: |
@ Oldboy
You have a PM. It's possible that between the two broken connectors, I may be able to cannibalise one good one.
Thanks.  |
Posted: Mon May 14, 2012 10:22 am Post subject: |
Oldboy wrote: | The delay is typical of a 'cold start' for GPS reception.
If you PM me your address I can send you the aerial module from my broken 910, and you can give that a try. |
Oh I see
thanks Richard thats brilliant have sent you a PM |
Posted: Mon May 14, 2012 11:06 am Post subject: |
lostgerry wrote: | ... have sent you a PM | Nothing so far.  _________________ Richard
Posted: Mon May 14, 2012 11:06 pm Post subject: |
??? must have been another blooming senior moment ? dunno what I did wrong I tried it again  |
