| Author |
matthewj Frequent Visitor
Posted: Mon May 21, 2012 12:47 pm Post subject: Embedding power |
We just bought a new (to us) car and I'm pondering embedding the TomTom 740 power supply again. In the last car I embedded a cigarette lighter and stuck the TomTom cable into that and the USB part popped out at the right location. I think I'll have the car supplier fit this, so it would make sense to use the TomTom embedding item. However, it appears that the new TomToms are not compatible, so maybe I don't do anything at all.
Thoughts? |
| Back to top |
Darren Frequent Visitor
Posted: Tue May 22, 2012 9:12 am Post subject: |
Not sure I understand your issue? New TomTom's still use USB cables which plug into a USB cigarette lighter adapter/charger.
So, if you have USB in your car, or a cigarette lighter socket, either the factory fit, or one hidden in a more convenient spot, then you're good to go? _________________ Darren Griffin |
| Back to top |
Posted: Wed May 23, 2012 10:12 am Post subject: |
| USB does indeed seem to be the common power form now. But I was hoping to be able to bury the cable in the dash, with just a few cm visible for connection. But that connector varies of course, which is a pity. |
| Back to top |
AliOnHols Pocket GPS Verifier
Posted: Wed May 23, 2012 5:09 pm Post subject: |
Have a search on Amazon, etc. for Universal Car Charger. They come with a multitude of different push-in-heads to suit different devices. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
| Back to top |
Posted: Thu May 24, 2012 10:33 am Post subject: |
| AliOnHols wrote: | | Have a search on Amazon, etc. for Universal Car Charger. They come with a multitude of different push-in-heads to suit different devices. |
An interesting experiment - until you include "tomtom 1005" in the search, at which point there are no chargers at all (for me). Choosing a non-standard connector makes the newer PNDs quite unattractive. |
| Back to top |
| Back to top |
Posted: Thu May 24, 2012 12:48 pm Post subject: |
Thank you Darren - I thought it was a thing you stuck up through the dock, but a proper fitted one solves that issue. I shall have them fit one I think. TVM.
[edit]
So, to be clear, the http://www.tomtom.com/en_gb/products/accessories/chargers-connect-cables/usb-charging-cable/ would work with the 1005 etc, even though it doesn't say so, with the active dock.
(edited again to not be such a prat with my URL and quotes!)
| Back to top |
Posted: Thu May 24, 2012 1:09 pm Post subject: |
Go 1000 and 1005 share the same mount. The link I gave shows 1005 as compatible. _________________ Darren Griffin |
| Back to top |
Posted: Thu May 24, 2012 5:50 pm Post subject: |
| Another option is the Brodit iPhone "ball" attached to the mount supplied with your device then bury that cable and connect it to a hidden ciggy socket under the dash, this is something both Darren and myself did with the Go-1000 units some time ago as I recall - It does involve taking the supplied mount to bits but I have pictures covering how to do this on the computer if you need a guide - Mike |
| Back to top |
Posted: Fri May 25, 2012 11:54 am Post subject: |
| I embedded a ciggy cable in our old car, but removed it. This one I intend to leave in the car, and feel that it should be done "properly" if I'm going to be happy selling it. |
| Back to top |
| Back to top |
