Pocket GPS World :: View topic - Go 520 No map found
Go 520 No map found
rf065
PostPosted: Wed May 30, 2012 7:39 pm    Post subject: Go 520 No map found Reply with quote
Just updated my map on my Go 520 and it now says No maps found, tried to reinstall my back up from Tomtom Home, but still comes up with the same message. Is there an easy way to get my map back?
Russ
PostPosted: Wed May 30, 2012 8:52 pm    Post subject: Reply with quote
Using Windows Explorer, can you see a Map Folder? It might be called United Kingdom & ROI.
If you can, go to Switch Maps. Are you offered a Map to Select?
If so Select it.
Otherwise, if you downloaded a New Map, HOME can ADD it to the Device, or should be able to.
Select Add Traffic, Voices, Safety Cameras, etc and then Items on my Computer. There should be at least one Map available.
TT Via 135 App 12.075: Europe Map v1165
rf065
PostPosted: Thu May 31, 2012 8:06 pm    Post subject: Reply with quote
The only screen on the tomtom is the no maps found screen. I cannot go beyond this screen. I can find a Tomtom folder on the computer with map files, can one of these be reinstalled on the tomtom?
Russ
PostPosted: Thu May 31, 2012 9:17 pm    Post subject: Reply with quote
You mentioned that you have updated the Map.
The Map is stored on the PC.
If you connect the 520 to HOME you can add this Map to your 520.
The only other problem you might have is that you may be using an old Navcore. How old was the previous Map? And the Navcore, if you can remember.
technik
PostPosted: Thu May 31, 2012 10:16 pm    Post subject: Reply with quote
I would guess this is what happens when using illegal maps?
Is the OP using a map registered in his/her name and have a receipt?
Otherwise OP is not using correct version of Navcore.
GO 620, Tomtom Android EU,
Garmin 2548LMT-D; 2599LMT-D
rf065
PostPosted: Fri Jun 01, 2012 5:55 am    Post subject: Reply with quote
Illegal maps?
I paid for a years map update from tomtom, tomtom home said a new map was available and down loaded it, as I have done for the last 6 months or so.
When I connect to tomtom home, it still recognises the 520 and tells me that mapshare updates are available, it will still download & apply them. But once done, the 520 will only go to a white screen with no maps found message. It will not go beyond this screen.
If I go to the add items on tomtom home, I can see that I have 1 map on the 520, which is UK & Ireland, but if I go to add maps from computer it only lists a western europe map which is for my works tomtom and registered under a different e-mail address?
Russ
PostPosted: Fri Jun 01, 2012 6:34 am    Post subject: Reply with quote
I think you'll need to update the Navcore (software).
To save me a lot of typing, Embarassed I'll point you to This Post by Andy_P.
rf065
PostPosted: Fri Jun 01, 2012 6:42 am    Post subject: Reply with quote
Thanks Richard.
Russ
PostPosted: Fri Jun 01, 2012 10:57 am    Post subject: Reply with quote
Also try running the "Clear Flash" utility on the TomTom.
See here for details and download link.
Some suggest you run it THREE times one after the other, I don't know why, but it does no harm to try....
Don't expect to see much happening when you run it.
"Settling in nicely" ;-)
rf065
PostPosted: Fri Jun 01, 2012 4:22 pm    Post subject: Reply with quote
I'll try clear flash as well, I think I used it before when I had problems with the bluetooth & phone calls getting stuck in a loop, it was never a permant fix though.
Russ
rf065
PostPosted: Fri Jun 01, 2012 7:41 pm    Post subject: Reply with quote
Thanks to all the advice guys, tried clear flash 3 times, no difference. Deleted all but the yellow folders and connected to home which updated the software, but still no map found. Tried connecting to home a further 3 times and each time it said using the wrong version and downloaded another update, but still no maps found.
Eventually, on the last update, my maps are back! Only strange thing is that though my maps are UK & ROI, home is now saying I have French camera updates to download? If I attempt to download them it states an internal server error has occured?
Version no is now 9.430 and maps are showing a 2d 3d button that i did not have before, I assume these are the latest versions?
Russ Laughing Very Happy Laughing
dhn
PostPosted: Fri Jun 01, 2012 8:10 pm    Post subject: Reply with quote
That is correct. The 2D/3D button appeared with the latest (9.430) app.
rf065
PostPosted: Fri Jun 01, 2012 8:27 pm    Post subject: Reply with quote
Thanks, nice to know I now have the latest software.
How do I update to the same version on my works tomtom one new edition? Can it be done without deleteing any files?
Russ
dhn
PostPosted: Fri Jun 01, 2012 8:51 pm    Post subject: Reply with quote
Just connect it to Home and 'update my unit'. If there is a new app to be offered for that device, it will......
rf065
PostPosted: Fri Jun 01, 2012 9:02 pm    Post subject: Reply with quote
Tried it already but it never went to 9.430 like the other one has? Both tomtoms use UK & ROI maps and map update service?
Russ
24.041 (01 Apr 26)
