Kremmen Pocket GPS Verifier
Posted: Wed Jan 02, 2013 3:28 pm Post subject: Garmin CSV to GPX Converter |
I have developed a utility to convert the Garmin PGPSW camera files to the Garmin supported GPX format.
The reasons behind this are:
1) To overcome/reduce the Garmin default 36 second advance warning.
2) To avoid the situation where there is no warning, usually because you are below the speed limit and not accelerating.
3) To remove continual back to back warnings (e.g.Motorways) because the Garmin is not directional for user created POI's.
4) More recently there is a warning banner change facility but this should be used with caution on Garmins as it stops other features from working. These are mentioned in the change text screen.
5) Separate Redlight, Gatso and RedSpeed cameras with appropriate icons and sounds.
Latest versions:
**Download CSV Converter V1**
Version 2 :
**Download CSV Converter V2**
Installation:
Unzip the package somewhere unique and follow the instructions in the help file which can be viewed before installation.
I've been using this program since the middle of 2011 without issue so I'm confident it is fit for purpose.
#kremsearch _________________ Lets be careful out there !
walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 494 Location: South Yorkshire
Posted: Sun Jan 06, 2013 1:57 pm Post subject: |
ok - giving this a test - installs fine on windows 8
could do with being able to change the working directory
will upload to my 2390 and see how it performs tomorrow, compared to using ash's camera manager
i may need to change the bitmaps as last time tried over 22x22 on the device it didn't like it |
Posted: Mon Jan 07, 2013 7:36 am Post subject: |
Ok thanks
Once you've used it, if you still think a user defined working directory is the way to go I'll work on it. _________________ Lets be careful out there ! |
Posted: Tue Jan 08, 2013 10:48 pm Post subject: |
Kremmen wrote: | Ok thanks
Once you've used it, if you still think a user defined working directory is the way to go I'll work on it. |
this worked a treat - I just got to change distance warning so a bit longer, rather than when near enough on top of the camera (ie 200 yards) - so will try different settings.
I swapped the voices for the ones with the 3 beeps at the beginning as I prefer these.
The icons displayed fine, but I need to see if can use similar to the ones from camera manager (but they are 22x22) as not bothered about it displaying the speeds as the voice alerts tell me.
I also found the app to generate the output a lot faster than CM as well.
But definitely would like t to have a user defined working folder, as I store all my data on a hybrid drive or network and not the os and app installation drive.
Not sure what you program in, but it's usually a simple command to open the dialog box and select a folder
Overall though the app is very good |
Posted: Wed Jan 09, 2013 7:40 am Post subject: |
Thanks for the feedback.
I program in VB2010 at home and VB2012 in the office (plus VB6 and COBOL in the office). I would have upgraded at home but the Visual Studio 2012 is heavily into Win8 and therefore more akin to touchscreen which I don't like. I upgraded to MapPoint 2013 recently and that is the same with large black and white finger size buttons. Colour menus and buttons seems to be a thing of the past with M$. I've avoided Office 2013 for the same reasons.
Changing the working directory and holding it in the .ini file will not be a problem but give me a bit of time as I have a large project on the go at the moment.
ps: Also in the working folder/directory is the .ini file and a .log file, just in case there are problems. _________________ Lets be careful out there ! |
Posted: Wed Jan 09, 2013 12:22 pm Post subject: |
I've done a bit in VB6, 2010 and Delphi 6 - many years ago used to program in assembly language (that was fun)
Why not use the registry to store information instead of an ini file? |
Posted: Wed Jan 09, 2013 1:21 pm Post subject: |
I like to be able to get at both the ini and log files for any debugging, just my personal preference.
I need to work out the best way to allow user selection of the working directory as the old VB6 components of drive /directory / files are no more, and I don't want to call in the COM component to include them.
I've backed out VS2012 here in the office and I'm now running VS2010 so I've got compatibility both here and home. Just need to find the time now .......... _________________ Lets be careful out there ! |
Posted: Mon Feb 11, 2013 10:32 pm Post subject: |
As Kremmen has been busy lately, I have with his permission been updating his CSV to GPX Converter and PGPSW have agreed to host it.
I have made some changes mainly to the code and also some of the menu options have been changed
if you are interested in testing or using it, it can be downloaded from
All feedback is welcome
thanks
Walkerx |
Andy_P Pocket GPS Moderator
Posted: Tue Feb 12, 2013 1:39 am Post subject: |
Hi walkerx (and Kremmen!)
It all looks very clever, I really wish I knew how to code.
But just looking at your screen shots from the PGPSW cam-data side of things....
I just wondered why the Gatso, SPECS and Mobile "TBA" sections were missing? (and there's SPECS "var" too now) _________________ "Settling in nicely" ;-) |
Posted: Tue Feb 12, 2013 11:50 am Post subject: |
That's my fault.
For my personal preference I don't want to be warned of TBA stuff and I remove them during the conversion. If the majority verdict is to include them, probably as an option, then that would be quite straightforward.
I think walkerx has done a mighty fine job slimming it down and I look forward to testing the final version myself now it's reached that stage. _________________ Lets be careful out there ! |
Posted: Tue Feb 12, 2013 8:02 pm Post subject: |
Andy_P wrote: | Hi walkerx (and Kremmen!)
I just wondered why the Gatso, SPECS and Mobile "TBA" sections were missing? (and there's SPECS "var" too now) |
Kremmen wrote: | That's my fault.
I think walkerx has done a mighty fine job slimming it down and I look forward to testing the final version myself now it's reached that stage. |
I'm going to update it so you can choose whether or not to include the unknown cameras and also ensure it pulls in the data for the specs variable cameras (as it adds them for the gatso one's).
Also looking at the over-speed section to give you the option of including in main or separating them (similar to Ash's Camera Manager), as on some Garmins (mine including) if in same file it won't display the icon's on the screen.
update: I've just gone painstakingly debugging why the TBA cameras weren't been adding when included in the run and found that most are duplicates of confirmed cameras and thus no need to be added again.
I did find a couple of other bugs which I've near enough ironed out, but as it's getting late and i'm tired I off to bed in a moment, so won't be doing much more tonight
regards
Walkerx |
Posted: Wed Feb 13, 2013 8:58 pm Post subject: |
The application has been updated
The updates include:
Fix for incorrect number of cameras read
Inclusion of specs variable speed cameras
Inclusion to include unverified speed cameras
Use settings from previously installed version
Update can be downloaded from |
Posted: Sat Feb 23, 2013 10:27 pm Post subject: |
New update released
This update has some from Kremmen and myself
you can download from
Changes to the speed camera choices layout
Changes to the menu options
Hope you all enjoy and all feedback appreciated |
Posted: Sun Feb 24, 2013 7:15 am Post subject: |
Over the last week I've been the 'tester' for walkerx's enhancements.
I'm confident that this latest version is rock solid and will provide far better control over both approaching a PGPSW camera and notification when still over the known limit.
As above, all feedback welcome  _________________ Lets be careful out there ! |
AliOnHols Pocket GPS Verifier
Posted: Sun Feb 24, 2013 11:04 am Post subject: |
It looks brilliant Kremmen & walkerx, it makes me wish I had a Garmin so I could start using it.
When something like this is made available it makes you realise that there are some very clever people about. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
