Pocket GPS World :: View topic - problem loading a route to a Dakota 20
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
lepidas
PostPosted: Mon Feb 11, 2013 10:14 am    Post subject: problem loading a route to a Dakota 20 Reply with quote
Hi to all, I'am new to handheld gps and found this foroum searching the internet searching for a sollution for a problem I have.
My Dakota 20 handheld won't load some routes and I don't know why, for example this route http://www.hellaspath.gr/misc/pt2gpx.php?trk_id=76
some routes are loaded ok, some not.
Any idea what's wrong?
Thanx in advance for any replies.
George
PostPosted: Mon Feb 11, 2013 12:32 pm    Post subject: Reply with quote
That's a track not a route but it loads fine onto my PC. If you've been looking for it in Route Manager rather than Track Manager that will explain why you don't see it. It also has quite a long file name, I'm not sure if the Dakota will cope with that so if you can't find it in Track Manager either try a shorter name.
lepidas
PostPosted: Mon Feb 11, 2013 1:28 pm    Post subject: Reply with quote
Sorry for my bad English but it's not my native language. You are right, I meant "track" and not "route".
I discovered that the Dakota can load tracks from
http://en.wikiloc.com/wikiloc/home.do
but can't load tracks from this site
http://www.hellaspath.gr/index.php?p=2
is there an explanation for this? something in the .gpx file perhaps?
PostPosted: Mon Feb 11, 2013 1:52 pm    Post subject: Reply with quote
That track you posted worked fine for me, have you tried entering it with a shorter name?
lepidas
PostPosted: Mon Feb 11, 2013 2:23 pm    Post subject: Reply with quote
Well I found out this,
it has something to do with the character encoding of the .gpx file.
Name length is ok in all cases, it's ok to have a long lenghted name.
Now I understand I have to change something in Dakota settings menu that has to do with character encoding or language (my prefered language is English though), any idea;
PostPosted: Mon Feb 11, 2013 2:27 pm    Post subject: Reply with quote
Sorry no, not heard of that before.
The track you posted works fine in Basecamp. Why don't you try loading it into Basecamp (available here http://www8.garmin.com/support/download_details.jsp?id=4435 ) and then send it from Basecamp to your Dakota?
dales
PostPosted: Mon Feb 11, 2013 2:31 pm    Post subject: Reply with quote
That track you posted worked fine for me, in Memory-Map on the PC.
But it would not show up in my Oregon handheld, no matter how I renamed it.
When I sent it from Memory-Map to the Oregon it worked fine.
If I open the two files in Excel, I see that the one that works in the Oregon has far fewer columns. All of the Bounds columns are absent, as are the columns for Time and Trk/Desc. There are other smaller differences as well, which I can itemise if necessary.
Hope this helps.
Dales.
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
dales
PostPosted: Mon Feb 11, 2013 2:47 pm    Post subject: Reply with quote
I doubt if it's anything to do with character encoding.
I cleared the contents of column N (which was all Greek) and the track still wouldn't display.
I changed the language of the Oregon to Greek, and the track still wouldn't display. (I then had the task of navigating a menu in Greek, to reset it back to English!!).
I think the easy answer is to pass the track through BaseCamp or Memory-Map, down to your Dakota.
Dales.
lepidas
PostPosted: Mon Feb 11, 2013 3:33 pm    Post subject: Reply with quote
Well I use Ubuntu Linux so BaseCamp or Memory-Map are not compatible with my system.
But I solved the problem, here is how.
the first line of the file mustn't be
?xml version="1.0" encoding="ISO-8859-7" ?
but must be
?xml version="1.0" encoding="UTF-8"?
to show the titles that are in Greek letters
lepidas
PostPosted: Mon Feb 11, 2013 3:37 pm    Post subject: Reply with quote
so, each time I want to load a track to my Dakota I will have to edit the first line as above.
It's ok for me, quite fair I think
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
23.094 (24 Sep 25)
