Pocket GPS World :: View topic - Garmin GPS 17N and Pocket PC .....
kostis100
PostPosted: Tue Aug 24, 2004 1:44 pm    Post subject: Garmin GPS 17N and Pocket PC ..... Reply with quote
Can i use my Garmin GPS 17N
http://www.garmin.com/products/gps17n/
with .............. 1). (my old) HP iPAQ h1940 Pocket PC
and
with .................2). (my new) Acer n30 Pocket PC ?
Are there any cables for that ?
PostPosted: Tue Aug 24, 2004 3:57 pm    Post subject: Reply with quote
It says in the tech specs that the device speaks RS232. So technically you can connect it to a COM port on a Pocket PC.
Now for the bad news. The 1940 doesn't have a COM port. (only USB). And - neither does the Acer!
So the only way you can accomplish this is to buy one of the serial GPS receivers that are specifically suited for the 1940 or the Acer (because their cable contains a USB to serial converter) , cut the cable and connect your Garmin instead.
Now wait, why would you do that when you have just bought a working combination?
kostis100
PostPosted: Mon Sep 13, 2004 11:03 pm    Post subject: Reply with quote
there is a serial cable for Acer n30 http://www.mobiledatadirect.co.uk/product_info.php?products_id=1522
............if i use it can i connect the Acer n30 with Garmin 17n ?
Pc-Mobile
PostPosted: Tue Sep 14, 2004 2:55 pm    Post subject: Reply with quote
Most likely you can.
I have not used/tested an Acer N30 so do not know what sort of com port it has.-- not all com ports are the same. If it has a true RS232 com port you should have no problem.
Pc-Mobile
http://pc-mobile.net/gps.htm
kostis100
PostPosted: Tue Sep 14, 2004 5:42 pm    Post subject: Reply with quote
what about the HP ipaq 2210 pocket pc ? can i connect it with Garmin 17N? do you have data( serial) and power cable ?
Pc-Mobile
PostPosted: Tue Sep 14, 2004 7:06 pm    Post subject: Reply with quote
I forgot to add that you do need a null modem adapter between the 2 serial cables.
We have cables for Ipaq 2210.
PQ8SMP is a "serial interface" which you can connect to a serial device like a GPS (connects to the PC serial cable of the GPS, no null modem adapter is necessary).
It also allows you to power the Ipaq with appropriate car adapter if you already have one. If not then add CKUC (car adapter/cable for use with PQ8SMP).
http://pc-mobile.net/pdaserial.htm
Pc-Mobile
kostis100
PostPosted: Wed Sep 15, 2004 8:18 am    Post subject: Reply with quote
can i found the cable in Europe ?
Pc-Mobile
PostPosted: Wed Sep 15, 2004 6:44 pm    Post subject: Reply with quote
WE ship to anywhere in the world, if that was what you meant.
Pc-Mobile
24.041 (01 Apr 26)
