Pocket GPS World :: View topic - Deleted a file in Error
Goto page Previous  1, 2
keithmillar
PostPosted: Tue Sep 03, 2013 5:39 pm    Post subject: Reply with quote
This is what I'm looking at....I can pick the voice I want to install but no TTS
Keith
Edited by MaFt - image was too wide ;)
Keith
Garmin 3598LTM-D
Android CoPilot
Navigon 72 Plus Live
TTGO540
PostPosted: Tue Sep 03, 2013 7:23 pm    Post subject: Reply with quote
Only reason you would not be offered them would be because they're already installed. Have you checked to see what voices are listed on your nuvi?
keithmillar
PostPosted: Tue Sep 03, 2013 7:32 pm    Post subject: Reply with quote
I have these 4 voices -
English_British_Daniel, James, Kate and Serena.vpm
I'll try and reinstall these voices and see if this does anything
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
keithmillar
PostPosted: Wed Sep 04, 2013 9:09 am    Post subject: Reply with quote
Thinks have now a bit strange Confused .... had no voice at all this morning when i used the unit. My voice had been set to Kate from my list, but i noticed that i only had 3 choices to choose from.....Kate or James or English British.
I then selected English British and i now have a voice but again i don't have the TTS as well.
When i looked on the folder after connecting the unit to my computer i had 5 English British voices to choose from - 4 named voices and English British
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
PostPosted: Wed Sep 04, 2013 9:59 am    Post subject: Reply with quote
Strange indeed. You can tell the TTS voice files as they are way larger in size than the normal voices. Are all the voice files you see around the same size?
WebUpdater will show/replace any missing files. As it hasn't either they are there and not working or there is another problem.
Can you look in the Garmin directory on your nuvi? There should be a GarminDevice.xml file there. What size is it? If 0kb delete it, in fact delete it regardless of size, then disconnect the nuvi from your PC then reboot the nuvi. Switch it off and reconnect it to the PC. The .xml file should be somewhere in the region of 50kb, check it now is. The reason for this is that sometime this file can become corrupted, and it's that file that holds details about your nuvi. Deleteing it forces the nuvi to recreate it.
Now try WebUpdater again.
Of course you said you had a back up, so copying all the voice files from your back up onto your nuvi should also resolve the issue Smile
keithmillar
PostPosted: Wed Sep 04, 2013 10:13 am    Post subject: Reply with quote
Thanks sussamb, i'll give it a go tonight, and let you know the outcome.
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
keithmillar
PostPosted: Wed Sep 04, 2013 7:16 pm    Post subject: Reply with quote
Well I've removed the GarminDevice.xml file and it can back, as you said it would and the size is 38kb.
I've also ran by back up as well - will see how things go in the morning but my Voice Folder does not show voices with TTS after them
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
keithmillar
PostPosted: Wed Sep 04, 2013 7:58 pm    Post subject: Reply with quote
Done It...Yes.....Normal service has been resumed Very Happy Laughing
Thank you for your help
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
PostPosted: Wed Sep 04, 2013 8:39 pm    Post subject: Reply with quote
Great.
Page 2 of 2
24.041 (01 Apr 26)
