| Author |
citroen999 Occasional Visitor
Posted: Tue Sep 17, 2013 11:23 am Post subject: Garmin OSM issue.. please help |
hi
just d/l USA file and Canada file from http://www.osmmaps.com/
put usa on the SD card in folder named garmin, my sat nav wont recognize it.
i then deleted the USA file and put canada on and my sat nav found it..
my sat nav is a garmibn nuvi 610t
any ideas what i amdoing wrong? |
| Back to top |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Tue Sep 17, 2013 11:52 am Post subject: |
Possibly a corrupt file, it's not unknown. Download the US one again and see what happens.
Incidentally the earlier nuvis were fairly strict when it came to map filenames. What names are you using? gmapsupp.img will work, so if your US map isn't called that try renaming it to see if it's recognised.
Also note that there's a limit on the number of map tiles that some GPS can read. Some OSM maps can be made up of many tiles so I guess it's possible that the US map exceeds the allowable limit, in which case you'd have to split it into two.
I also seem to recall that the earlier nuvis were limited to map sizes of 2Gb, although this was changed with a software update. If your software isn't up to date you could try doing that also, as the US map will be well over 2Gb. |
| Back to top |
Posted: Tue Sep 17, 2013 12:39 pm Post subject: |
thanks for that.. software is upto date...
so i'm a bit stuck |
| Back to top |
M8TJT The Other Tired Old Man
Posted: Tue Sep 17, 2013 12:46 pm Post subject: |
| But have you actually tried the re-naming as suggested? |
| Back to top |
Posted: Tue Sep 17, 2013 12:59 pm Post subject: |
| M8TJT wrote: | | But have you actually tried the re-naming as suggested? |
complete noob... not sure hwo to do it... i can rename i file or folder but that hasnt worked |
| Back to top |
Posted: Tue Sep 17, 2013 1:05 pm Post subject: |
What filename does the US map have?
If it's not gmapsupp.img right click the file then select rename, rename it as gmapsupp.img, see if it then works.
Incidentally the file comes as a zipped file, I assume you've unzipped it?
Edit: since posting this I've downloaded the file and it works fine on my 1490, so I suspect yours may have corrupted while downloading IF you've named it correctly, it's in the correct folder on the card and you've selected it in Settings, Map, Map Info |
| Back to top |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15506 Location: Bradford, West Yorkshire
Posted: Tue Sep 17, 2013 4:03 pm Post subject: |
Will you be driving across the whole of America? Or just a few states? If the latter then how about just downloading the sates you will be driving in?
I do that for European mapping - I may be allowed to download the whole of Europe but in reality the countries I would download are UK, France and Spain to save space on a device. |
| Back to top |
Posted: Tue Sep 17, 2013 4:21 pm Post subject: |
I thought that too ... but the map comes 'as is'
It may be possible to install it to a PC so that you could split it using Basecamp or a similar program, but given the OPs comments I felt it wasn't worth trying that until we've exhausted all other options  |
| Back to top |
| Back to top |
