| Author |
patsimpson Occasional Visitor
Posted: Sat Jan 25, 2014 12:03 pm Post subject: Kenwood DNX4210BT |
| I have downloaded my Garmin p9psw - speed camera nv3rn(12-014) to a memeory stick and now connected it to the Kenwood computer in my Mitsubishi L200 Barbarian. It says it is 'reading.....'. After 30 minutes it is still 'reading....' What's wrong? Pat S. |
| Back to top |
Posted: Sat Jan 25, 2014 5:40 pm Post subject: |
The Kenwood installation guide is here
Give it a go after reading that. |
| Back to top |
sgould Frequent Visitor
Posted: Sat Jan 25, 2014 9:04 pm Post subject: |
That Kenwood guide is out of date…
I have the similar DNX-4210DAB. It took a few goes to get it right. I'll try and look up what I did.
But also be aware that I have had some problems with my installation. The front speakers occasionally do not recover the sound after muting for the navigation command. I have been advised that this is due to adding voices to the PoIs. I'm going to check this at the next PoI upload.
Are you using the Kenwood KCS-IP202 cable http://www.justkenwood.co.uk/car-audio.aspx/kca-ip202-adaptor
If you aren't, the USB connection may not work. I don't know why. I have the cable and it did work eventually. It may have been down to the need for exact file names, including upper case/lower case letters. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
| Back to top |
Posted: Sun Jan 26, 2014 1:36 am Post subject: |
I've had a look at what I did the last time. And I remembered.
I used a completely blank USB stick with nothing else on it. It worked after this, but I did some other things at the same time, so a blank stick may not be necessary.
I tried all the written stuff, but in the end with a blank USB stick and allowing the Garmin PoI Loader application to create and establish all the folders and files, it went OK.
http://support.garmin.com/support/searchSupport/case.faces?supportPage=POI%20Loader&caseId={16d895d0-2fe6-11de-76c5-000000000000}&locale=en_GB _________________ TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
| Back to top |
| Back to top |
