| Author |
bothybob Occasional Visitor
Posted: Tue Feb 25, 2014 8:01 pm Post subject: Garmin Oregon 450 versus Veiwranger |
I decided to test the accuracy and any variation between the above devices
Using both I zeroed and set trip, after a short walk the viewranger registered 6.35 miles taking 1.59.05, the Garmin was 5.34 taking 2.00 , a difference of 1.1 miles
I consider the results from the Viewranger to be the most accurate
Any ideas on why such a variation |
| Back to top |
AliOnHols Pocket GPS Verifier
Posted: Tue Feb 25, 2014 9:26 pm Post subject: |
Possibly due to loss of or the sensitivity of the gps signal reception. Are you able to zoom in on the traces of your walk on both devices? If so, is one device showing a nice, smooth trace of your walk while the other is a bit jagged as it jumps around due to a bad satellite lock.? _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
| Back to top |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Tue Feb 25, 2014 11:11 pm Post subject: |
Why do you consider the viewranger the most accurate?
I use both a GPS and Viewranger on a smart phone, and generally there is little overall difference when following routes, although the GPS is more accurate when determining an exact location. |
| Back to top |
M8TJT The Other Tired Old Man
Posted: Tue Feb 25, 2014 11:53 pm Post subject: |
| sussamb wrote: | | Why do you consider the viewranger the most accurate? | Perhaps the OP knew that he had walked 6.35 miles. If the GPS location jumps about, surely it will indicate a greater distance than you actually cover? |
| Back to top |
Posted: Wed Feb 26, 2014 7:59 am Post subject: |
Correct, it's rare for a GPS to 'under read' hence my query  |
| Back to top |
| Back to top |
