Pocket GPS World :: View topic - Nissan connect - unable to download speed cams
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Nissan Connect
witanet
PostPosted: Sun Apr 27, 2014 3:19 pm    Post subject: Nissan connect - unable to download speed cams Reply with quote
I am unable to add speed cams to my system although I followed installation instructions. The system does not read files recorded on the memory stick at all. I have current model NISSAN QASHQAI (here in Ausralia called DUALIS). What am I doing wrong?
Mark
PostPosted: Sun Apr 27, 2014 5:27 pm    Post subject: Reply with quote
Hi Mark and welcome to TG forums. I can't help you directly, but there is loads of posts about the Nissan Quashthingy. Try a search for NISSAN QASHQAI and check the 'Search for all terms' check box. I'm not certain if there is an answer there, but I feel certain that someone who knows about these things will be along in a bit.
If you have followed the instructions, it would be useful if you could tell us at what point 'it doesn't work'
witanet
PostPosted: Mon Apr 28, 2014 7:42 am    Post subject: Reply with quote
My problem has been resolved. I used different memory stick and it worked this time.
PostPosted: Mon Apr 28, 2014 8:00 am    Post subject: Reply with quote
I'm pleased for you. It's also good to know that the stick makes a difference.
peasemore
PostPosted: Thu May 22, 2014 11:50 am    Post subject: Nissan Connect Reply with quote
Query from long time TT user, but now with new Qashqai;
so this database is d/loaded on memory stick, and goes nowhere near the SD card then, and then integrates with the Nissan/Navteq/Bosch built in sat nav?
Does it then get permanently migrated into the Nissan system, or does USB stick need to be inserted each time you want to use?
Appreciate has to be for each update.
(I was intending to back up SD card, but probably won't due to threats/hints it will work in no other device, may damage..doubt that!) Surprised
Thanks in anticipation.
Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve.
PostPosted: Thu May 22, 2014 11:58 am    Post subject: Re: Nissan Connect Reply with quote
Go on. Back it up. You know it makes sense. It probably won't work on a different SD card and probably will in a different car. If it screws up, at least you will be able to re-instate the software on the original SD.
As to your other questions. You'll have to wait for an expert.
ntec87
PostPosted: Fri Jul 25, 2014 1:20 pm    Post subject: Reply with quote
I managed to down load the database but as I am driving along, nothing seems to be happening. The inbuilt Nissan alerts sound but nothing appears on the screen from the pocket gps world system. In my last car the system worked perfectly with the connect system. Any ideas?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Nissan Connect All times are GMT + 1 Hour
23.122 (10 Dec 25)
