Pocket GPS World :: View topic - Just subscribed, which system to select?
chrisw99
PostPosted: Fri Mar 22, 2013 4:44 pm    Post subject: Just subscribed, which system to select? Reply with quote
Just subscribed, so now have the dropdown to select the system and I can see there is a "Nissan Connect" and a "Nissan Connect (old)".
I've downloaded both, but what is the difference and which should I be using? My car is a Sept 2009 Qashqai.
Cheers,
ChrisW
PostPosted: Fri Mar 22, 2013 6:53 pm    Post subject: Reply with quote
Personal preference really.
They just have a different format for the text on the screen. They both work and give the same warnings, just the text is slightly different.
chrisw99
PostPosted: Sun Mar 24, 2013 7:28 pm    Post subject: Reply with quote
Thanks, downloaded both and can see the different text versions.
I was confused because there are two models of Nissan Connect, firmware 1.0 and 1.5 (built in speed cams).
I assumed as the dropdown question was Select your system, it was asking which I had...
peasemore
PostPosted: Thu May 22, 2014 4:56 pm    Post subject: Problems downloading onto Nissan Connect Reply with quote
Tried 4 USB sticks to date, but getting same grief in each case Sad
Initially on insertion screen shows "No Audio Files" which is correct.
Selecting Set Up/Navigation & POI's, then selecting DOWNLOAD MY POI's, which I assume is right option, in each case system says there are no POI files on this device ie the USB stick.
I've followed he detailed instructions, and even modified folder name from .myPOIs to MyPOIs as that's what Nissan shows on Screen, but made no difference.
Will persevere/ post back [/b]
Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve.
PostPosted: Thu May 22, 2014 6:22 pm    Post subject: Reply with quote
You have unzipped the file(s) haven't you?
No insult intended. It's a fairly common mistake.
peasemore
PostPosted: Thu May 22, 2014 9:26 pm    Post subject: Nissan Connect Reply with quote
yes!!
Have finally found usb where it did run; hooray Laughing
Gel
loubrown
PostPosted: Fri Oct 03, 2014 5:58 pm    Post subject: Reply with quote
I have just picked up my new Juke today and am having the exact same issue as peasemore above, where the screen states 'No Audio Files'. I had a juke prior to this one and used these speed camera alerts perfectly fine, but this car has the new Connect system, so not sure if there have been some compatibility issues. Interestingly, No Audio Files comes up irrespective of whether a USB stick is installed or not. I have also tried another USB stick and receive exactly the same message. Any help would be appreciated!
loubrown
PostPosted: Fri Oct 03, 2014 6:40 pm    Post subject: Reply with quote
For anyone else's future reference, I tried four USB sticks (thankfully my partner is a geek and we had plenty) and the fourth one appears to have worked!
PostPosted: Mon Oct 06, 2014 2:06 pm    Post subject: Reply with quote
Out of interest, what size and make were the ones that did and didn't work?
loubrown
PostPosted: Mon Oct 06, 2014 6:43 pm    Post subject: Reply with quote
Although I thought one of the sticks had worked, it seems that it didn't as I am still not receiving the alerts. Am at a bit of a loss as to what to do now.
24.034 (25 Mar 26)
