| Author |
lofty2347 Occasional Visitor
Posted: Fri Sep 19, 2014 10:22 pm Post subject: Road name anouncements |
| I am running igo primo 2.4 on winc6 256 mb. the tts is greyed out so is there anyway of activating the road name announcements? any advice would be appreciated. Lofty |
| Back to top |
M8TJT The Other Tired Old Man
Posted: Fri Sep 19, 2014 10:30 pm Post subject: |
| Yes, buuuut, you need a TTS voice for 2.4. The TTS voices for 2.2 and earlier won't work on 2.4. They generate an 'Invalid voice' (or something like that) error message. suggest you Google around (and if you find one, let me know please) |
| Back to top |
Posted: Thu Sep 25, 2014 6:01 pm Post subject: |
| Hi M8TJT. I am still struggling with tts announcements. I am now using igo primo 2 winc6. I have loaded tts v5 v1 172646 english uk into the voice file. It shows up in the list of voices but when I try to activate it nothing happens and the tts pro is still greyed out. Do I need a voice engine or what to get the street announcements its doing my head in. lofty |
| Back to top |
Posted: Thu Sep 25, 2014 6:53 pm Post subject: |
You say you are NOW using primo 2. Is this different than what you said before? i.e. Primo 2.4?.
Have you got the tts_nua-v5 FOLDER with its contents in the same folder as the primo exe file and Content folder etc are in? |
| Back to top |
Posted: Thu Sep 25, 2014 8:48 pm Post subject: NavNgo igo |
| Hi M8TJT I am now using my old system 2 as the only tts voices I could download were for 2. I downloaded tts v5 v1172646 serena uk english. unzipped the file and put the voices into voice file with no result. By what I think you are saying I should have added the zip file to primo, is this correct? thanks again for your patience. lofty |
| Back to top |
Posted: Thu Sep 25, 2014 9:30 pm Post subject: |
Hi Lofty.
The file in the CONTENT\VOICE folder should look like this "Voice_TTS-nua-eng-uk-f1-lua-dri40-vssq5f22.zip"
As I said before, you also need the tts_nua_v5 folder and its contents in the same folder as the CONTENT folder and the PRIMO V2.0.exe and SYS.txt and Branding.zip files are in
You should have at least the following in the Primo folder
folders
CONTENT
LICENCE
tts_nua_v5
files
Branding.zip
Data.zip
Primo v2.0.exe (or whatever)
SYS.txt
vautov5.dll
This does work with 2.0, but not 2.4 as it needs different TTS files/folders.
You have to have the three things to get the TTS to work
The correct voice zip file in VOICES
The tts_nua_v5 Folder
vautov.dll |
| Back to top |
Posted: Fri Sep 26, 2014 12:02 am Post subject: NavNgo igo |
| You are a star I will give it a go and keep you posted. lofty |
| Back to top |
Posted: Fri Sep 26, 2014 7:24 pm Post subject: NavNgo igo |
| M8JTT you are a wizard it worked like a dream on 2. Now if I opt to use 2 instead of 2.4 can I transfer my 2013 maps from 2.4 to 2? or find tts folders to work with 2.4 I note what you said previously if you find some to let you know so it don't look good although I will trawl the net in the hope of finding the correct tts folders for 2.4. Thanks again for your help and advice. lofty |
| Back to top |
Posted: Fri Sep 26, 2014 8:02 pm Post subject: |
Yes. Just copy the maps from the 2.0 content\map folder to same folder in the 2.4 installation. Or the other way round. The maps will be read properly by all recent iGO versions. I assume that you have got your stuff safely backed up on your computer!
| Lofty wrote: | | M8JTT you are a wizard | Doesn't my avatar confirm that?  |
| Back to top |
Posted: Fri Sep 26, 2014 9:04 pm Post subject: NavNgo igo |
| Cheers mate thats just what I wanted to hear it gives me the best of both worlds. Lofty |
| Back to top |
Posted: Sun Sep 28, 2014 5:35 pm Post subject: NavNgo igo |
| Hi M8TJT. On the off chance I loaded tts_nua_v5 folder and the voices as per your instructions into my version 2.4 and hey presto it worked. I am well chuffed serenas voice is just the job. Thanks again for your help. Lofty |
| Back to top |
Posted: Sun Sep 28, 2014 6:16 pm Post subject: |
| Then I'm pleased that you have got a result (that surprises me) and that I was able to help. |
| Back to top |
| Back to top |
