Pocket GPS World :: View topic - TomTom Go920T EPT
TomTom Go920T EPT
wachkds
PostPosted: Sun Dec 21, 2014 11:54 am    Post subject: TomTom Go920T EPT Reply with quote
Hello, I no longer have EPT nor access to TomTom services via an android smartphone after upgrading my Go920 (now at v9.510 / maps Europe v710) .
Have these features been removed with the new firmware and maps and is it possible to downgrade a GO920 to an earlier version, and in that case which one would be advised and where could I find the old firmware and restore procedure ?
Best
Pierre W
Stecha
PostPosted: Sun Dec 21, 2014 11:52 pm    Post subject: Reply with quote
Have you got an earlier full copy saved on your PC ?
wachkds
PostPosted: Mon Dec 22, 2014 12:11 am    Post subject: Reply with quote
Hello Stecha,
I did a backup when I received the GO920 .
Will the restore fix the issue and is an older OS compatible with the last maps ?
best Pierre W
Stecha
PostPosted: Mon Dec 22, 2014 12:33 am    Post subject: Reply with quote
Sorry I really don't know
Only its the easiest way to go back to earlier versions on your TomTom if you should wish to Smile
PostPosted: Mon Dec 22, 2014 12:48 am    Post subject: Reply with quote
And take a Windows backup of what you have got now before restoring.
wachkds
PostPosted: Mon Dec 22, 2014 10:07 am    Post subject: Reply with quote
Hello,
Thanks for the advices .
Any idea which last version of the TT GO920 OS supported EPT and if there is a site where to download them ?
Best Pierre
dhn
PostPosted: Mon Dec 22, 2014 11:16 am    Post subject: Reply with quote
What are you referring to as EPT?
PostPosted: Mon Dec 22, 2014 10:15 pm    Post subject: Reply with quote
It was a feature of the 920 (not in 720 or 520) which magically figured out the GPS location when you lost your satellites. It flashed up a symbol to say it was in use. I used to get it when I went under the odd bridge or two. Worked off them funny thingies, gyro somethings? "Enhanced Positioning Technology".
http://uk.support.tomtom.com/app/glossary/locale/en_GB
dhn
PostPosted: Mon Dec 22, 2014 11:06 pm    Post subject: Reply with quote
Well, that's what I thought it was, Dennis. That's why the post asking where to download it doesn't make sense.
It was a gyro in the 920/930 models and the 9.510 application had code to interpret the movement.
Thanks for the confirmation.
wachkds
PostPosted: Mon Dec 22, 2014 11:17 pm    Post subject: GO 920 EPT Reply with quote
Hello,
Thank You very much for your feedback .
Do I understand correct that EPT should still work OK with OS ver 9.510 and latest maps Europe v7.10 ?
I am aware that EPT requires a certain route to calibrate and work OK , I will retry it to make sure the non working was not related to my recent update.
Best Pierre W
PostPosted: Mon Dec 22, 2014 11:20 pm    Post subject: Reply with quote
Latest map Europe v710??? That map must be many years old. Latest map is v940.
wachkds
PostPosted: Mon Dec 22, 2014 11:28 pm    Post subject: GO 920 EPT Reply with quote
Ooops I had rebooted the GO920 with the old card ...
The card on sd is well v940.5963 ...
Best Pierre W
23.105 (29 Oct 25)
