| Author |
Pev Regular Visitor
Posted: Sat Feb 21, 2015 11:43 pm Post subject: Transferring routes to Garmin 2460 |
Has anybody used Tyre (itinerary planning software) with a Garmin 2460?
I have previously used it with a Tom Tom and it worked fine but I cannot get it to work with my Garmin. I can transfer the route from my PC but it does not show on my Garmin.
Failing that what is the best method for planning a route on a PC with say Google Maps and then transferring it to my Garmin?
Finally I have am 8gb SD card in my Garmin which is formatted as FAT 32 and recognised by the PC as is my Garmin but I cannot find out how to make use of it as there does not seem to be an option to save routes or maps to the SD card. The internal memory on my Garmin is nearly full and my SD card is empty.
Thanks for any help
Pev |
| Back to top |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
| Back to top |
Pev Regular Visitor
Posted: Sun Feb 22, 2015 8:49 am Post subject: |
Thanks for your reply. I can see the route I have copied from Tyre to my Nuvi 2460lt in the GPX folder but I cannot access it when I have disconnected the Sat Nav from my PC. I have read in another Forum that it takes several minutes for it to appear in Trip Planner. When I copied an 85 mile trip to my Nuvi and left it on overnight only the first section of the trip showed not the complete trip.
I looked at your link but unfortunately there is no icon in Settings or elsewhere for User Data or My Data on my Sat Nav in order to access imported routes.
There must be some way of planning a route on a PC and then transferring that route to my Sat Nav. I could do it fairly easily with my old TomTomGo 700 using tyre but there is no import route facility on my 2460LT |
| Back to top |
Posted: Sun Feb 22, 2015 1:40 pm Post subject: |
The part that applies to your nuvi doesn't mention icons, user data etc. You have a 2400 series so the route will appear under Apps, Trip Planner automatically.
You also have the older style of Trip Planner so will only see the first part of the 'trip', the next part will appear once you get to the end of the first part etc etc. _________________ Where there's a will ... there's a way. |
| Back to top |
Pev Regular Visitor
Posted: Sun Feb 22, 2015 2:14 pm Post subject: |
Thanks for the info. That is what I thought would happen, that the next section is displayed when I complete the previous section.
I am considering buying a new Sat Nav and possibly going back to TomTom. If I do buy a new one it would be the latest version of either Garmin (3598LMT-D) or TomTom 6000. If I stayed with Garmin I take it that I would have the latest version of Trip Planner and be able to transfer the route and drive it in one go without having all the sections independently displayed?
Also I find the 2460LT I currently have is extremely slow plan a route if the car is not stationary. I am reluctant to start to drive if the route hasn't been planned as it can take some 5-10 mins before it completes the route planning if the car is moving.
This wasn't the case with my old TTGo700 which was very quick to plan a route whether I was moving or stopped. Garmin support told me it was because TomTom plane the route from the destination back to your current position whereas Garmin plan it from your current position.
I would appreciate your thoughts on the above.
Thanks for your help
Pev |
| Back to top |
Posted: Sun Feb 22, 2015 3:54 pm Post subject: |
I have a 2508 which is a 2013 model, and it was from that year on that the newer trip planner style was introduced. It shows the whole route, and also allows the use of 'shaping' points throughout a route as well as waypoints. Waypoints you HAVE to go through, shaping points you can simply skip if you want to.
The 3598 behaves the same way so would do what you want.
I've not noticed any appreciably delay in planning a route provided the satnav has a satellite fix. Like any satnav, gaining an initial fix will take longer IF the car is moving. I tend to switch mine on as I'm getting into the car, putting my seatbelt on etc and so by the time I'm ready to go I have a fix. _________________ Where there's a will ... there's a way. |
| Back to top |
Snudge Lifetime Member
Joined: Aug 22, 2007 Posts: 212 Location: Peterborough
Posted: Sun Feb 22, 2015 6:43 pm Post subject: |
| Pev wrote: |
Pev |
The latestt TomTom will not let you plan routes with Tyre
I'm interested if anyone can say if latest Garmin can use Tyre - sussamb perhaps? |
| Back to top |
Posted: Sun Feb 22, 2015 7:16 pm Post subject: |
I'll check and confirm but there's no reason why it shouldn't. Been a while since I used it though so need to run it and see. _________________ Where there's a will ... there's a way. |
| Back to top |
Posted: Sun Feb 22, 2015 7:20 pm Post subject: |
| Ok thanks - appreciated. |
| Back to top |
Posted: Sun Feb 22, 2015 7:49 pm Post subject: |
Latest Tyre from here http://www.tyretotravel.com/ works OK with my 2508.
Having said that I find Garmin's Basecamp far easier to use. _________________ Where there's a will ... there's a way. |
| Back to top |
Posted: Sun Feb 22, 2015 8:08 pm Post subject: |
That's useful info so thanks. I've only had one satnav and the OneXL has been great but needs new battery and screen not so responsive as it was.
I hadn't heard of BaseCamp but will have a look so may buy a Garmin now.
Thanks for yor help. |
| Back to top |
alan_sh Lifetime Member
Posted: Wed Feb 25, 2015 10:58 pm Post subject: |
Bascamp takes bit of getting used to - but is very powerful. Plus it will use the maps off your Garmin (useful if you are short of disk space - but you can download them to your PC so you can plan without it being connected)
Alan |
| Back to top |
Posted: Thu Feb 26, 2015 9:05 am Post subject: |
| Thanks Alan and I'm guessing that TomTom will be losing sales to Garmin over the route planning issue - not their best business decision! |
| Back to top |
| Back to top |
