Pocket GPS World :: View topic - SOX and PGPSW File sets
PostPosted: Thu Mar 26, 2015 10:33 am    Post subject: SOX and PGPSW File sets Reply with quote
Here are 2 'helper' images to refer to when we get help requests. As they say, a picture is worth a thousand ..........
1) Where SOX.EXE goes (in the POILoader folder):
2) The 3 files needed (CSV, BMP & WAV) for a successful POILoader upload:
Notes:
a) Ignore the .prev file, that's for CSV Converter
b) Ignore the 50 to fifty filename, that is also for CSV Converter, this example is just to display that all 3 files are needed with identical prefix names.
#kremsearch
Lets be careful out there !
PostPosted: Thu Mar 26, 2015 1:05 pm    Post subject: Reply with quote
A link to the correct SOX.EXE would complete your very useful post Kremmen.
From Andy_P's post
SOX.exe 'working version': http://www.pocketgpsworld.com/downloads/sox.zip
and There's a step by step guide http://www.pocketgpsworld.com/speed-camera-alerts-garmin.php#installation
PostPosted: Thu Mar 26, 2015 1:33 pm    Post subject: Reply with quote
Don't need to now Very Happy
vkl
PostPosted: Sun Mar 03, 2019 4:39 pm    Post subject: Mercedes Comand Online ntg4.5 Reply with quote
Hi guys
I have successfully downloaded and installed the .gpx files needed to get the camera warnings and beeps on my system. To do this, I had to create a folder called PersonalPOI and just copy the .gpx files to it. This is working well and all is as it should be.
Now... I would like to expand on this and add the .wav files to get rid of the aforementioned beep. This is where I require some help.
I have downloaded the POILoader exe and installed it. I have downloaded and extracted Sox.exe and copied that to the POILoader directory, as your picture above.
I have downloaded the .wav files that I need by following your step by step guide above but when I run the POILoader software, it generates a POILoader.gpi file which obviously needs to be a .gpx to run in my system.
I'm not quite sure what to do next and am a bit confused about the .bmp, .csv, .wav stage.
Could you point me in the right direction please?
Confused
PostPosted: Sun Mar 03, 2019 5:06 pm    Post subject: Reply with quote
It's the gpi file you need, and should be placed in the POI folder on your device. This assumes you have a Garmin portable navigation device as per the title of this thread?
dales
PostPosted: Sun Mar 03, 2019 5:28 pm    Post subject: Reply with quote
...but if you're trying to get the voice files working in a Mercedes, you'd be better off asking the Mercedes crew here https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=88539&start=195 rather than in this Garmin section.
Dales.
24.041 (01 Apr 26)
