Pocket GPS World :: View topic - Speed Cameras & POIs
justclox
PostPosted: Mon Apr 06, 2015 10:02 pm    Post subject: Speed Cameras & POIs Reply with quote
I saw this app and was wondering if it was any good. Would I be able to load speed camera and POIs? Will it allow text to speach, like the actual sat nav units so it will give verbal warnings, etc.
Alistair
IanS100
PostPosted: Tue Apr 07, 2015 6:12 pm    Post subject: Reply with quote
If you're Talking about the new TomTom GPS Navigation Traffic or TomTom GO you can install & use it free of charge for a limited number of miles per month so give a GO Laughing and see if it does what you want
JockTamsonsBairn
PostPosted: Tue Apr 07, 2015 10:33 pm    Post subject: Reply with quote
Just to make you aware that it appears, from my experience, that you don't need to navigate to use up your free miles, you just have to have the app open while you're travelling.
Jock
rbecking
PostPosted: Wed May 06, 2015 8:46 pm    Post subject: Reply with quote
Anyone else having problems getting access to the POI folder to put custom POI's in? Think it may be since updated to IOS8.3. Have Apple locked it down again, Iknow we had problems like this when IOS7 came out
theripper
PostPosted: Fri May 08, 2015 9:46 pm    Post subject: Reply with quote
To add my pois on an android phone I had to find a root explorer that would work without rooting the phone, but it did work.
JockTamsonsBairn
PostPosted: Sat May 09, 2015 5:17 pm    Post subject: Reply with quote
Can you provide some more info on how you did it?
Jock
theripper
PostPosted: Sat May 09, 2015 6:31 pm    Post subject: Reply with quote
I downloaded Total Commander from play store then you can navigate to
/storage/sdcard0/Android/data/com.tomtom.gplay.navapp/files/files
then I put poi file into /personal/pois.
To be on the safe side I also went up to the first files directory and then went to /data this is where the map is and I put the poi file into the map directory(Uk& roI) just to be on the safe side. Don't know which one it uses.
Start app bring up menu go to my places and the poi file is in there.
This is on an HTC One XL with built in storage so the first part of the directory structure might be different on another phone.
I don't think you can add anything to your poi file.
theripper
PostPosted: Sat May 09, 2015 6:34 pm    Post subject: Reply with quote
You can also plan a trip
1. enter destination
2. find another location, in popup choose add to current trip. it then replans.
I used it Wednesday and put 18 stops into my trip!
JockTamsonsBairn
PostPosted: Sun May 10, 2015 2:23 pm    Post subject: Reply with quote
I'm afraid I read more into your earlier post than was actually there!
It uses the \Android\data\com.tomtom.gplay.navapp\files\files\personal\pois folder.
Have you had any luck getting the POI's Icon to display, either on the My Places menu, or on the map, as you're driving?
That's handy to know!
Jock
marksfish
PostPosted: Sun May 10, 2015 2:48 pm    Post subject: Reply with quote
I think you'll find it's not available yet, same as you can't do it on the standalone units. A bit of a half hearted and useless update really Sad
Mark
theripper
PostPosted: Mon May 11, 2015 7:03 pm    Post subject: Reply with quote
As marksfish said it won't show the bmp to go with the pois, also tried png file but no go.
NukeThemAll
PostPosted: Sun Jul 12, 2015 8:45 pm    Post subject: Reply with quote
I've recently installed the GO app on my 'droid phone. I had the same issue as JaTe regarding 'contacts' - some very bizarre behaviour which gives me a very long (and mostly useless) list of contacts that only a few of have linked addresses, because the app harvests not only 'real' contacts but also a whole load of folks you've e-mailed. WTF????
The slight good news is that it **is** possible to install POIs - see the posts in
https://en.discussions.tomtom.com/tomtom-go-mobile-and-navigation-for-android-156/tomtom-go-mobile-for-android-with-old-ov2-file-not-working-975805
I tried 'elfhelm's' method and it worked just fine. No icons on the map but at least I can search and select from my very useful legacy POI sets.
I haven't yet tried doing something similar with the pgpsw POI files, but it would appear to be feasible to install these - a real advantage given how (still) useless the TT 'search for POI' capability is. Even if you're not a fan of Google Maps/Navigation, the huge attraction is its search capability......
I haven't tried the app very much so can't really comment on its speed/stability etc but so far it seems to work just fine[url][/url][url][/url]
TT GO app on Android Phone
NukeThemAll
PostPosted: Tue Jul 14, 2015 9:06 pm    Post subject: Reply with quote
Actually, a bit of experimenting and......
Some (kind of) good news: I can confirm, as others have found, that the TT GO app v1.6 can certainly use the pgpsw POIs ie you can search for and navigate to them. All that you need to do is copy the pgpsw.ov2 file to the folder:
Android\data\com.tomtom.gplay.navapp\files\files\personal\pois\
on the device. If you have an sd card there might be a leading sdcard\
Custom icons don't appear to be supported but that doesn't bother me too much.
It might be that this only works because in .ov2 format the pgpsw POIs are, I think, pre-sorted (or created, I dunno) by longitude, which some folks have said is necessary for the TT app to be able to use them. If that's the case, please chaps don't change the way .ov2 POI files are made!!!!
For speed camera warnings I use the excellent CameraAlert app
wibbly
PostPosted: Thu Oct 29, 2015 3:21 pm    Post subject: Reply with quote
Anyone tried using the TomTom speed camera alerts recently? Based on limited experience so far, running CamerAlert in parallel, TomTom has cameras in the same places...
PostPosted: Thu Oct 29, 2015 7:15 pm    Post subject: Reply with quote
Edit..... TomTom has cameras in SOME OF the same places.
Did the TT app tell you what type they were, what speed they were set at, what audio warning did they give?
24.034 (25 Mar 26)
