Pocket GPS World :: View topic - Why are these cameras not on latest download?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert News
PostPosted: Mon Feb 15, 2016 10:50 pm    Post subject: Why are these cameras not on latest download? Reply with quote
N53 35.415 W002 51,346 new gatso which was erected 3months ago and it is not included on your latest download.
N53 35.234 W002 51.742 existing gatso removed due to new island 3 months ago and it is still listed on your latest download
PostPosted: Mon Feb 15, 2016 11:00 pm    Post subject: Reply with quote
Have you reported them? Will earn you a years subscription rather than just posting here.
JockTamsonsBairn
PostPosted: Wed Feb 17, 2016 1:58 am    Post subject: Reply with quote
If I've managed to convert those coordinates correctly, (and there's no guarantee that I have!! ,) then the locations are near Burscough:
1) 53.59025,-2.855767 - (outside the Red Lion pub?) - GATSO:166657@30, Heading:53 is shown on our map at this location.
2) 53.587233,-2.862367 - (outside Booth's supermarket?) - there is no camera shown on our map, but if you zoom back through StreetView History, you can see that there WAS a Gatso at this location, so I presume it was on our database, but has been removed correctly.
I've checked both locations on my 14.022 CamerAlert (Android) download and they're correct.
I'm slighty confused - both your previous post were seeking advice on installing the DB on a Zumo 590LM, have you ditched this and started to use the phone app?
Jock
PostPosted: Wed Feb 17, 2016 9:34 am    Post subject: Reply with quote
So it would appear that 590 has NOT got the 'latest database'. At least, not the PGPSW one.
PostPosted: Wed Feb 17, 2016 9:42 am    Post subject: Reply with quote
This is second reported issue with the latest phone CamerAlert. My guess is that the actual database is OK.
Lets be careful out there !
PostPosted: Wed Feb 17, 2016 12:39 pm    Post subject: Reply with quote
Would be good if the OP had mentioned the device on which the database is installed.
Are you suggesting finger trouble kremmen, or something else?
PostPosted: Wed Feb 17, 2016 1:26 pm    Post subject: Reply with quote
Not at all, remember the recent long thread re missing cameras that were there one day then missing the next. That was on a phone using the latest CamerAlert, but his Garmin was OK.
PostPosted: Thu Feb 18, 2016 12:31 am    Post subject: Reply with quote
Ahem, cough cough... We DO have a co-ordinate converter you know: http://www.pocketgpsworld.com/coordinate-converter.php
submission page - underneath the search bar wrote:
NOTE: You MUST use Decimal Degrees format (e.g. 52.12345,-2.54321). Other formats will need to be converted using [url="http://www.pocketgpsworld.com/coordinate-converter.php"]this conversion tool[/url].
But yes, your calculations are correct Very Happy
Active in the database since August 2007
GATSO:14822 - removed September 2015 dues to new roundabout.
FOR ALL THOSE INVOLVED IN THIS DISCUSSION
The OP (590) last downloaded the 27th Jan database and it was for a Garmin. They don't use CamerAlert phone app on this account.
So, with the format clarified - let's work on getting him sorted!
Couple of thoughts spring to mind:
1) An older database still installed - POI LOader changed ages ago and uses the folder name for teh POI files on the device by default. If he has not removed older .gpi files then this could be the cause
2) Garmin/Cyclops data is out of date and it's being confused as being our data
PostPosted: Thu Feb 18, 2016 7:42 am    Post subject: Reply with quote
I was not aware this was a Garmin problem.
Can you check what is on the Garmin unit. Ideally you should just have the one camera GPI file as per the picture below.
Note the creation date and report back.
PS: Take no notice of the file size because they will all be different depending on the camera sets used.
JockTamsonsBairn
PostPosted: Thu Feb 18, 2016 8:39 am    Post subject: Reply with quote
Sadly, it seems I'm not intelligent enough to use that converter correctly Sad
Anyone spot what I'm doing wrong?
MaFt wrote:
... and it was for a Garmin
Move to a more relevant forum?
Jock
Oldboy
PostPosted: Thu Feb 18, 2016 9:01 am    Post subject: Reply with quote
Try putting 35.415 and 51.346 in the M Boxes. Smile
TT Via 135 App 12.075: Europe Map v1160
PostPosted: Thu Feb 18, 2016 11:08 am    Post subject: Reply with quote
Yes, if you don't have D M S (Degrees Minutes Seconds) eg 52o 23' 15" and instead have Degrees and Decimal Minutes (52o 23.25) then you need to put the decimal minutes in the minutes field as it is 0.25 of a minute as opposed to 25 seconds.
The format given in the OP was degrees with decimal minutes.
JockTamsonsBairn
PostPosted: Fri Feb 19, 2016 10:42 pm    Post subject: Reply with quote
MaFt wrote:
"Decimal" Minutes
Shocked
Jock
PostPosted: Fri Feb 19, 2016 11:28 pm    Post subject: Reply with quote
Yes integer minutes with decimal fraction i.e. 30.5 mins = 30 mins 3o secs. Simples.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert News All times are GMT + 1 Hour
23.122 (10 Dec 25)
