| Author |
Kremmen Pocket GPS Verifier
Posted: Mon May 16, 2016 4:38 am Post subject: |
I should have time this week to add that as I'm coming to a pause shortly.
As you know I'm in Eastbourne for a few days from Saturday while the undercoat dries properly.
Just running round with a paintbrush today looking for missed bits.
I've got one job looking at the variable limit code that should be looking at the user set limit (in purple) on the main screen but apparently isn't.
I've got stuartb's voice pack to include into the install zip file.
I've now got this increased text. _________________ Lets be careful out there ! |
| Back to top |
Posted: Mon May 16, 2016 7:58 am Post subject: |
New version 44:
https://www.dropbox.com/s/4kpnpbwlk6k2e78/CSV%20to%20GPX%20Installer.zip?dl=0
1) Warning message now includes prompt to unzip PGPSW file using the programs own unzip routine.
2) stuartb voice pack included.
3) Bug with user selectable variable speeds fixed. It was using the set speed to calculate the proximity but was replacing the 0mph test with 70mph.
(Note) The approach warning text does not include a speed because the camera is 'variable speed' but the overspeed element, if selected, now uses the user selected speed - good spot  _________________ Lets be careful out there ! |
| Back to top |
Nemesis1 Regular Visitor
Posted: Mon May 16, 2016 4:09 pm Post subject: |
| Cant access that link mate :-( |
| Back to top |
M8TJT The Other Tired Old Man
Posted: Mon May 16, 2016 4:17 pm Post subject: |
Link's broken K.
Error message is
"This site can’t be reached
dl.dropboxusercontent.com’s server DNS address could not be found." |
| Back to top |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Mon May 16, 2016 4:45 pm Post subject: |
Working for me? _________________ Where there's a will ... there's a way. |
| Back to top |
Posted: Mon May 16, 2016 4:48 pm Post subject: |
Working for me too now.
Have spoken to Kremmen, he's done nothing so must have been a temp Dropbox glitch. |
| Back to top |
Posted: Mon May 16, 2016 5:06 pm Post subject: |
K, can you confirm it's v44? Having done a fresh install from the above link mine has 43 at the end? _________________ Where there's a will ... there's a way. |
| Back to top |
Posted: Mon May 16, 2016 5:13 pm Post subject: |
Thanks for the headsup M8.
I'll check but the link was setup this morning. Give me 10 minutes...
It is 43, what I did was look at the auto increment it does when you publish it.
The top version should show 2016.05.16.43
44 will be the next one which hopefully will be the % overspeed facility.
Anyway, the latest zip is dated today at 07:48
Dropbox must have had a fit because I've changed nothing since this morning. _________________ Lets be careful out there ! |
| Back to top |
Posted: Mon May 16, 2016 6:29 pm Post subject: |
Got it.
Also been an interesting update regards the system used in the Merc.
Will update that thread.
| Back to top |
Posted: Mon May 16, 2016 6:59 pm Post subject: |
Thanks nemesis.
There was a major overhaul a month or so back due to the directional voice alerts. After that overhaul it was given some serious testing and a few other bugs were detected and ironed out.
I did check your warning message area and it seemed to still be working OK.
The detected bugs didn't affect any missing camera data or anything fundamental, that was OK, it was mainly cosmetic like camera counts and going the wrong way and including some cameras you asked it to ignore. _________________ Lets be careful out there ! |
| Back to top |
Posted: Mon May 16, 2016 8:16 pm Post subject: |
Looks good to me mate.
Can't use custom sound files in the Merc so no probs there for me. |
| Back to top |
Posted: Tue May 17, 2016 4:48 am Post subject: |
Ta  _________________ Lets be careful out there ! |
| Back to top |
Posted: Wed May 18, 2016 11:18 am Post subject: |
OverSpeed enhancement:
Here's how I see it:
The theory is that the warning speeds will be controlled by the up/down arrows.
They will be limited to the speed limit and the 10% +2.
The 50 one will therefore only range from 50 to 57. That will stop any mistakes.
This is just a screen mockup, there is no code behind it yet.
If you change the speed over the limit the that overspeed colour will change from green to red.
Also, the VAR speed will be lifted from what you have set for the Gatso VAR on the main page.
The above are all just thoughts/suggestions waiting for feedback before I start coding. _________________ Lets be careful out there !
| Back to top |
Allan_whoops Frequent Visitor
Posted: Thu May 19, 2016 8:33 am Post subject: |
Looks good.
Are you going to give the option of splitting out the cameras eg mobiles, fixed and specs or is that far more time consuming? |
| Back to top |
Posted: Thu May 19, 2016 12:13 pm Post subject: |
I've just finished a beta version 2016.05.19.44
https://www.dropbox.com/s/3q8pmzybhoybzxc/CSV%20to%20GPX%20Installer.zip?dl=0
This link is different to the normal version 43 so it's not forced on everyone.
I've updated the manual with what you need to do, not much.
Let me know.
This is just separated by speed as I didn't consider trying to separate it out by camera type as well. Not impossible but I'd rather wait until this version has been tested and OK'd so any issues are less to change.
PS: I've also had issues with DropBox not always connecting first time so keep trying to download if it first fails. _________________ Lets be careful out there ! |
| Back to top |
| Back to top |
