Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 44, 45, 46 ... 74, 75, 76  Next
PostPosted: Wed Jan 25, 2017 8:29 am    Post subject: Reply with quote
Sorted:
With Blue Dot:
Without, using the 1x1 magenta trick:
Plus with SmartLink activated, just for info.
I'm now about to upload the overspeed.bmp into the zip file ......
Lets be careful out there !
PostPosted: Wed Jan 25, 2017 9:34 am    Post subject: Reply with quote
But, is it the 1x1 pixel or the magenta colour that is doing the trick? Make it bigger, but magenta and see if you can see a nice magenta dot instead of a blue one.
PostPosted: Wed Jan 25, 2017 9:41 am    Post subject: Reply with quote
It's the colour http://garmin.blogs.com/softwareupdates/2010/03/personalize-your-map-with-custom-symbols.html#.WIhkpk1prcs
Note
To make a pixel transparent, set its color to magenta (RGB = 255, 0, 255).
PostPosted: Wed Jan 25, 2017 9:52 am    Post subject: Reply with quote
Don't think it matters M.
What I have found is that the transparent dot doesn't interfere with the normal BMP by creating a transparent hole in it.
Interesting to note, during break testing, that the bmp shows as normal for the approach distance then the blue dot appears over the top at the overspeed distance.
The zip file now contains the identical overspeed.bmp in all 3 sizes folders.
PostPosted: Wed Jan 25, 2017 10:08 am    Post subject: Reply with quote
But when I tried it, it didn't work, that's why I asked K whether it was the small size ir the colour that made it not visible. If he made it bigger than 1 pixel (so that it is clearly visible) then change the colour to 255,0,255, does it go invisible?
I'll try it myself later.
PostPosted: Wed Jan 25, 2017 10:58 am    Post subject: Reply with quote
If you go back a few posts, previous page now, I've done it ............
Look at the 50 sign, the top left corner is transparent.
Now who's speed reading Laughing
pcaouolte
PostPosted: Wed Jan 25, 2017 8:14 pm    Post subject: Reply with quote
Hi Kremmen,
Can I make a request for an enhancement to your program:
Under Help - Program Location can the popup box with the location be changed to allow the location details to be copied to the clipboard please?
This would allow the location to be pasted into the exclusion section of antivirus or anti malware programs which sometimes dislike the rapid file changes that your program makes.
Paul
PostPosted: Thu Jan 26, 2017 5:23 am    Post subject: Reply with quote
Certainly can make any request. That's what I'm here for on these cold days.
Good call.
I already have a function to display the program location so I just need to clipboard it.
Done - v58 now available from the usual link.
Note that the previous version number file is now a ReadMe. Note the contents as there are some file copies highlighted from the recent releases.
pcaouolte
PostPosted: Thu Jan 26, 2017 8:58 am    Post subject: Reply with quote
Wow, very speedy. Thank you.
Paul
pcaouolte
PostPosted: Thu Jan 26, 2017 7:52 pm    Post subject: Reply with quote
Hi, something strange is happening to the overspeed.gpx file when processing a warning text change. All the cameras in the overspeed.gpx file are renamed to MOBILE cameras. The first few lines of the processed file (I have changed greater and less than to curly braces) are:
Code:
{?xml version="1.0" encoding="UTF-8" standalone="no"?}{gpx xmlns="http://www.topografix.com/GPX/1/1" creator="CSV to GPX Creator" version="1.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.topografix.com/GPX/1/1 http://www.topografix.com/GPX/1/1/gpx.xsd"}
{wpt lon="-1.94351" lat="53.07335"}{name}MOBILE Camera:46@50{/name}{extensions}{WaypointExtension xmlns="http://www.garmin.com/xmlschemas/GpxExtensions/v2"}{Proximity}223{/Proximity}{/WaypointExtension}{/extensions}{/wpt}
Camera 46 is a GATSO not a MOBILE and was shown correctly in the overspeed.gpx file as a GATSO until I processed the warning text change.
The options that I have selected in the warning text change (from settings.txt) are:
Code:
GatsoText,    FIXED Camera
MobileText,   MOBILE  Camera
PMobileText,  pMOBILE  Camera
RedlightText, RED LIGHT  Camera
SpecsText,    AVERAGE SPEED  Cam
AllowText,    False
RemoveText,   True
TextFormat1,  True
TextFormat2,  False
TextFormat3,  False
TextFormat4,  False
TextMPH,      mph
I also notice that an extra space is being inserted in settings.txt immediately before the word Camera on every line except the GatsoText line and that there is no entry in settings.txt for the text set for the RedSpeed family of cameras.
Paul
PostPosted: Thu Jan 26, 2017 8:05 pm    Post subject: Reply with quote
Well, there's another K. I feel a v59 coming on Very Happy
PostPosted: Fri Jan 27, 2017 6:25 am    Post subject: Reply with quote
Interesting.
When the text change was requested it was initially for the Merc system and I didn't consider the separate overspeed section.
That change is processed after the gpx conversion so will be easy to trap.
Given that RedSpeed is new that will require a more in depth change involving a screen expansion, so not as quick.
First test - I can find no processing issue with any of it except for Overspeed. Overspeed isn't touched and the other categories are process by 'family'.
Mobile must have been the last family processed so it's used that throughout the Overspeed file = bug and I will work on that.
I'll look into the Settings TXT as I must have missed RedSpeed.
Fortunately there are no screen changes required so I just need a strategy to deal with the Overspeed file that contains all families.
I'm on it.
Done
This is purely a Beta version even though it is v59. the main link still downloads v58.
https://www.dropbox.com/s/1oja47hxh45voh8/CSV%20to%20GPX%20Installer.zip?dl=0
I've tried a few combinations but there may be some I've missed.
Let me know.
pcaouolte
PostPosted: Fri Jan 27, 2017 8:49 am    Post subject: Reply with quote
Thank you. I won't be able to test it until this evening as work is interrupting my social life again. Very Happy
Paul
PostPosted: Fri Jan 27, 2017 9:07 am    Post subject: Reply with quote
No rush
It was easier than I first thought.
The problem now is that there are so many combinations I'm sure some will produce errors.
Plus I won't be touching the PC till Monday as I'm off out later to try and verify cameras 9283 and 177194, both of which have been flagged for removal.
One is a recent change to Monitron and the other is a new Specs so I'm suspicious.
I'm hoping to get my latest usual 100% rejection rate.
PostPosted: Fri Jan 27, 2017 11:48 am    Post subject: Reply with quote
Well, Kremmen gave me one with 255,0,255 background and I generated a couple myself in Paint. All I got was the usual icon with a magenta background rather than a white one on my 2699.
Any other ideas?
Page 45 of 76
24.034 (25 Mar 26)
