Pocket GPS World :: View topic - New to sygic..import 3rd party POI
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps
Rick-uk
PostPosted: Mon Sep 25, 2017 9:21 pm    Post subject: Reply with quote
adobbing wrote:
Also with TomTom it was possible to configure verbal warnings for proximity to .OV2 files such as speed cameras, is there any way of configuring Sygic?
Like TT they have removed proximity alerts from the latest versions 🤐
https://share.octopus.energy/dense-raven-261
PostPosted: Tue Sep 26, 2017 8:07 am    Post subject: Reply with quote
The have indeed, but you need a *.csv file to import, not a *.ov2.
Can you convert .ov2 to .csv?
Allan_whoops
PostPosted: Tue Sep 26, 2017 8:45 am    Post subject: Reply with quote
Look at Extra POI editor. That can import OVs and export CSVs easily. That is what I use. Also, make sure that the CSV uses UTF-8 character set. I use Notepad ++ to do this.
I use Sygic (Be on Road) in the car so have gone through this process. There's a good how to here
http://www.poi-factory.com/node/34103
Rick-uk
PostPosted: Tue Sep 26, 2017 5:58 pm    Post subject: Reply with quote
adobbing wrote:
New to sygic.
I have a large collection of my own TomTom .OV2 and .BMP files.
Is there an easy way to convert them to the correct format for Sygic, .rupi?
I use two pieces of software to convert my OV2 to UPI which the latest version of Sygic still accepts
Step 1. I use Ov2Upi Translator 2.3 to convert the OV2 to an older format UPI. You can either do individual files or select the "translate in series" checkbox to batch convert
Step 2. I use POI Converter to update the format. Select the "Convert old UPI to McGuider 2009" button and process your files created in previous step. This batch converts a complete folder.
Step 3. Transfer your newly created files to the Maps/Import folder on your device and then when you next run Sygic it will import your new POIs. include a BMP file with them to display on the map.
I have tried numerous other pieces of software to convert from OV2 to RUPI but usually I still end up having to edit the CSV file to get the correct format that the converter will accept.
This is the only reliable way I have found for consistent results although YMMV.
The import will return an error if the UPI file is empty but will continue with the next until finished.
I will leave the files shared on my Google Drive for a while should you wish to try this method. Am I allowed to share these files?
My main device is a TomTom PND and that is what I use to mark/create POIs which I then edit in Tyre before I transfer them to my phone in Sygic (which I always have with me). Sygics POI creation and editing is woeful and not worth bothering with, plus unless you use a 3rd party software can not be exported to display in Tyre (or similar) for editing.
Regards
adobbing
PostPosted: Mon Oct 30, 2017 7:10 pm    Post subject: Reply with quote
Rick-uk wrote:
adobbing wrote:
New to sygic.
Regards
Thanks for your help, I've not had a chance until today to do any further investigation into this!
Got as far as "Step 3. Transfer your newly created files to the Maps/Import folder on your device and then when you next run Sygic it will import your new POIs. include a BMP file with them to display on the map."
Where and how do I access the "Maps/Import folder"?
I have tried using iMazing, but under Sygic I don't see that folder, just a "Documents" folder ?
Rick-uk
PostPosted: Wed Nov 01, 2017 6:20 pm    Post subject: Reply with quote
On an Android device the maps folder is Android\data\com.sygic.aura\files\Maps on either the internal memory or sd card depending on how it was installed
As you mentioned iMazing which is for iPhones then I will not be able to help sorry.
PostPosted: Wed Nov 01, 2017 7:38 pm    Post subject: Reply with quote
But you may have to create the "\Import" folder if it does not exist.
adobbing
PostPosted: Fri Jan 05, 2018 5:53 pm    Post subject: Reply with quote
Looking to have another go at doing this.
I have an iPhone rather than an android device, anybody any idea / experience of where I need to put the files / folder?
I have imazing, which I have used to manage POI files for the the TomTom iOS app.
I can’t see any maps folders under Sygic only a documents folder which seems to contain numerous .kml files, these appear to be created whenever I have used Sygic.
Privateer
PostPosted: Fri Jan 05, 2018 6:46 pm    Post subject: Reply with quote
Hi adobbing,
Sorry, I missed this before. I'm afraid that the iOS version of Sygic cannot take custom POIs, despite what the Sygic website says. I contacted Sygic support in April 2017 and they confirmed that the iOS version of Sygic couldn't handle custom POIs.
Robert.
Garmin Camper 770 LMT-D
adobbing
PostPosted: Fri Jan 05, 2018 6:50 pm    Post subject: Reply with quote
Import POIs on iPhone / iPad (iOS)
Launch iTunes on your Mac/PC. Connect your iPhone/iPad to Mac/PC.
Click on your iPhone/iPad and go to the Apps tab.
Choose Sygic navigation in "File Sharing".
Drag and drop .upi/.rupi and .bmp files directly into Sygic. Do not drag and drop folders.
Sync your iPhone / iPad with iTunes.
If Sygic is running on your iPhone/iPad, close it.
Launch Sygic on your iPhone/iPad.
A dialog for import of custom POI will open and your are done.
http://www.sygic.com/company/poi
According to this it can, but the method suggested no longer works since the ability to configure Apps was removed from iTunes.
I’ve emailed their support to see if they can advise on an updated procedure.
Privateer
PostPosted: Fri Jan 05, 2018 6:56 pm    Post subject: Reply with quote
Good luck!
It would be nice if Sygic have added custom POI support to their iOS app.
It would be nice if they allowed the use of .csv files as well for POIs, instead of their proprietary files.
Robert.
theripper
PostPosted: Fri Jun 07, 2019 10:28 pm    Post subject: Reply with quote
The latest version of rupi manager will import ov2 files.
Privateer
PostPosted: Fri Jun 07, 2019 10:48 pm    Post subject: Reply with quote
Thanks for that information! Thumbs Up
Do Sygic do a Mac version of Rupi manger, or an online version?
Robert.
PostPosted: Fri Jun 07, 2019 11:27 pm    Post subject: Reply with quote
But can you set up proximity alerts for the imported POIs.
Privateer
PostPosted: Sat Jun 08, 2019 9:41 am    Post subject: Reply with quote
If you can’t then you could always use CamerAlert. Thumbs Up
Robert.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps All times are GMT + 1 Hour
Page 2 of 3
23.094 (24 Sep 25)
