| Author |
BodgerBaz Lifetime Member
Joined: Jun 12, 2005 Posts: 368 Location: Mörsdorf, Germany
Posted: Thu Nov 16, 2017 7:20 am Post subject: TomTom GO 750 LIVE - sluggish |
My old faithful TomTom GO 750 LIVE is starting to play up.
For the last couple of days the screen is very sluggish to redraw when moving and road junctions and roundabouts are a nightmare as it takes ages to respond to the change in direction.
The audio commands 'seem' OK but trying to find an address in Antwerp yesterday was a real naus and we went wrong so many times (because of the time lag) that I nearly threw it into the canal!!
I know touch screens are much more responsive these days but I find I really have to stab the screen to get a response then it seems to cache the prods and respond to them one by one in a very laboured way.
Is it the end of the road for the 750 or is there a workaround?
If it is the end of the road, is the newer TOMTOM GO 5200 similar in that I can add my own POIs and use Itinerary Planning. This second option is a MUST?
Any advice or help would be brilliant
Many thanks
Barry |
| Back to top |
dhn Frequent Visitor
Posted: Thu Nov 16, 2017 12:39 pm Post subject: |
Have you tried a drum reset by holding the power button about 20 seconds till you hear the drum sounds?
(unless that model has a dedicated reset hole) _________________ David |
| Back to top |
Posted: Thu Nov 16, 2017 3:01 pm Post subject: |
| I'll give it a go David to see if it makes any difference. Thanks |
| Back to top |
Stecha Regular Visitor
Posted: Sat Nov 18, 2017 3:55 pm Post subject: |
Have you tried the clear flash tool ?
Worth a try |
| Back to top |
Posted: Sat Nov 18, 2017 4:12 pm Post subject: |
| Er . . . What’s the clear flash tool? |
| Back to top |
Posted: Sat Nov 18, 2017 4:28 pm Post subject: |
I am nowhere near as knowledgeable as most here, but, have been using tomtoms since 2006
In your situation I would do and have done
Use windows file error checker
With your tomtom connected to your pc, right click, properties, tools,
Defrag your tomtom with Smart defrag, get the free version
Download and use the rfee tomtom clear flash tool
A link to that does more than it says
iirc correctly its best to run it three times See Here
| Back to top |
justbrowsing Frequent Visitor
Posted: Sat Nov 18, 2017 4:43 pm Post subject: |
| Yes, clearflash.exe should be run 3 times allowing the device to reboot after each run....or you could maybe try to reduce the number of POI's showing as that does slow things down considerably |
| Back to top |
Posted: Sat Nov 18, 2017 6:01 pm Post subject: |
I’ve never heard of this before. Many thanks, I’ll give it a go.
To date it’s always worked well and I haven’t made any changes for ages except updating the map and adding different itinerary planning routes.
I suddenly noticed the extreme sluggishness to respond to screen inputs and redrawing of the map. I don’t think it was the GPS reception as even trying to select menu options was painfully slow.
Many thanks for the feedback
Barry |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
Posted: Sat Nov 18, 2017 7:19 pm Post subject: |
| Stecha wrote: | | Defrag your tomtom with Smart defrag, get the free version | It is generally agreed that it is unwise to Defrag a Solid State Memory Device (the excessive read/writes can shorten the life of the device), as it doesn't have the latency that a spinning magnetic disk does. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
| Back to top |
Posted: Sat Nov 18, 2017 8:41 pm Post subject: |
| Oldboy wrote: | | Stecha wrote: | | Defrag your tomtom with Smart defrag, get the free version | It is generally agreed that it is unwise to Defrag a Solid State Memory Device (the excessive read/writes can shorten the life of the device), as it doesn't have the latency that a spinning magnetic disk does. |
Thanks Oldboy
I live and learn  |
| Back to top |
Posted: Sat Nov 18, 2017 8:51 pm Post subject: |
| Soooooo. Shall I forget it and chuck it in the bin then? |
| Back to top |
Posted: Sat Nov 18, 2017 8:56 pm Post subject: |
| BodgerBaz wrote: | | Soooooo. Shall I forget it and chuck it in the bin then? |
After clearflash.exe & removing most POI's if still no better then just drive more slowly  |
| Back to top |
Posted: Sat Nov 18, 2017 9:13 pm Post subject: |
| justbrowsing wrote: |
. . . .if still no better then just drive more slowly  |
As I have mentioned on at least two occasions, even stationary, the screen is very slow to respond to instructions from me finger. I will however try the clear flash thing to see if it helps. |
| Back to top |
Posted: Sat Nov 18, 2017 10:19 pm Post subject: |
Eh... "just drive more slowly" was meant to be a joke!
Viva Brexit! |
| Back to top |
M8TJT The Other Tired Old Man
Posted: Sun Nov 19, 2017 12:27 am Post subject: |
That's French you twit.  |
| Back to top |
| Back to top |
