Pocket GPS World :: View topic - Coverting multiple POI's from .vcf to .csv or .gpx.
Goto page Previous  1, 2, 3, 4, 5, 6  Next
trapper
PostPosted: Fri Apr 13, 2018 8:10 pm    Post subject: Reply with quote
Thanks, I have downloaded to my drive and saved a copy to my Dropbox - Just in case..... Wink
Now to print and read.....
trapper
PostPosted: Fri Apr 13, 2018 8:45 pm    Post subject: Reply with quote
Printed and Read.
I now have the SD card files as \garmin\POI\BowlsClubs.gpi
It is too dark now to test this so I will tomorrow.
Hopefully you will have made my wife very happy as she was resigned to tapping them all in Exclamation
Thanks again.
PostPosted: Fri Apr 13, 2018 11:10 pm    Post subject: Reply with quote
Let's see if it works before a communal love in, eh! Very Happy
trapper
PostPosted: Sat Apr 14, 2018 8:44 am    Post subject: Reply with quote
Have to delay that one I'm sorry to say.
No response from the Garmin whatsoever, the map was on screen showing my location heading N speed 0. Sad Tried a few times in case of a dodgy connection in the SD socket.
Looks like removal of center console to check the lead is plugged in correctly or a new lead. Either way it will be a real pain to do. I cannot see the dealer will be willing to do it again for free, but I will try.
I am pretty certain I now have a card that would work, thanks to your help. It's such a shame it has all come to nothing.
trapper
PostPosted: Sat Apr 14, 2018 9:13 am    Post subject: Reply with quote
Kremmen wrote:
Thumbs Up
Done, DropBox download:
https://www.dropbox.com/sh/2num567udd9oqfb/AABsxPbzvDowveAQ_KklXVWwa?dl=0
I've only converted the top line of the CSV - and one in Northwood, the nearest to me for testing.
You can only have 4 columns.
1) Lat
2) Long
3) Main Heading Description for Nav
4) All other details seperated by a HTML BR line feed. (I can't post HTML tags but the file is obvious)
End result:
No BMP:
My 22x22 BMP:
On the Garmin "Where To" - "Custom POI's" - "Bowls"
Just wondering, does the column order matter? Kremmen gives the columns in a different order. And details separated by BR line breaks.
PostPosted: Sat Apr 14, 2018 10:33 am    Post subject: Reply with quote
Yes. It is vital that they are in the correct order for the Garmin.
Lon, Lat, Name, Details. The BR that are inserted are to place what's after it onto a new line.
The CSV that my prog generates is in the right order and works just fine on my Garmin.
The only thing is that you must not change the order of the columns on the 'master' Excel sheet otherwise it will screw up the CSV as I don't do ANY checking that the column contains the 'right' data.
EDIT. Presumably ypu have read THIS.
If you put a blank SD card into your computer and chose 'Garmin device', in POILoader the card will be listed and then the POI GPI file will be loaded in the correct place.
trapper
PostPosted: Sat Apr 14, 2018 5:59 pm    Post subject: Reply with quote
Err, no, I had not seen that guide.
Bit confused (So what's new?)
The guide shows;
B. Installing Pocket GPS Safety Camera Database - SD Card Models
Connect your card reader to the PC and insert the memory card.
If POILoader does not automatically start, run it now.
Select 'Garmin Device' from 'Save Options', Click Next.
Your card reader should now be listed as the device, Click Next.
Choose 'Install new custom POIs onto your device', Click Next.[\b]
Browse for the folder where you saved and extracted the POIs at 'A. Extracting the Database on the PC'. Follow the on screen instructions.
Browse for your POI folder and follow the on screen instructions.
In your ReadMe, it shows;
Chose'Computer' as the destination.
At no point in this trial have I seen the option to
'Install new custom POI onto your device'
The screen shots on the guide are also different to my POILoader. All I see is Garmin device and Computer.
Column order is fine, I was looking at the xlsm file......
Embarassed
[/quote]
PostPosted: Sat Apr 14, 2018 6:21 pm    Post subject: Reply with quote
It's a radio button that is normally selected above 'Remove all previously installed custom POIs from your device.
The xlsm file is exactly what you sent me. No data changes, no column changes. It's the CSV produced that has the column changes.
trapper
PostPosted: Sat Apr 14, 2018 10:00 pm    Post subject: Reply with quote
Trapper:
Not seen this either:
My POILoader.
[img]
Hell, taken 4 screen shots of my POILoader, now on my desktop but no idea how to insert them here. img asks for a http url. ?
Sad
Plan B. As text.
Screen 1, where to install?
O Garmin Device
O Computer.
Screen 2,
Please select a folder for saving your POI file
Screen 3,
Please select the folder where data can be found
Screen 4,
Congratulations, you have now installed 42 custom POI's to your computer.
Two versions of POILoader ??
If this was not so annoying it might be funny....
PostPosted: Sat Apr 14, 2018 10:25 pm    Post subject: Reply with quote
No not two versions. You see what I said if you chose 'Garmin device' as in my EDIT a couple of posts ago.
Have you got an otherwise blank SD card with the folders Garmin\POI on it and the GPI created by POILoader from the CSV that my program creates in the POI folder?
If you have, and it doesn't load onto your device then there is another problem that I can't help you with because I don't have your device.
Pictures have to be hosted somewhere else and link posted
trapper
PostPosted: Sun Apr 15, 2018 8:47 am    Post subject: Reply with quote
As you say, there is probably another problem elsewhere. I have tried the 3 SD cards again without success. Crying or Very sad Evil or Very Mad
I am sorry, not only for me, but for the hard work you have done on my behalf that has come to nothing.
I am sure I will get the damn thing to work after I can get at it! However this may take a little time to sort out.
Thank you for your help.
You are a credit to to this forum.
PostPosted: Sun Apr 15, 2018 9:35 am    Post subject: Reply with quote
Do you have documentary or hearsay evidence that it is actually possible to load POIs onto the device in question?
trapper
PostPosted: Sun Apr 15, 2018 10:36 am    Post subject: Reply with quote
Yes I do.
In the manual on page 42 titled Appendix it states:
You can manually load custom points of interest (POI) databases, available from various companies on the internet.......
Later in the blurb;
After downloading your POI database use the Garmin POILoader to install the POIs onto an SD Card to load the POIs....
Usual warnings about not being responsible if it all goes T' up etc.
PostPosted: Sun Apr 15, 2018 4:39 pm    Post subject: Reply with quote
Well that seems pretty positive that you should be able to load them then.
trapper
PostPosted: Sun Apr 15, 2018 5:51 pm    Post subject: Reply with quote
I have emailed the dealer principle about this problem, I have had problems with them before, where they have lied and tried to con me saying that they had correctly done a job under warranty, and I then proved they were lying. A technician bad mouthed me and called me an obscenity not realising I was in earshot!
So I reckon they might owe me a favour or two.
Oh, they also failed to keep promises. Then again, they're car dealers, so what do I expect?
Rolling Eyes
Once this is sorted I will post back with the results.
Page 4 of 6
23.102 (08 Oct 25)
