Pocket GPS World :: View topic - Copy content to new device
psyskiesman
PostPosted: Mon Aug 27, 2018 4:33 pm    Post subject: Copy content to new device Reply with quote
Hi, is there any easy way to copy all content from existing Go Live1005 to new refurbished Go Live1005, things like poi's and favourites?
PostPosted: Mon Aug 27, 2018 7:18 pm    Post subject: Reply with quote
Well, one VERY important thing is to copy mapsettings.cfg from old map folder to new map folder, should get your favourites. Then copy and paste all POIs (including associated BMPs and OGGs) from map folder to hard disk and copy/paste them from hard disk to new map folder. Got to be as easy/quick as whatever method TT have.
justbrowsing
PostPosted: Mon Aug 27, 2018 7:59 pm    Post subject: Reply with quote
....but a GO Live1005 is a NAV3 device that uses MDC so that ain't going to work is it Dennis (or am I'm wrong?)
dhn
PostPosted: Tue Aug 28, 2018 10:23 am    Post subject: Reply with quote
https://uk.support.tomtom.com/app/answers/detail/a_id/24851
and this:
https://www.youtube.com/watch?v=AiO4zR0ugGo
justbrowsing
PostPosted: Tue Aug 28, 2018 10:38 am    Post subject: Reply with quote
Ah, OK thanks. A bit convoluted compared with the good old copy & paste the NAV'2 but if it works, cool Cool
psyskiesman
PostPosted: Tue Aug 28, 2018 10:51 am    Post subject: Reply with quote
Very convoluted, but I'll give it a try when the new device arrives. Thanks to all.
psyskiesman
PostPosted: Fri Aug 31, 2018 6:33 pm    Post subject: Reply with quote
Hi all, copied all favourites on to new Go Live 1005 with no problems; but I do have another query. I have downloaded the latest PGPSW speed camera database and have installed them on said device, but while trying to set warnings I have gone to settings, manage poi's, warn when near and then tap on first PGPSW camera, set warning distance and then next, warn only if poi is on route and the only option then is Done. I can't remember how I set the voice warnings on my old 1005, I can't even choose what warning sound let alone the ogg file voice warnings. Any helpers out there know what I'm doing wrong?
PostPosted: Sat Sep 01, 2018 10:27 am    Post subject: Reply with quote
Something seems to be missing there - it's normal to be asked for the sound you want, except if you have already loaded OGG files, it merely asks "Is this the sound you want" BUT with no sound! And you simply say YES (to accept the No sound!). I wonder if the MDC transfer process takes care of that for you. Can you do a simulated run past a camera to see if that is the case?
psyskiesman
PostPosted: Sat Sep 01, 2018 1:26 pm    Post subject: Reply with quote
Thanks Dennis, you've helped a lot over the past years and this time is no exception. I had already had the device out on the road yesterday and I was just getting a non descript beep-beep when approaching cameras. This morning I deleted all PGPSW cameras and re-installed them, went through the same rigmarole of setting warning distances on all categories and then tried a demo on the device. All seem to be fine, so as you suspected, the ogg files are automatically taken care of. Not sure why it didn't work yesterday though.
PostPosted: Sat Sep 01, 2018 3:51 pm    Post subject: Reply with quote
Just goes to show, ignorance (mine) is bliss. Give me a typewriter and enough time and I'll write a new play à la Shakespeare!
By the way, I suspect the non descript beeps were for TomTom cameras, not pgpsw - they do have the odd ones correct! Time will tell, when you get non descript beeps again if you haven't disabled TT cameras.
24.034 (25 Mar 26)
