Pocket GPS World :: View topic - Land Rover Evoque
Land Rover Evoque
Goto page Previous  1, 2
PostPosted: Tue Oct 02, 2018 3:45 pm    Post subject: Reply with quote
If you're referring to the help in this thread then it may very well be out of date.
The last post before yours is 2015 and technology moves on.
If the advice is elsewhere then the same may apply.
Lets be careful out there !
ElectricGhost
PostPosted: Tue Oct 02, 2018 4:26 pm    Post subject: Land Rover Evoque Reply with quote
Thanks for your responses.
If I need to re-install in order to pick up the Pocket GPS World points of interest, I'll need a software disc to do so. There was not one which came with the car - any idea how to get my hands on one (|I've already tried to find out online with no success).
With regard to the comment that things move on, I would have hoped that they would have improved but things just seem to get worse. Landrover is not much help (issuing videos with old versions of the navigation software and restricting the current software to a navigation version which is pretty useless).
petevick
PostPosted: Fri Dec 28, 2018 10:30 am    Post subject: Reply with quote
you don't need to re-install - you can add POI's from a USB stick.
Download GPX other and extract the GPX files to a USB stick. Then (taken from https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=598860#598860)
From NAV menu, touch More..
Select Stored Locations
Touch My POI
Select Add
Then select the GPX file on the USB stick and it will download the file to the Nav system
You can then select Edit
and choose to pick a sound to play and an Icon
The chosen Icon is displayed on the map and the chosen sound is played on approach
Hope that helps.
Pete
smilers
PostPosted: Fri Nov 08, 2019 9:54 pm    Post subject: evoque Reply with quote
what and where is the file I need for cameras for a 16 Evoque ?
petevick
PostPosted: Fri Nov 08, 2019 10:52 pm    Post subject: Reply with quote
use 'Other - GPX' from https://www.pocketgpsworld.com/modules.php?name=Cameras
HTH
lokalebasen
PostPosted: Sun Jul 11, 2021 5:43 am    Post subject: Reply with quote
It was very helpful for me! Thank you all!
Page 2 of 2
23.122 (10 Dec 25)
