Posted: Tue Mar 10, 2020 5:24 pm Post subject: Honda in-dash sat nav
Would some kind person please be able to tell me using words which I as a still computer/internet layman (and one who cannot do computer-speak) could expect to understand with ease just why although my Pocket GPS World downloads of the UK and European speed camera databases which I then transfer using the POI Loader to an SD card for insertion into my Garmin 2597 sat nav unit have always (or at least since I discovered I had to do something (actual process now forgotten) to enable voice warnings) worked perfectly well in the “windscreen” item yet when I make a similar download and transfer to a memory stick (already containing the relevant map updates) which I then insert into the USB slot in my lately-purchased UK market 2019 Honda CR-V, I suspect that the in-dash sat nav does not even recognise the existence of the camera database which is stored upon it, let alone permit of its use?
I have looked here (and generally) for some answers but without success (likely my ignorance at work once again), and (perhaps not having understood properly what I have read) although I have spoken to Garmin (who have been pleasant enough) I have learned nothing there which has assisted me in a practical manner.
It is almost certainly just me, but anything helpful will thus be most gratefully received.
Posted: Tue Mar 10, 2020 5:57 pm Post subject:
Nope, it's deffo not you mate. Honda have made it pretty damn difficult to put user POIs on the unit other than by manual input.
I have a 2017 Prestige and putting the PGPSW (or any other) database is a right pain in the butt as you have to go through the complete map update routine.
As well as that, unless you reset the satnav every time you want the full Monty of the speedcam warnings. This of course resets other stuff that you might have programmed in.
However, having said all that, without the reset every time, the speedcam Icons show on the map display all the time.
If you are not too daunted by what I just said, I will dig out a link to exactly what you have to do to install them, but it's best to run them through Kremmens CSV to GPX converter first first to tag on spoken voice and sensible Icons.
Thank you very much for that, and I shall be glad of further help when you are able, please. Doubtless you will also be kind enough to let me know in detail of how to access and thereafter use the file converter which you mention.
In case it matters, I should, however, just add that, so far as I am aware, I currently do not currently see even the icons on the in-car sat nav screen.
But althouth very ignorant of the technicalities of these matters, I do like to think of myself as possessing a certain degree of persistence!
Posted: Tue Mar 10, 2020 7:38 pm Post subject:
Correct. You will not see any third party POIs, only the built in ones. As I said above, you have to go through the motions of completely updating the maps with the added POI file on the Honda version of Garmin, you cannot just 'add a few POIs'.
Here's a bit of light reading on Kremmen's CSV to GPX that you really need to run otherwise the h=Honda puts up a nondescript ico and a beep. I'll look up the other info, but it's on a different website, but it won't be before tomorrow at the earliest.
Posted: Wed Mar 11, 2020 5:59 am Post subject:
Most manufacturers now make it either impossible or very difficult to add speed camera info. These are different to normal POI's that are just single favourites to navigate to.
The only easy way to be warned of cameras is to use a Garmin SatNav or the PGPSW database on a phone.
If the CRV is the same as my Civic then you can link your phone to your car headunit and have the camera positions and speed fed through the CRV headunit sound system. This solution also has the bonus of being directional so you only get alerted to cameras trapping your direction of travel. _________________ Lets be careful out there !
