| Author |
markrmifsud Lifetime Member
Posted: Fri Jul 17, 2020 3:45 pm Post subject: Kenwood DNX9280BT time issues |
Hi there, a strange new problem has just started on this unit.
If I set the Nav time = Auto then it is 1 hour out, ie displays 14:00 when it is 15:00
If I manually set the time to 15:00 then it displays 15:00 but the Nav seems to still use the incorrect time.
Setting to auto, set destination to 1 hour drive, it says eta is 1 hour earlier thanreal time. ie auto set is 14:00, current real time is 15:00 and it says I will arrive at 15:00
Set to Manual, 15:00, 1 hour drive eta is 15:00, similarly if I set a 30 min drive it will say ETA is 14:30.
I have played around back and forth with the time settings, also hard powered off the HU and a full reset, it still has the same error with the times.
Any ideas?
regards |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
Posted: Fri Jul 17, 2020 8:18 pm Post subject: |
It seems like a GMT and GMT+1 problem. Are you able to set the time zone to GMT+1 in the settings? _________________ Richard
TT Via 135 App 12.075: Europe Map v1165 |
| Back to top |
Posted: Sat Jul 18, 2020 10:05 am Post subject: |
Hi, no the options are
set HH:mm or set to auto
To add to this, if I look at the system time in World Clock settings, it shows as 4th Dec 2000. The days are updating and the actual mins are accurate.
I get an average 8 sats with 18ft accuracy and it shows my position accurately whilst driving so it is getting the GPS signals. |
| Back to top |
| Back to top |
M8TJT The Other Tired Old Man
Posted: Mon Jul 20, 2020 7:02 pm Post subject: |
and 20 1/2 years later, it rears its ugly head.  |
| Back to top |
Kremmen Pocket GPS Verifier
Posted: Tue Jul 21, 2020 4:25 am Post subject: |
Would the Y2K bug affect it in this way ?
The Y2K bug was old memory restricted software where dates were just YYMMDD.
The issue arose when before or after comparisons were needed. In those days 990101 (1st Jan 1999) was higher than 981230 (30th Dec 1998) so all was well.
As soon as we crossed Y2K then 000101 (1st Jan 2000) wasn't greater than 991230 so hardware started having issues.
What we had to do was introduce a CC into the mix so 20000101 was greater than 19991230.
FYI Additional info:
Because date comparisons often included birth dates and given some were still working at 70 we had to perform the fix using dates up to 2030, some used 2020. This way a birthdate of 1930, or 1920 was correctly returned.
The software 'fix' said, if YY is greater than 30, or 20, then assume CC is 19 else CC is 20. Moving forward, for any old software still in existence, 2020 could be converted to 1920.
Some fixes used 50 as the cutoff so Y2K may still be an ongoing problem but new software correctly uses CCYYMMDD. _________________ Lets be careful out there ! |
| Back to top |
Posted: Tue Jul 21, 2020 9:29 am Post subject: |
As the problem with OP's unit has only just started, I really can't imagine why we are even discussing the Y2K 'problem'. That was concerning dates, not time.
But OP's problem seems to be, pretty obviously, one of BST v GMT (or whatever you want to call them) as his device is displaying (and calculating on)GMT when it should be BST.
But other than that, I have absolutely no idea of what's CAUSING the problem. I would normally suggest a hard reset, but OP has already done that. |
| Back to top |
| Back to top |
| Back to top |
