Pocket GPS World :: View topic - What brand and size of SD card??
Goto page 1, 2, 3, 4, 5  Next
cfw
PostPosted: Sat Oct 09, 2004 10:11 pm    Post subject: What brand and size of SD card?? Reply with quote
I was using a 256MB CF Sandisk card for my TT3 maps and it was working a treat, the card was borrowed from my digital camera so I decided to buy an SD card so I could put CF card back into my camera. I bought a 512MB SD card made by Peak, I copied all the stuff over from CF to SD and tried that, but after 5 minutes of using TT3 it hangs on me. After having a look around I heard it could be the make of card and/or the size of the SD card. I'd like you to tell me what make and size of SD cards I should get, or better still a solution why this SD card maybe causing TT3 to hang.
cfw
PostPosted: Thu Oct 14, 2004 11:40 pm    Post subject: Reply with quote
What size and what brand of SD card are people using for TT3? Thanks again.
Tim Buxton
PostPosted: Thu Oct 14, 2004 11:45 pm    Post subject: Reply with quote
Look at my sig. I don't use Tomtom, though.
Tim
xda
PostPosted: Fri Oct 15, 2004 4:22 am    Post subject: Reply with quote
Like Tim has said, I used to use TT3 with a Novatech 256 SD card and had frequent lock ups. Switched to a Panasonic and it stopped the lock ups.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
cfw
PostPosted: Fri Oct 15, 2004 9:50 am    Post subject: Reply with quote
Thanks xda, I'm get the impression that it's to do with the card and not the software even though the both of you have changed your navagation software. I would like a bigger card than 128 but I've heard that bigger cards can cause a problem too. What other brands of card are good?
Privateer
PostPosted: Fri Oct 15, 2004 9:59 am    Post subject: Reply with quote
I used to use a 256MB Lexar SD card in my iPAQ 3970 for TTNav3, as you’ll see in my signature. The Lexar has always performed well.
However for the last fortnight I’ve been using a 512MB Kingston SD card, in the 3970, with no apparent problems.
Robert.
Garmin Camper 770 LMT-D
xda
PostPosted: Sat Oct 16, 2004 7:44 am    Post subject: Reply with quote
In TomTom's case it is both, TT3 makes heavy demands on the SD card such that certain brands have been known to cause lockups ie Sandisk. Panasonic and other quality cards don't give this problem. CP5 is much more tolerant and seems to work ok with Sandisk card.
I changed to CoPilot because for me it was a better package, more uptodate maps and database, and doesn't keep telling me it can't find such and such a place as TT3 was when going to a destination that I had been to before in TT2.
Graham.
Nokia 925 Windows 8
kickstart
PostPosted: Sat Oct 16, 2004 5:32 pm    Post subject: Reply with quote
I have an XDA II and use 256M and 512M Kingston SD cards and I also have a 256M Viking SD card. All bought from ebuyer.com and work really well. I'm running TT3 as well as Memory-Map and have never had any problems.
cfw
PostPosted: Sat Oct 16, 2004 11:07 pm    Post subject: Reply with quote
Thanks for that Kickstart, I was looking at getting a Kingston 512MB SD card. Ebuyer you say??... Just had a look at their site, looks like Kingston it is.
juliem
PostPosted: Wed Oct 20, 2004 2:43 pm    Post subject: Reply with quote
Has anyone else got a 512 SD card working with TT3? I've seen someone with a 512 working with copilot. I'm thinking of getting the same 512 SD by Kingston from Ebuyer.
bhau
PostPosted: Wed Oct 20, 2004 6:30 pm    Post subject: Reply with quote
How does one move to a bigger card?
Am a total newbie.. so apologise in advance for perhaps not knowing the basics perhaps
nicknick
PostPosted: Wed Oct 20, 2004 9:24 pm    Post subject: Reply with quote
I have a 512M Panasonic SD card and that has been working since March without any problems with TT3 (in an Axim X5)
The best tip is to use a Japanese make of card
For moving between cards I just copied all the data from the old card onto the PC and then copied from there onto the new card
Nick
bhau
PostPosted: Wed Oct 20, 2004 10:39 pm    Post subject: Reply with quote
Nick
Thanks for your advice
Regards
topgazza
PostPosted: Thu Oct 21, 2004 11:05 am    Post subject: Reply with quote
Why not buy a 512 CF card? Much more reliable and cheaper......
DavidW
PostPosted: Thu Oct 21, 2004 12:54 pm    Post subject: Reply with quote
I can only echo advice earlier up the thread - that TomTom Navigator in particular puts heavy demands on SD cards, with the result that you'll see malfunctions with some 'bad' cards.
Most Sandisk cards cause problems - which is a nuisance as many brands are actually rebadged Sandisk.
For size, 512MB is getting to be very affordable now. You could contact ValueFlash and ask them what they're recommend. They used to say (if you asked politely in an email) which of their cards were rebadged Panasonic - but now that they stock Panasonic "own brand" they may be less forthcoming.
Page 1 of 5
23.104 (22 Oct 25)
