daxeno Occasional Visitor
Posted: Thu Jun 25, 2020 9:56 am Post subject: |
Hi everyone...
i have just bought a nav software for Mercedes Benz GLA 2019.
when i inserted the SD Card, it won't read the card and it says
"No Memory Card Containing Navigation Software installed"
any help to fix this would be much appreciated.
Thanks! |
Nemesis1 Regular Visitor
Posted: Wed Aug 05, 2020 7:51 pm Post subject: |
Here we go again.....
Just got my 2020 C300DE with command online yesterday.
Can’t get anything to load. All trace of personal POI, or navigating to a poi from an SD card has been removed from the system. |
M8TJT The Other Tired Old Man
Posted: Thu Aug 06, 2020 9:46 am Post subject: |
daxeno seemed to be talking about new Sat Nav software, not user POIs.
Clarification would help. |
Posted: Sun Aug 09, 2020 7:13 pm Post subject: |
So command online is HDD run, not SD card like the audio 20 version.
There is no option I can see anywhere in any menu that would indicate you can load personal POI’s onto the system :-( |
gbw Occasional Visitor
Posted: Mon Nov 02, 2020 10:15 pm Post subject: Mercedes A class |
You need the latest MBUX software (from late March 2000. Earlier versions did not give audible warning. You can use the Mercedes single file from here but it must be in a folder called PersonalPOI on a memory stick plugged into the front set of usb sockets. You can also music on this memory stick if you wish as long as it is another folder.
Set up the pio option in navigation.
You will get a graphic on the map and a beep - not awfully loud and only about 100yds before hand.
Have a look at the "AClass Club Forum" elsewhere for more information. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15460 Location: Bradford, West Yorkshire
Posted: Tue Nov 03, 2020 1:39 pm Post subject: Re: Mercedes A class |
gbw wrote: | You need the latest MBUX software (from late March 2000. Earlier versions did not give audible warning. You can use the Mercedes single file from here but it must be in a folder called PersonalPOI on a memory stick plugged into the front set of usb sockets. You can also music on this memory stick if you wish as long as it is another folder.
Are the instructions here still relevant: https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=583794#583794
Or is this a new system from the Comand? |
Posted: Tue Nov 03, 2020 8:25 pm Post subject: Re: Mercedes A class |
MaFt wrote: | gbw wrote: | You need the latest MBUX software (from late March 2000. Earlier versions did not give audible warning. You can use the Mercedes single file from here but it must be in a folder called PersonalPOI on a memory stick plugged into the front set of usb sockets. You can also music on this memory stick if you wish as long as it is another folder.
Unfortunately no good for Command online (NTG 5.2) mate
And yes, MBUX is different again.
Still hoping some one finds a way to add to the new command, but nothing I can figure out or find so far. There is no option in any menu for ‘personal POI’.
The system does have POI baked in, and you can save locations, so just need to find a way into the software to input the locations. |
Dabaws Occasional Visitor
Posted: Sat Dec 19, 2020 1:15 pm Post subject: Re: Mercedes A class |
I have a W177 Mercedes A Class and i want to get speed camera POI on my MBUX. How do I do this? Do i just download the files as normal? There are no instructions on this site for MBUX. |
Posted: Sat Dec 19, 2020 2:32 pm Post subject: |
You have actually quoted instructions on how to do it. Have you even tried that? |
Posted: Sat Dec 19, 2020 2:46 pm Post subject: |
M8TJT wrote: | You have actually quoted instructions on how to do it. Have you even tried that? |
The instructions are for Mercedes Command, not Mercedes MBUX. I’ve checked and can’t find any mention of these POIs working on MBUX. I don’t want to pay for a subscription that might not work. |
Posted: Sat Dec 19, 2020 9:20 pm Post subject: |
Oh sorry. I was completely fooled into tying the first five words in the quote to the first sentence of your question. Silly me.
But in my defence, I have a lowly Honda, not a Merc.
The single file Merc download is in .gpx format, so not easy to see the underlying format. |
Kremmen Pocket GPS Verifier
Posted: Sun Dec 20, 2020 5:36 am Post subject: |
With the previous Merc format the GPX contents needed to be in full capitalised text.
I don't know if that restriction still exists. 50 mph for example needed to be converted to FIFTY MPH. I can't remember what else Nemesis1 found but it's all in his thread. _________________ Lets be careful out there ! |
geoffsut Occasional Visitor
Posted: Thu Apr 14, 2022 9:57 am Post subject: |
i have just purchased a 2020 c class sports with command ntg5.5 can i still install speed camera alerts for this model |
wogga Occasional Visitor
Posted: Sun May 11, 2025 11:24 am Post subject: its 2025 |
H all, I am downloading SC poi's for my Merc Comand sat nav but seem to be having issues with SC database. The FAQ says there should be 3 databases in the package however I can only see sc and pmobile. Neither of these seem to show fixed cameras or red-light. Some of these cameras have been in situ since I last had a merc in 2018.
All other poi's hotels, McD's work fine .
Any idea peeps, thanks in anticipation. |
