| Author |
Kremmen Pocket GPS Verifier
Posted: Sun Jan 10, 2021 5:39 am Post subject: |
Thanks Dales
The program has the embedded code to download the complete database including pMobiles, but I need to confirm that tomorrow morning.
There is a possibility that an old version had the code for excluding pMobiles.
What version of the Converter are you running ? It's in the program top header.
Regardless of the above I'm going to change the V1 program to include both options:
Download with pMobiles
Downl9ad without pMobiles
I have both codes in stock and working in the V2 program.
Hopefully I'll have the new V1 program ready tomorrow afternoon. _________________ Lets be careful out there ! |
| Back to top |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 756 Location: Knaresborough, North Yorkshire.
Posted: Sun Jan 10, 2021 10:48 am Post subject: |
My version is 2020.03.27.84 for the ordinary GPX Converter.
Dales _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
| Back to top |
Posted: Sun Jan 10, 2021 11:17 am Post subject: |
I actually meant the OP
I'd like to track back for the version specs. _________________ Lets be careful out there ! |
| Back to top |
Posted: Tue Jan 12, 2021 9:13 am Post subject: |
Well well well, the OP is right.
The V1 download does not include the pMobiles, no one else obviously uses them.
New version now available with the following options:
**Download CSV Converter V1 (Latest Version) ** _________________ Lets be careful out there ! |
| Back to top |
Gym Occasional Visitor
Posted: Tue Jan 12, 2021 9:55 am Post subject: |
"Well well well, the OP is right."
You sound surprised. My wife knew I was Mr. Right when she met me...she didn't find out my first name was Always until later.
Thanks for the mod, I'll download the latest version tonight.
EDIT: Latest version downloaded and as promised, the option to have pMobiles (or not).
I had a hiccup when updating, as I had renamed the folder containing the contents of the previous version's .zip so uninstalled and reinstalled from the renamed folder.
All is well with the world...well, within the 4 walls of my home office, at any rate.
| Back to top |
Posted: Tue Jan 12, 2021 12:53 pm Post subject: |
What surprised me is that this has been like that for years and no one else spotted they had no pMobiles in the download.
Usually someone finds and reports even the smallest errors. _________________ Lets be careful out there ! |
| Back to top |
Joined: 30/12/2002 17:36:20 Posts: 4923 Location: Oxfordshire, England, UK
Posted: Tue Jan 12, 2021 1:25 pm Post subject: |
| Kremmen wrote: | | What surprised me is that this has been like that for years and no one else spotted they had no pMobiles in the download. |
I wonder if you'll get any complaints from users of the V1 download that for years they have been under protected due to the lack of pMobiles. Even though it's been free to use.  _________________ Robert.
Garmin Camper 770 LMT-D |
| Back to top |
Posted: Tue Jan 12, 2021 2:16 pm Post subject: |
I find it odd that no one has noticed. How many years now ?
Fixed now though, make your own choice. _________________ Lets be careful out there ! |
| Back to top |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Wed Jan 13, 2021 11:19 am Post subject: |
Strange. I think I'm using V1, mine says version 2017.01.27.59 at the top of the screen and when I click PGPSW Database Options - Download Database it takes me here:
[img]https://drive.google.com/file/d/1RnI2WceAMPYi6hI0dchpj803oPy30gnM[/img]
I've used the pMobiles for years.
Edit: Can't get the embedded image to display. Working on it!
2nd Edit: I've given up trying to get the image displayed in line. Here is a link to it: https://drive.google.com/file/d/1RnI2WceAMPYi6hI0dchpj803oPy30gnM/view?usp=sharing _________________ Paul |
| Back to top |
Posted: Wed Jan 13, 2021 12:28 pm Post subject: |
Very odd, let me run the latest V1 and see what I get ...........
............ I'll be back
Version 57 is quite old now, we are on version 87.
I've checked the download of version 87 and both links download the correct Zip from PGPSW.
Both versions links at the bottom.
The improvements are, in reverse order:
Version 87 - 12th January 2021.
1) Option to download with or without pMobiles.
Version 86 - 27th July 2020.
1) There must be a 5 second minimum gap between Approach and Overspeed warnings.
2) Manuals updated with Approach and Overspeed explanations.
Note: This is allow one warning to finish before the next starts.
Version 85 - 24th May 2020.
1) Version check against Dropbox version.
Version 84 - 26th March 2020.
1) Additional info about last Garmin device used and PGPSW database location used by POILoader.
2) Prevent program ending when PGPSW database check fails.
Version 83 - 16th February 2019.
1) New build after Krem PC upgraded/downgraded to Windows 10 and needed a new security certificate
Version 82 - 5th February 2019.
1) If invalid CSV are detected it will offer options to correct.
Version 81 - 3rd February 2019.
1) Trap Direction Converter CSV and stop processing.
2) Add debugging to Database version check.
Version 80 - 25th December 2018.
1) Check Unzip request before proceeding.
2) Change of out of date database colours.
Note: There are unzip options for Cameras only, icons, sound or all.
Before proceeding with anything other than cameras only, a messagebox will ask for confirmation and
the 'No' option will be the default.
Version 79 - 17th December 2018.
1) Update of .NET to 4.7 for Win 10 compatibility.
2) Check for database version on working folder change.
3) Check for incorrect database version.
Version 78 - 14th December 2018.
1) Cosmetic change of empty CSV / WAV / BMP fields from white to beige to indicate no files found.
Version 77 - 3rd December 2018.
1) When you set your Working Directory on the next install it will remember it for subsequent installs.
Version 76 - 1st December 2018.
1) Retreive the actual latest database date from the server for validation.
Version 75 - 21st November 2018.
1) Double click bottom database date to update (only enabled when database out of date).
2) Addition of PGPSW database date.
Version 74 - 14th November 2018.
1) Addition of Basecamp & Mapsource Cache files.
Version 73 - 13th November 2018.
1) Simple checker to see if downloaded Garmin Maps are eating into too much C:\
Version 72 - 24th September 2018.
1) POIloader location changed by Garmin for new installs, program will now look for both locations.
2) If POILoader is not found then the final "Launch POILoader" button is disabled.
Version 71 - 19th February 2018.
1) Facility to check for additional camera files in the sub directory structure.
Version 70 - 18th February 2018.
1) Unzip routine removes existing CSV files if found.
Version 69 - 8th January 2018.
1) Option to include or exclude x5 mph cameras.
Version 68 - 27th December 2017.
1) Inclusion of 55MPH Specs.
2) 22x22, 24x24, 44x44, 44x44 Transparent, Female Voicepack, Male Voicepack will need updating as required.
Version 67 - 30th November 2017.
1) Resize Option
Version 66 - 6th October 2017.
1) POILoader launch added to top menu
Version 65 - 5th October 2017.
1) Option to either Finish or Close CSV Converter and auto launch POILoader.
Version 64 - 12th July 2017.
1) The check for a number in the CSV filename was using the whole path instead of just the filename - fixed.
2) Distance Checker expanded to work with metres and yards.
3) Distance Checker form now floating so can be used in tandem with the main form.
4) UnZip routine rewritten to use .Net 4.5 to overcome a cross platform incompatibility in recent 2017 versions of Shell.dll.
5) The latest help files, except htm, are automatically copied to the program location upon each install = up to date help files via the Help menu.
Note: The HTM helpfile is still available and must be manually copied to your Working Directory for the Help link to work and to be up to date.
6) New Helpfile formats added - DOCX and MHT.
7) If SOX.EXE does not exist in the POILoader folder it will be installed automatically.
8) Any missing BMP and/or WAV/MP3 files now reported in a single message box with the actual filenames of the missing files.
9) If a rogue numeric CSV file is detected it will also auto delete any accompanying WAV and BMP files, if found.
10) Bugfix, the program wasn't reloading all user settings after a clean install - specifically overspeed % - fixed.
11) Manual has had a major rework to be in the correct order and 'proper English innit'
Version 63 - 31st March 2017.
The change text screen was forcing the direction prefix radio button to 'allow', due to a 'tab' ordering issue.
Version 62 - 6th February 2017.
Major rework of the Text Change screen logic to allow more flexibility and some bug fixes.
Version 61 - 3rd February 2017.
Bug found when processing the Text Change screen with CSV files from the Direction Converter - fixed.
Note: This fix also needs the Direction Converter to be updated.
Version 60 - 30th January 2017.
After feedback, TEXT CHANGE screen made more user friendly
1) Top banner now details the steps
2) If you press 'Save and Exit' without processing the gpx files you get a warning/confirmation popup
Version 59 - 27th January 2017.
OverSpeed Text change facility bug - fixed.
Version 58 - 26th January 2017.
Addition of an auto 'copy to Clipboard' function when the program path is queried via the button.
Note:
If you haven't already -
1) Copy the BMP contents as some changed in versions 56 and 57
2) Copy the latest Help Files
Original V1:
**Download CSV Converter V1**
Latest Version 2:
**Download CSV Converter V2** _________________ Lets be careful out there ! |
| Back to top |
MIKECURTIS Occasional Visitor
Posted: Wed Jan 13, 2021 7:43 pm Post subject: CSV to GPX Installer V87 |
Hi Kremmen itsa been a while since i needed your help but decided tyo upgrade from a 2018 version to version 87 as my cameras were not uploading into my Honda Garmin Satnav after the last map update. I am now getting the message when i sry to run setup "Your Administrator has blocked this application because it potentially poses a security threat to your computer. Your security settings do not allow this application to be run on your computerUNKNOWN PUBLISHER" albeit I am running it as administrator in latest update of Windows 10 20H2
I have tried putting exceptions in the firewall paths to no avail and I wonder whether the latest patch of this week KB4598242 has anything to do with the problem
Mike Curtis mikecurtis1000@gmail.com |
| Back to top |
Posted: Thu Jan 14, 2021 6:17 am Post subject: |
The software is digitally signed by me but Windows seems to want a $500+ a year Verisign subscription to a security database. Thanks but no thanks.
However, you can quite safely ignore the warnings. There is a bypass route in each of the 2 steps.
I have to go through the ignore route with Earthshine Dashcam Viewer each time I update it. Both Windows 20H2 and Norton reckon each version is too new and not known.
If it's your AV that's blocking it then that will be because the program replaces CSV files with GPX files very rapidly. Similar behaviour to some ransomware.
To avoid this you need to whitelist the program within the AV.
For you own peace of mind scan the zip with your AV before extract and install. _________________ Lets be careful out there ! |
| Back to top |
Posted: Thu Jan 14, 2021 6:45 am Post subject: CSV to GPX Installer V87 |
I am trying to reinstall the software from scratch by running the setup.exe. I certainly trust your software and have used it for years
The install will not proceed after the error message and there is no option to do otherwise. Only a CLOSE button. I have whitelist the program within the AV software
There are some comments on the latest microsoft 2021 patch that may be relevent about digital signatures |
| Back to top |
| Back to top |
Posted: Thu Jan 14, 2021 1:22 pm Post subject: CSV to GPX Installer V87 |
YES That is the error message as featured in the link you sent me. Should I try the registry hack?
Mike |
| Back to top |
| Back to top |
