Pocket GPS World :: View topic - garmin lgv820
garmin lgv820
bulldog43
PostPosted: Sat Oct 04, 2025 3:07 pm    Post subject: garmin lgv820 Reply with quote
hi all ive just got my self a lgv 820 satnav the problem is this ive download the speedcamara data base and installed it to said satnav but the problem is that all thought the speed camaras show up but with a different icon it wont show the custom bmp that ive used on my last satnav which was also a garmin any help would be greatful
PostPosted: Sat Oct 04, 2025 3:32 pm    Post subject: Reply with quote
As long as the BMP has the same name as the various speed cameras it should work
What size are they 22x22 or 44x44
I did create a step by step instruction but ImgUR have blocked access to all the images
Lets be careful out there !
bulldog43
PostPosted: Sat Oct 04, 2025 5:13 pm    Post subject: Reply with quote
Thank you for your response the bmps are 22x22 and 44x44 I've tried both sizes they worked perfectly on my garmin dezel 720
PostPosted: Sat Oct 04, 2025 5:39 pm    Post subject: Reply with quote
Modern Nuvi's don't show the BMP until you are on a route and get close to the point
With your file in place use the Garmin simulated GPS/route option, set a route, and watch from your armchair as you pass a point with a known camera
Assuming this is the issue, you can't view icons by just scrolling round the map
bulldog43
PostPosted: Sat Oct 04, 2025 5:59 pm    Post subject: Reply with quote
They don't show up whilst I'm driving on any route
But the garmin satnav puts a icon where the downloaded speed camara is that is a large icon with an R in a light brown background
bulldog43
PostPosted: Sat Oct 04, 2025 6:13 pm    Post subject: Reply with quote
I've just tried the armchair journey and no custom bmp I've tried to post a picture of the icon used by satnav but I can't paste it to our conversation
PostPosted: Sun Oct 05, 2025 5:40 am    Post subject: Reply with quote
Strange
As a test, can you use the BMPs that come with the download and see if they work
I do remember something I read where the bmp needs to be a particular colour depth max, number of colours, which I forget
Having looked at all the ones I have, that work, they are
"44 x 44 x RGB - 8 bits/channel"
"22 x 22 x Index - 256 color palette"
"44 x 44 x Index - 256 color palette"
Now that ImgUR has gone I'm investigating ImgBB for image hosting
bulldog43
PostPosted: Sun Oct 05, 2025 9:02 am    Post subject: Reply with quote
Once again thank you for your help
I'll have a look later at the colour depth
I'll try the bmp that come with the download
It just seems very strange that the bmps don't show up in my new satnav that I've used for ten years in my old satnav.
I'll look and test later today and get back to you with the results.
bulldog43
PostPosted: Sun Oct 05, 2025 4:32 pm    Post subject: Reply with quote
well after checking the bit depth and changing it = nothing shows ie custom bmp
checking that the details match ie gatso csv and gatso bmp =nothing shows ie custom bmp
changing the sizes 22x22 44x44 8bit 256 colour palette =nothing shows ie custom bmp
so after spending about five hours on this ive come to the conclusion that this satnav wont take custom bmp so im just going to put up with it
so thank you for your help and input it was greatly appreciated
PostPosted: Sun Oct 05, 2025 5:35 pm    Post subject: Reply with quote
Very odd
Another thought, make sure you haven't got any other speedcam active like the Cyclops as with both running Cyclops may override yours
bulldog43
PostPosted: Sun Oct 05, 2025 7:30 pm    Post subject: Reply with quote
I'll turn cyclops and see what happens
Thank you
bulldog43
PostPosted: Sat Oct 11, 2025 5:30 pm    Post subject: Reply with quote
my apologies for not replying since last week .
i've tried with cyclops off and there's no conflict.
with cyclops on there's no conflict.
so i'm still at a lost as to why custom bmps don't work on my garmin lgv 820 .
so ill just have to get on with it
so once again thank you for your help
PostPosted: Sat Oct 11, 2025 5:39 pm    Post subject: Reply with quote
The only other thing I'd try is my CSV Converter as that checks the validity of the files and uses GPX instead of CSV that POILoader treats differently
23.122 (10 Dec 25)
