| Author |
macsmart Occasional Visitor
Joined: Oct 25, 2004 Posts: 6 Location: Bonn, Germany
Posted: Fri Dec 03, 2004 8:37 am Post subject: iCN 510 Service Pack 1 |
Service Pack 1 for iCN 510 is available since a few days. Whats new after installing this patch?
Regards from Germany,
Juergen |
| Back to top |
breers Occasional Visitor
Posted: Fri Dec 03, 2004 11:16 pm Post subject: |
Hi Juergen
Sorry not to much help here - could you let me know what a service pack is or does? new to the sat nav world
breers |
| Back to top |
PaulWildsmith Occasional Visitor
| Back to top |
Spider-101 Occasional Visitor
Posted: Sat Dec 04, 2004 10:33 am Post subject: |
I may be being dim, where do you get the service pack from? I can't find it not the Navman Website.
Thanks |
| Back to top |
Posted: Sat Dec 04, 2004 11:25 am Post subject: |
When you go to Navman's website here, there is a box on the left which says "Navman Service Packs". Click on it and follow the link for iCN510. Make sure you have your 510 connected to the PC. Alternatively, read this page. _________________ Tim |
| Back to top |
Simon1 Frequent Visitor
Posted: Sat Dec 04, 2004 3:39 pm Post subject: |
| See Tim? I'm not the only one........ |
| Back to top |
Posted: Sat Dec 04, 2004 3:50 pm Post subject: |
I know, but you've been here longer.  _________________ Tim |
| Back to top |
Posted: Sat Dec 04, 2004 3:56 pm Post subject: |
After using the SP1 for a couple of days, the big improvements as far as I'm concerned are:
1. The POI icons no longer disappear!! Yippee!
2. There is more detail regarding the current road name on the bottom of the 3d screen. For instance, the A3 west of the M25: previously the road name only appeared if it was called something like the Ripley Bypass. At other times it was blank. Now the A3 is clearly named and other names replace it as you travel along.
3. You can now type in the house no. you are looking for instead of being offered a range of numbers.
4. The numerical keyboard is complete.
Overall, a few decent improvements to some of the more niggling faults. |
| Back to top |
JChew Occasional Visitor
Posted: Sat Dec 04, 2004 10:49 pm Post subject: |
In the past, the unit only presented a limited range of addresses and did not allow entry of specific house numbers. I had to pick the house number range closest to the destination and navigate to it on the map. Now with SP1, I can type in specific house numbers javascript:emoticon( ), but the unit still will not accept any number that is not part of the original, limited range. javascript:emoticon(' ')
Example:
Destination>Address>California>San Francisco>45th Ave>1200 (house number)
The unit will not accept this house number because it still appears to be referencing the original limited range (starting with 1900).
I understand that the address database and the map database are separate. I'm not sure if TeleAtlas is responsible for both. The map appears to cover the addresses, but the incomplete address database is still a problem. |
| Back to top |
Pekkle Occasional Visitor
Posted: Mon Dec 06, 2004 4:15 am Post subject: |
| JChew wrote: | In the past, the unit only presented a limited range of addresses and did not allow entry of specific house numbers. I had to pick the house number range closest to the destination and navigate to it on the map. Now with SP1, I can type in specific house numbers javascript:emoticon( ), but the unit still will not accept any number that is not part of the original, limited range. javascript:emoticon(' ')
Example:
Hi JChew, Thanks for the info. That's exactly what I am looking to find out. I was going to buy it back again to see how SP1 improved the handling of address but I guess you have answered my question. |
| Back to top |
larkshall Regular Visitor
Joined: Nov 11, 2004 Posts: 112 Location: Selby North Yorkshire
Posted: Tue Dec 07, 2004 10:19 am Post subject: Service Pack what service pack? |
There is no service pack for the ICN510, either on Navman site, or via the direct link in Smartst on pc.
There is summat for the 6 series.
Had my ICN 4 5 weeks, its ok on the whole, apart from
Sending me in a never ending loop around the Outskirts of Luxemburg (road works).
No Gatso POI on N55 between Aachen and Monschau (there are 3 got flashed by all of them), noted the Long/Lat on my Garmin handheld. Yes had got the EU POI's loaded)
Maps being terribly out of date (Bypass around Selby unknown), a blocked off road in Selby not known (been like that for 8 years).
Oh whilst sitting at Zeebrugge ferry port, got it to work a route to York, and although ferries info loaded, the route was from Zeebrugge, down the French coast somewhere, to the chunnel......I ask you
regards
David Low |
| Back to top |
icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Tue Dec 07, 2004 10:40 am Post subject: |
Click here for the service packs The 510 is the fifth product down.
The camera database relies on user submissions and is not infallable. Please send in the missing cameras for inclusion.
This unfortunately is a TeleAtlas error, but you could submit them to Navman who will pass them on to TA. _________________ Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
| Back to top |
Posted: Tue Dec 07, 2004 11:06 am Post subject: |
| icsys wrote: | | This unfortunately is a TeleAtlas error, but you could submit them to Navman who will pass them on to TA. |
Or even better, cut out the middle man and report map errors directly to TeleAtlas. Each submission receives a reference ID and you can use the reference ID you're given (this is given once, at the time of submission and not via email, so I save all references to a text file immediately) on the same page to see if anything is being done about it.
For instance, if you go to the page in the Hyperlink above, (click on the red TeleAtlas), select "View request status" and put the reference W007oko45 into the box, it will tell you about a submission I made on October the 17th.
Oh, and if you do use the form, you'll need to type in what product you're using manually if you're using anything with V3, as the new software isn't in the list yet. _________________ Tim |
| Back to top |
Posted: Tue Dec 07, 2004 11:37 am Post subject: Thanks |
Thanks guys, will have a go at teleatlas
Where do I send gatso co-ordinates (Europe),and camera info? |
| Back to top |
Posted: Tue Dec 07, 2004 12:16 pm Post subject: |
Send any camera additions / changes to
cameras-at-pocketgpsworld.com _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
| Back to top |
| Back to top |
