Pocket GPS World :: View topic - O2 XDA IIs Tom Tom Navigator 3 and Bluetooth
avaya
PostPosted: Wed Dec 08, 2004 11:24 am    Post subject: O2 XDA IIs Tom Tom Navigator 3 and Bluetooth Reply with quote
I bought an XDA IIs yesterday an dmust admit that I am very pleased with it. Previoulsy had the ipaq 6340, not sure why they released that model.
The problem I am facing now is that ever since I installed the Tom Tom Navigator software, my jabra 250 bluetooth headset will not connect. It pairs up bu won't connect for use. I initially installed the new Tom Tom 3.07 patch but uninstalled it and put on the 2.07 version. That hasn't solved my problem.
Any advice?
PostPosted: Wed Dec 08, 2004 3:55 pm    Post subject: Reply with quote
the uninstall of 3.07 may not have worked. You'll need to check the registry to see if BTCeIf.dll is back in the value.
The_Pilgrim
PostPosted: Thu Dec 09, 2004 4:39 pm    Post subject: Reply with quote
Hi avaya
i would recommend you install Pocket bluetooth tools it can be downloaded from here www.bluetooth.jazztel.es
i will sort out all you bt connection problems.i use it with my xda 2 +fortuna bt clipon + jabra 250 headset. it works a dream.
Regards
The Pilgrim
alix776
PostPosted: Thu Dec 09, 2004 8:48 pm    Post subject: Reply with quote
it should work fine changing to 2.07 wont solve the problem as the headset and gps use different serial ports so you can use both at the same time make sure you have tne lastest rom verision which should be 1.72 though do a FULL BACK UP before you do this as it will erase all the info on there you can get it from the o2 website this should do it i havent tried a jabra with my xda2 yet so ill try it at weekend as i left my charger at home this week and left the house with tge jabras batterry flat and get back to you
device Lumia 950 xl
gpssparky
PostPosted: Thu Dec 09, 2004 9:31 pm    Post subject: Reply with quote
XDA IIs has all sorts of problems with BT headsets.
Search the forums at
www.xda-developers.com
Everyone is waiting for a patch.
Everywhere and nowhere
Tomtom Go 540 Live - That's it.
The_Pilgrim
PostPosted: Fri Dec 10, 2004 10:49 am    Post subject: Reply with quote
HI
Since installing BTtools i have had no problems with any BT headsets or any BT gps receiver.
I think you should try bttools as this is probably what you have been waiting for.
Regrads
The Pilgrim
Tarkuk
PostPosted: Sat Dec 11, 2004 11:42 pm    Post subject: Reply with quote
I have exactly the same problem but with my Moto BT headset.
Not sure what the problem is
But i can say that i have tried other GPS software and they work fine but Tom Tom 3 does not work.
Hope their is a fix for this.
24.041 (01 Apr 26)
