Pocket GPS World :: View topic - TTN2 Post your fault here!!!
Goto page 1, 2, 3  Next
MarkRD
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: TTN2 Post your fault here!!! Reply with quote
Ipaq 3870
128Mb SD Card for GB map
Garmin GPSII+
No problems so far
Mark
RichDem
Compaq Ipaq 3950 (ROM 1.00)
Leadtek 9532
No longer able to use the "Alternatives & Navigate to" options. Nothing happens when these are selected
RobMob
Compaq 3970
Emtac BT GPS
128MB SD card
ROM 2.0
Few immediate findings after my SD card format and map re-install.
1) Whilst able to now set up favourites (by the way I inadvertantly did not copy over favourites file to SD card and have therefore started from scratch)when trying to navigate to them rather than hang program now closes. But just discovered only does this when a route is already in place. If I clear the existing route first in Map view I can then navigate successfully to favourites. Didn't have this problem in TTNAV1.
2) Selecting Alternative route or Original Route in Map screen - program closes
3) Sometimes able to get Instructions other times TTNAV2 closes.
RobMob
Houmark
HP IPAQ 5450
Socketcom / Emtac BT GPS
Program installed in internal memory
Maps installed on 256 MB Sandisk Ultra Compact Flash Card
No problems registred.
boblister
HP Ipaq 3970
Sapphire RGM-2000 also Garmin GPSIII+
Maps on a Sandisk 128K CF
Tony_B
iPAQ 3870 64MB MMC
Hiacomm Hi-203
No problems except 64MB map will not fit on a 64MB card MMC or CF
agibbs
Pocket Loox
Holux GM-270 CF
TT2 internal, maps on SD card (no special formatting)
Problems with system freezes, especially setting depart/dest from favourites
Andrew Gibbs
NickR
iPAQ 3970 (ROM 2.10)
iPAQ Nav System
maps on 256mb CF card in iPAQ Nav System Sleeve
Problems with system freezes and program crashes, especially setting depart/dest from favourites. Also did not close GPS program but does now when closing task TOMTOM 2 ??????
Nick
Stealie
Compaq Ipaq 3950 (ROM 1.10)
Leadtek 9532
Unable to navigate from favourites with tap & hold feature, problems navigating to any favourites especially "Home"
Steve
SteveRose
Compaq iPAQ 3870 with 128 SD card
Leadtek 9531
No problems found
rwbthatisme
Ipaq 5455
Navman 3000
Sandisk 256mb CF
no problems
wibble
oisky
iPAQ 5450
Standard TomTom Reciever
Sandisk 128 mb SD card
Freezes when navigating to HOME or in favourites navigating to HOME. Interestingly doesn't crash if I change my home address to another 'known' good address? Maybe some areas in Britain are 'faulty' when navigating to ???
clem
Oisky,
I get the same problem. If you use the recent destination list instead of home it works fine (as long as your home destination is in the recent destination list of course). it's a workaround but it does the trick until TT release the update.
steve111
Ipaq 3970 (ver 2.00)
ematac bluetooth gps
maps on SD card
problems:
1/ often can not get gps signal to respond.
2/ 3D postion jumps about, totally unuseable in 3D mode also no speed indication.
3/ very slow operation of address finding
steve
Michael
Compaq iPAQ 3630
Haicom H-203E
GPS Assist
TTN2 & GPSAssist on internal RAM, GB Map on Toshiba 2GB PCCard.
Seems to be fine in the majority, but experience frequent long pauses while in navigation mode.
Michael
View user's profile Send private message AIM Address
Page 1 of 3
24.041 (01 Apr 26)
